Trigger question, is compare on non existing previous item value possible?
  • toj
    • Oct 2023
    Hi
    Im trying to trigger if the previous item value is not the same as "current/last" item value, but trigger only fires if there is a item value in history aka if a previous item value exists.
    In my world a item value that does not exists should not be equal to one that does, is what im trying to do just not possible in zabbix?
    # My Trigger
    count(/Zabbix server/log[/var/log/my.log],#1,"regexp","ERROR")>0 and last(/Zabbix server/log[/var/log/my.log],#1)<>last(/Zabbix server/log[/var/log/my.log],#2)
    // Torben
  • Answer selected by toj at 16-04-2024, 12:41.
    cyber
    • 5004
    How long you keep history, so you end up having no more than one value there?
    Otherwise its quite understandable, that you cannot make proper calculation if some values are unknown... There are some cases, where it works, but not in this case, I think...
      • 5004
      • toj
        • Oct 2023
        Ok, that ofc. makes sense.
        Thanks a lot for the anwser.
