Zabbix server is not running
  • jros
    • Mar 2023
    • 16
    Hi to all!
    I have been having problems with Ubuntu and Zabbix.
    At the morning we are getting an error on frontend telling us that database not found. After investigation I noticed that Ubuntu had been doing the daily update and upgrade but it hangs when restarting the services, including mariadb and zabbix-server. After investigation I noticed that zabbix-server service didn't stop if mariadb was stopped, I think zabbix-server service wait for mariadb stop but if mariadb is stopped the zabbix-server is waiting for ever.
    Ok, I stoped zabbix-server service and then update and upgrade all packages.
    All seems be ok but I have a message on zabbix UI: "Zabbix serrver is not running: the information displayed may not be current" ...
    Looking at logs seems that zabbix-server ends by self, the service is active but exited and I can see at log a message that says to recive a SIGKILL message.
    administrador@SZabbix:~$ sudo systemctl status zabbix-server
    [sudo] password for administrador:
    ● zabbix-server.service - LSB: Start zabbix-server daemon
         Loaded: loaded (/etc/init.d/zabbix-server; generated)
         Active: active (exited) since Tue 2024-04-16 15:03:28 UTC; 2min 23s ago
           Docs: man:systemd-sysv-generator(8)
        Process: 1264 ExecStart=/etc/init.d/zabbix-server start (code=exited, status=0/SUCCESS)
            CPU: 6ms
    abr 16 15:03:28 SZabbix systemd[1]: Starting zabbix-server.service - LSB: Start zabbix-server daemon...
    abr 16 15:03:28 SZabbix systemd[1]: Started zabbix-server.service - LSB: Start zabbix-server daemon.
    What could be happening?
  • Answer selected by jros at 17-04-2024, 13:56.
    jros
    • Mar 2023
    • 16
    Indeed I had to reinstall zabbix-server-mysql ...
    # wget https://repo.zabbix.com/zabbix/6.4/ubuntu/pool/main/z/zabbix-release/zabbix-release_6.4-1+ubuntu22.04_all.deb
    # dpkg -i zabbix-release_6.4-1+ubuntu22.04_all.deb
    # apt update
    # apt install zabbix-server-mysql
    Solved!!
    • jros
      • Mar 2023
      • 16
      the log says:
        1289:20240416:092010.760 ****** Enabled features ******
        1289:20240416:092010.760 SNMP monitoring:           YES
        1289:20240416:092010.760 IPMI monitoring:           YES
        1289:20240416:092010.760 Web monitoring:            YES
        1289:20240416:092010.760 VMware monitoring:         YES
        1289:20240416:092010.760 SMTP authentication:       YES
        1289:20240416:092010.760 ODBC:                      YES
        1289:20240416:092010.760 SSH support:               YES
        1289:20240416:092010.760 IPv6 support:              YES
        1289:20240416:092010.760 TLS support:               YES
        1289:20240416:092010.760 ******************************
        1289:20240416:092010.760 using configuration file: /etc/zabbix/zabbix_server.conf
        1289:20240416:092011.019 Zabbix supports only "utf8_bin,utf8mb3_bin,utf8mb4_bin" collation(s). Database "zabbix" has default collation "utf8mb4_general_ci"
        1289:20240416:092011.375 current database version (mandatory/optional): 06040000/06040026
        1289:20240416:092011.375 required mandatory version: 06040000
        1353:20240416:092011.451 starting HA manager
        1353:20240416:092011.466 HA manager started in active mode
        1289:20240416:092011.482 server #0 started [main process]
        1356:20240416:092011.484 server #1 started [service manager #1]
        1358:20240416:092011.513 server #2 started [configuration syncer #1]
        1641:20240416:092015.063 server #3 started [alert manager #1]
        1643:20240416:092015.067 server #5 started [alerter #2]
        1644:20240416:092015.069 server #6 started [alerter #3]
        1646:20240416:092015.071 server #8 started [lld manager #1]
        1645:20240416:092015.072 server #7 started [preprocessing manager #1]
        1642:20240416:092015.074 server #4 started [alerter #1]
        1647:20240416:092015.077 server #9 started [lld worker #1]
        1648:20240416:092015.080 server #10 started [lld worker #2]
        1645:20240416:092015.083 [1] thread started [preprocessing worker #1]
        1645:20240416:092015.083 [2] thread started [preprocessing worker #2]
        1645:20240416:092015.083 [3] thread started [preprocessing worker #3]
        1654:20240416:092015.086 server #12 started [timer #1]
        1657:20240416:092015.090 server #14 started [discoverer #1]
        1656:20240416:092015.091 server #13 started [http poller #1]
        1653:20240416:092015.092 server #11 started [housekeeper #1]
        1659:20240416:092015.097 server #15 started [history syncer #1]
        1662:20240416:092015.101 server #16 started [history syncer #2]
        1664:20240416:092015.106 server #17 started [history syncer #3]
        1666:20240416:092015.107 server #18 started [history syncer #4]
        1668:20240416:092015.111 server #19 started [escalator #1]
        1669:20240416:092015.116 server #20 started [proxy poller #1]
        1670:20240416:092015.117 server #21 started [self-monitoring #1]
        1674:20240416:092015.126 server #23 started [poller #1]
        1675:20240416:092015.127 server #24 started [poller #2]
        1676:20240416:092015.133 server #25 started [poller #3]
        1677:20240416:092015.140 server #26 started [poller #4]
        1678:20240416:092015.147 server #27 started [poller #5]
        1673:20240416:092015.148 server #22 started [task manager #1]
        1681:20240416:092015.175 server #29 started [trapper #1]
        1680:20240416:092015.175 server #28 started [unreachable poller #1]
        1682:20240416:092015.181 server #30 started [trapper #2]
        1684:20240416:092015.189 server #31 started [trapper #3]
        1686:20240416:092015.193 server #32 started [trapper #4]
        1688:20240416:092015.202 server #33 started [trapper #5]
        1690:20240416:092015.209 server #34 started [icmp pinger #1]
        1692:20240416:092015.214 server #35 started [alert syncer #1]
        1696:20240416:092015.219 server #36 started [history poller #1]
        1697:20240416:092015.222 server #37 started [history poller #2]
        1698:20240416:092015.226 server #38 started [history poller #3]
        1700:20240416:092015.231 server #39 started [history poller #4]
        1705:20240416:092015.239 server #40 started [history poller #5]
        1706:20240416:092015.241 server #41 started [availability manager #1]
        1707:20240416:092015.243 server #42 started [trigger housekeeper #1]
        1710:20240416:092015.247 server #43 started [odbc poller #1]
        1659:20240416:092016.105 error reason for "SWEBI:perf_counter_en["\Web Service(_Total)\Total Method Requests/Sec", 60]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Bytes Received" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1659:20240416:092016.106 item "SWEBI:perf_counter_en["\Web Service(_Total)\Trace Requests/Sec", 60]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Bytes Sent" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1659:20240416:092016.106 error reason for "SWEBI:perf_counter_en["\APP_POOL_WAS(PDAPad Server)\Current Application Pool Uptime"]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Bytes Received" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1659:20240416:092016.106 item "SWEBI:perf_counter_en["\APP_POOL_WAS(Prensa Intranet)\Current Application Pool Uptime"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Bytes Sent" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1659:20240416:092016.106 item "SWEBE:perf_counter_en["\PhysicalDisk(1 D:)\Avg. Disk sec/Write",60]" became supported
        1659:20240416:092016.415 error reason for "SWEBI:perf_counter_en["\HTTP Service Request Queues(ASP.NET v4.0)\CurrentQueueSize"]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Method Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1659:20240416:092016.415 item "SWEBI:perf_counter_en["\APP_POOL_WAS(LanzadorSilverlight)\Total Application Pool Recycles"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Method Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1659:20240416:092017.502 error reason for "SWEBI:perf_counter_en["\Web Service(_Total)\Unlock Requests/Sec", 60]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Bytes Transferred" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1659:20240416:092017.502 error reason for "SWEBI:perf_counter_en["\APP_POOL_WAS(TPLEmuasaV3)\Current Application Pool Uptime"]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Bytes Transferred" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092019.125 error reason for "SWEBI:perf_counter_en["\APP_POOL_WAS(KPIExports)\Total Application Pool Recycles"]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Search Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1680:20240416:092019.331 resuming Zabbix agent checks on host "SCA": connection restored
        1659:20240416:092020.627 error reason for "SWEBI:perf_counter_en["\Web Service(_Total)\NonAnonymous Users/sec", 60]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Connection Attempts (all instances)" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1659:20240416:092020.627 error reason for "SWEBI:perf_counter_en["\APP_POOL_WAS(MVC)\Current Application Pool Uptime"]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Connection Attempts (all instances)" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1678:20240416:092021.741 Zabbix agent item "perf_counter_en["\PhysicalDisk(5)\Avg. Disk Write Queue Length",60]" on host "SCOPIAS" failed: first network error, wait for 15 seconds
        1662:20240416:092022.159 error reason for "SWEBI:perf_counter_en["\Memory\Page Faults/sec"]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Copy Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1659:20240416:092022.722 item "SWEBI:perf_counter_en["\APP_POOL_WAS(Alfresco)\Current Application Pool Uptime"]" became supported
        1662:20240416:092023.170 item "SWEBI:perf_counter_en["\APP_POOL_WAS(ASP.NET v4.0)\Total Application Pool Recycles"]" became supported
        1664:20240416:092024.198 error reason for "SWEBI:perf_counter_en["\Web Service(_Total)\Total Connection Attempts (all instances)"]" changed: Failed to get counter for path "\\Web Service Cache\\Current Files Cached" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092024.199 item "SWEBI:perf_counter_en["\Web Service(_Total)\Service Uptime"]" became not supported: Failed to get counter for path "\\Web Service Cache\\Current Metadata Cached" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092024.199 error reason for "SWEBI:perf_counter_en["\HTTP Service Request Queues(.NET v4.5 Classic)\CurrentQueueSize"]" changed: Failed to get counter for path "\\Web Service Cache\\Current Metadata Cached" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092024.199 error reason for "SWEBI:perf_counter_en["\APP_POOL_WAS(ASP.NET v4.0 Classic)\Total Application Pool Recycles"]" changed: Failed to get counter for path "\\Web Service Cache\\Current Files Cached" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092024.199 error reason for "SWEBI:perf_counter_en["\APP_POOL_WAS(Alfresco SGD)\Current Application Pool Uptime"]" changed: Failed to get counter for path "\\Web Service Cache\\Current Files Cached" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092024.199 item "SWEBI:perf_counter_en["\APP_POOL_WAS(Comagua)\Current Application Pool Uptime"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Unlock Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092024.199 error reason for "SWEBI:perf_counter_en["\Memory\Pages/sec"]" changed: Failed to get counter for path "\\Web Service Cache\\Current Files Cached" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092024.199 error reason for "SWEBI:perf_counter_en["\PhysicalDisk(0 C:)\Avg. Disk Read Queue Length",60]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Unlock Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092024.199 item "SWEBE:perf_counter_en["\Memory\Page Faults/sec"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Delete Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1680:20240416:092024.376 resuming SNMP agent checks on host "Contraparada_1": connection restored
        1675:20240416:092024.672 Zabbix agent item "perf_counter_en["\Paging file(_Total)\% Usage"]" on host "SCA" failed: first network error, wait for 15 seconds
        1666:20240416:092025.276 error reason for "SWEBI:perf_counter_en["\Web Service Cache\URI Cache Misses"]" changed: Failed to get counter for path "\\Web Service Cache\\Current URIs Cached" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1666:20240416:092025.276 error reason for "SWEBI:perf_counter_en["\HTTP Service Request Queues(.NET v4.5)\CurrentQueueSize"]" changed: Failed to get counter for path "\\Web Service Cache\\Current URIs Cached" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1666:20240416:092025.276 item "SWEBI:perf_counter_en["\APP_POOL_WAS(LanzadorSilverlight)\Current Application Pool Uptime"]" became supported
        1666:20240416:092025.357 error reason for "SWEBI:perf_counter_en["\PhysicalDisk(0 C:)\Avg. Disk Write Queue Length",60]" changed: Failed to get counter for path "\\Web Service Cache\\URI Cache Hits" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1662:20240416:092025.399 error reason for "SWEBI:perf_counter_en["\Web Service Cache\URI Cache Hits %"]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Delete Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1659:20240416:092025.753 error reason for "SWEBI:perf_counter_en["\HTTP Service Request Queues(.NET v2.0 Classic)\CurrentQueueSize"]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Delete Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1659:20240416:092025.753 error reason for "SWEBI:perf_counter_en["\APP_POOL_WAS(Alfreeco Jfranco)\Total Application Pool Recycles"]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Delete Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1659:20240416:092025.868 item "SWEBI:perf_counter_en["\APP_POOL_WAS(Indigest)\Current Application Pool Uptime"]" became not supported: Failed to get counter for path "\\Web Service Cache\\URI Cache Hits %" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1659:20240416:092025.868 item "SWEBI:perf_counter_en["\PhysicalDisk(0 C:)\Current Disk Queue Length",60]" became not supported: Failed to get counter for path "\\Web Service Cache\\URI Cache Hits %" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1659:20240416:092025.938 error reason for "SWEBI:perf_counter_en["\HTTP Service Request Queues(.NET v2.0)\CurrentQueueSize"]" changed: Failed to get counter for path "\\Web Service Cache\\File Cache Flushes" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1666:20240416:092026.410 error reason for "SWEBI:perf_counter_en["\APP_POOL_WAS(ASP.NET v4.0)\Current Application Pool Uptime"]" changed: Failed to get counter for path "\\Web Service Cache\\URI Cache Misses" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1666:20240416:092026.411 error reason for "SWEBI:perf_counter_en["\PhysicalDisk(1 D:)\Current Disk Queue Length",60]" changed: Failed to get counter for path "\\Web Service Cache\\URI Cache Misses" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1662:20240416:092028.421 item "SWEBI:perf_counter_en["\APP_POOL_WAS(ASP.NET v4.0 Classic)\Current Application Pool Uptime"]" became supported
        1662:20240416:092028.421 item "SWEBI:perf_counter_en["\PhysicalDisk(0 C:)\Disk Reads/sec",60]" became supported
        1666:20240416:092028.610 item "SWEBI:perf_counter_en["\APP_POOL_WAS(.NET v2.0 Classic)\Total Application Pool Recycles"]" became supported
        1666:20240416:092028.610 item "SWEBI:perf_counter_en["\System\Threads"]" became supported
        1659:20240416:092029.045 item "SWEBI:perf_counter_en["\HTTP Service Request Queues(AquacisGDPR)\CurrentQueueSize"]" became supported
        1664:20240416:092030.475 item "SWEBI:perf_counter_en["\HTTP Service Request Queues(ControlPresupuestarioV4)\CurrentQueueSize"]" became not supported: Failed to get counter for path "\\Web Service Cache\\File Cache Misses" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092030.475 item "SWEBI:perf_counter_en["\APP_POOL_WAS(.NET v2.0)\Total Application Pool Recycles"]" became not supported: Failed to get counter for path "\\Web Service Cache\\File Cache Misses" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092030.476 item "SWEBI:perf_counter_en["\PhysicalDisk(0 C:)\Avg. Disk sec/Read",60]" became not supported: Failed to get counter for path "\\Web Service Cache\\File Cache Misses" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092030.692 item "SWEBI:perf_counter_en["\HTTP Service Request Queues(MoveServer)\CurrentQueueSize"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Get Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092030.692 item "SWEBI:perf_counter_en["\APP_POOL_WAS(HttpBackendAcceso400)\Total Application Pool Recycles"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Get Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092030.756 item "SWEBI:perf_counter_en["\PhysicalDisk(1 D:)\Avg. Disk sec/Read",60]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Get Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1662:20240416:092033.528 item "SWEBI:perf_counter_en["\HTTP Service Request Queues(Happy)\CurrentQueueSize"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Head Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1662:20240416:092033.528 item "SWEBI:perf_counter_en["\APP_POOL_WAS(AquacisGDPR)\Total Application Pool Recycles"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Head Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1662:20240416:092033.528 item "SWEBI:perf_counter_en["\APP_POOL_WAS(Alfreeco Jfranco)\Current Application Pool Uptime"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Head Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1662:20240416:092033.528 item "SWEBE:perf_counter_en["\Web Service(_Total)\Bytes Received/sec", 60]" became supported
        1662:20240416:092033.528 item "SWEBE:perf_counter_en["\Web Service(_Total)\Bytes Sent/sec", 60]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Locked Errors" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092033.773 item "SWEBI:perf_counter_en["\HTTP Service Request Queues(Gestión Documental EMUASA Alfresco)\CurrentQueueSize"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Lock Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092033.773 item "SWEBI:perf_counter_en["\HTTP Service Request Queues(As400HttpAccess)\CurrentQueueSize"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Lock Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092033.773 item "SWEBI:perf_counter_en["\APP_POOL_WAS(.NET v2.0 Classic)\Current Application Pool Uptime"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Lock Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092033.773 error reason for "SWEBE:perf_counter_en["\Web Service(_Total)\Bytes Total/Sec", 60]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Logon Attempts" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1666:20240416:092033.832 error reason for "SWEBI:perf_counter_en["\APP_POOL_WAS(.NET v2.0)\Current Application Pool Uptime"]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Locked Errors" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1666:20240416:092033.832 error reason for "SWEBE:perf_counter_en["\Web Service(_Total)\Connection Attempts/Sec", 60]" changed: Failed to get counter for path "\\Web Service Cache\\Metadata Cache Hits" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092033.910 error reason for "SWEBI:perf_counter_en["\HTTP Service Request Queues(LabPda)\CurrentQueueSize"]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Locked Errors" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092033.910 error reason for "SWEBI:perf_counter_en["\HTTP Service Request Queues(PandoraServices)\CurrentQueueSize"]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Locked Errors" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1666:20240416:092034.075 error reason for "SWEBI:perf_counter_en["\APP_POOL_WAS(IdentityServer)\Total Application Pool Recycles"]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Logon Attempts" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1662:20240416:092034.164 error reason for "SWEBI:perf_counter_en["\HTTP Service Request Queues(PDA Partes)\CurrentQueueSize"]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Logon Attempts" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1662:20240416:092034.164 item "SWEBI:perf_counter_en["\APP_POOL_WAS(AquacisGDPR)\Current Application Pool Uptime"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Logon Attempts" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1662:20240416:092034.164 item "SWEBI:perf_counter_en["\PhysicalDisk(1 D:)\Avg. Disk sec/Write",60]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Logon Attempts" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1662:20240416:092034.164 item "SWEBE:perf_counter_en["\Web Service Cache\File Cache Misses"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Move Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1674:20240416:092034.607 Zabbix agent item "perf_counter_en["\PhysicalDisk(1 H:)\Avg. Disk Write Queue Length",60]" on host "SCOPIASD2" failed: first network error, wait for 15 seconds
        1666:20240416:092035.224 item "SWEBI:perf_counter_en["\HTTP Service Request Queues(PDAPad Server)\CurrentQueueSize"]" became supported
        1666:20240416:092035.224 item "SWEBI:perf_counter_en["\APP_POOL_WAS(ControlPresupuestarioV4)\Current Application Pool Uptime"]" became supported
        1666:20240416:092038.286 item "SWEBI:perf_counter_en["\APP_POOL_WAS(Gestión Documental EMUASA Alfresco)\Current Application Pool State"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total NonAnonymous Users" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1666:20240416:092038.287 item "SWEBI:perf_counter_en["\APP_POOL_WAS(Happy)\Current Application Pool Uptime"]" became supported
        1666:20240416:092038.287 item "SWEBI:perf_counter_en["\APP_POOL_WAS(OctubreWebService)\Current Application Pool Uptime"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total NonAnonymous Users" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1666:20240416:092038.287 item "SWEBE:perf_counter_en["\Web Service(_Total)\CGI Requests/Sec", 60]" became supported
        1664:20240416:092039.305 item "SWEBI:perf_counter_en["\HTTP Service Request Queues(MVC)\CurrentQueueSize"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Not Found Errors" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092039.305 item "SWEBI:perf_counter_en["\APP_POOL_WAS(LabPda)\Current Application Pool State"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Not Found Errors" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1680:20240416:092039.777 resuming Zabbix agent checks on host "SCOPIAS": connection restored
        1674:20240416:092040.722 Zabbix agent item "perf_counter_en["\HTTP Service Request Queues(.NET v4.5)\CurrentQueueSize"]" on host "SFACE" failed: first network error, wait for 15 seconds
        1662:20240416:092041.417 error reason for "SWEBI:perf_counter_en["\HTTP Service Request Queues(TPLEmuasaV3)\CurrentQueueSize"]" changed: No data available.
        1680:20240416:092043.779 Zabbix agent item "perf_counter_en["\PhysicalDisk(9)\Avg. Disk Write Queue Length",60]" on host "SCOPIAS" failed: first network error, wait for 15 seconds
        1680:20240416:092043.781 resuming Zabbix agent checks on host "SCA": connection restored
        1664:20240416:092044.424 item "SWEBI:perf_counter_en["\HTTP Service Request Queues(Alfresco SGD)\CurrentQueueSize"]" became supported
        1664:20240416:092045.466 error reason for "SWEBI:perf_counter_en["\HTTP Service Request Queues(Comagua)\CurrentQueueSize"]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Post Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092045.466 item "SWEBI:perf_counter_en["\APP_POOL_WAS(Prensa Intranet)\Current Application Pool State"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Post Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092045.466 item "SWEBI:perf_counter_en["\APP_POOL_WAS(Movidir)\Total Application Pool Recycles"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Post Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092045.466 item "SWEBE:perf_counter_en["\Paging file(_Total)\% Usage"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Method Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092045.466 item "SWEBE:system.swap.pfree" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Method Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1680:20240416:092047.781 Zabbix agent item "perf_counter_en["\Paging file(_Total)\% Usage"]" on host "SCA" failed: first network error, wait for 15 seconds
        1664:20240416:092047.819 item "SWEBI:perf_counter_en["\HTTP Service Request Queues(LanzadorSilverlight)\CurrentQueueSize"]" became supported
        1664:20240416:092048.937 error reason for "SWEBI:perf_counter_en["\HTTP Service Request Queues(KPIExports)\CurrentQueueSize"]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Proppatch Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1659:20240416:092049.515 item "SWEBI:perf_counter_en["\APP_POOL_WAS(MVC)\Current Application Pool State"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Proppatch Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1659:20240416:092049.516 item "SWEBE:perf_counter_en["\Web Service(_Total)\Mkcol Requests/Sec", 60]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Search Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1662:20240416:092049.555 error reason for "SWEBI:perf_counter_en["\HTTP Service Request Queues(Indigest)\CurrentQueueSize"]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Bytes Received" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1680:20240416:092049.789 resuming Zabbix agent checks on host "SCOPIASD2": connection restored
        1666:20240416:092051.572 item "SWEBI:perf_counter_en["\APP_POOL_WAS(Alfresco)\Current Application Pool State"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Method Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1659:20240416:092051.643 item "SWEBE:perf_counter_en["\Web Service(_Total)\Search Requests/Sec", 60]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Copy Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092052.141 error reason for "SWEBI:perf_counter_en["\HTTP Service Request Queues(ASP.NET v4.0 Classic)\CurrentQueueSize"]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Bytes Sent" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092052.141 item "SWEBI:perf_counter_en["\APP_POOL_WAS(Alfresco SGD)\Current Application Pool State"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Bytes Sent" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092052.141 item "SWEBI:perf_counter_en["\APP_POOL_WAS(Comagua)\Current Application Pool State"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Bytes Transferred" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092052.269 item "SWEBE:perf_counter_en["\Web Service(_Total)\Options Requests/Sec", 60]" became not supported: Failed to get counter for path "\\Web Service Cache\\Current Metadata Cached" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1659:20240416:092052.760 item "SWEBE:perf_counter_en["\Web Service(_Total)\Post Requests/Sec", 60]" became not supported: Failed to get counter for path "\\Web Service Cache\\URI Cache Flushes" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1662:20240416:092053.792 item "SWEBI:perf_counter_en["\APP_POOL_WAS(LanzadorSilverlight)\Current Application Pool State"]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Copy Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092054.314 item "SWEBI:perf_counter_en["\Web Service(_Total)\Anonymous Users/sec", 60]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Copy Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1664:20240416:092054.314 item "SWEBE:perf_counter_en["\Web Service(_Total)\Propfind Requests/Sec", 60]" became not supported: Failed to get counter for path "\\Web Service Cache\\URI Cache Hits" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1666:20240416:092054.766 error reason for "SWEBI:perf_counter_en["\HTTP Service Request Queues(ASP.NET v4.0)\CurrentQueueSize"]" changed: No data available.
        1666:20240416:092054.766 error reason for "SWEBI:perf_counter_en["\HTTP Service Request Queues(Alfreeco Jfranco)\CurrentQueueSize"]" changed: Failed to get counter for path "\\Web Service(_Total)\\Total Unlock Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1666:20240416:092054.818 item "SWEBI:perf_counter_en["\APP_POOL_WAS(KPIExports)\Current Application Pool State"]" became not supported: Failed to get counter for path "\\Web Service Cache\\Current Files Cached" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1659:20240416:092055.065 item "SWEBI:perf_counter_en["\Web Service(_Total)\Bytes Received/sec", 60]" became not supported: Failed to get counter for path "\\Web Service Cache\\Current Files Cached" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1677:20240416:092055.065 Zabbix agent item "service.info["FlexNet Licensing Service",state]" on host "SCADAETAP" failed: first network error, wait for 15 seconds
        1659:20240416:092055.106 item "SWEBE:perf_counter_en["\Web Service(_Total)\Proppatch Requests/Sec", 60]" became not supported: Failed to get counter for path "\\Web Service(_Total)\\Total Delete Requests" and lang 0: Cannot add counter: El objeto especificado no se encontró en el equipo.
        1680:20240416:092055.411 resuming Zabbix agent checks on host "SFACE": connection restored
        1289:20240416:092055.454 Got signal [signal:15(SIGTERM),sender_pid:1950,sender_uid:0,reason:0]. Exiting ...
        1645:20240416:092055.454 [2] thread stopped [preprocessing worker #2]
        1645:20240416:092055.455 [1] thread stopped [preprocessing worker #1]
        1645:20240416:092055.455 [3] thread stopped [preprocessing worker #3]
        1353:20240416:092055.456 HA manager has been paused
        1677:20240416:092055.457 Zabbix agent item "net.if.in["{2D2F5128-0BF2-4316-86C2-AAD56AC8362D}",dropped]" on host "SSCADAME2" failed: first network error, wait for 15 seconds
        1662:20240416:092055.458 syncing history data in progress...
        1662:20240416:092055.486 syncing history data... 100.000000%
        1662:20240416:092055.486 syncing history data done
        1675:20240416:092056.110 cannot write to IPC socket: Broken pipe
        1675:20240416:092056.110 cannot send data to preprocessing service
        1676:20240416:092056.110 cannot write to IPC socket: Broken pipe
        1676:20240416:092056.110 cannot send data to preprocessing service
        1678:20240416:092056.111 cannot write to IPC socket: Broken pipe
        1678:20240416:092056.111 cannot send data to preprocessing service
        1644:20240416:092056.494 cannot read alert manager service request
        1353:20240416:092056.544 HA manager has been stopped
        1289:20240416:092056.562 syncing trend data...
        1289:20240416:092104.670 slow query: 7.576778 sec, "select itemid from trends_uint where clock>=1713258000 and itemid in (23662,28249,28534,42228,42254,42260,42266,44323,44324,44325,44326,47723,47724,47725,50556,50598,50614,50640,50656,50724,50740,50766,50782,51399,51400,51401,51405,51406,51407,51417,51420,51421,51422,51423,51424,51428,51429,51430,51449,51466,51468,51471,51473,51476,51478,51479,51480,51985,51987,51999,52000,52003,52004,52260,52261,52262,52266,52267,52268,52269,52278,52279,52556,52598,52640,52656,52682,52698,52724,52766,52782,52808,52824,52850,52892,52908,52934,52950,52970,52971,52972,52976,52977,52978,53002,53003,53291,53307,53333,53375,53417,53433,53459,53475,53501,53543,53559,53601,53622,53623,53624,53628,53629,53630,53631,53650,53937,53938,53939,53943,53944,53945,54243,54244,54245,54249,54250,54251,54268,54497,54498,54499,54503,54504,54505,54520,54521,54752,54753,54754,54758,54759,54760,54773,54775,54776,55065,55066,55067,55071,55072,55073,55075,55377,55378,55379,55380,55385,55386,55387,55388,55397,55657,55677,55678,55679,55680,55685,55686,55687,55688,55706,55707,55944,55945,55946,55950,55951,55952,56259,56260,56262,56263,56264,56265,56270,56271,56272,56273,56287,56288,56529,56530,56531,56535,56536,56537,56551,56552,56553,56783,56784,56785,56789,56790,56791,56796,56797,56798,57092,57093,57094,57098,57099,57100,57427,58819,58903,58945,58963,58964,58965,58970,60213,60914,63469,63554,63555,63556,63557,63558,63559,63560,63561,63562,63563,63564,63565,63566,63569,63570,63571,63572,63573,63574,63575,63576,63577,63578,63579,63636,63637,63638,63674,63676,63677,63679,63682,63683,63734,63735,63736,63737,63738,63739,63741,63742,63743,63744,63745,63746,63747,63748,63749,63750,63751,63752,63753,63754,63755,63756,63757,63758,63759,63760,63761,63762,63763,63764,63765,63766,63767,63768,63769,63874,63877,63878,63879,64109,64110,64115,64116,64119,64120,64122,64135,64139,64140,64158,64165,64169,64170,64175,64179,64180,64181,64183,64242,68568,69042,69097,69258,69275,70793,70794,70795,70799,70800,70801,71759,71824,71825,71826,72212,72213,72214,72218,72219,72220,72334,72336,75607,75667,75668,76053,76054,76055,76059,76060,76061,76097,76100,76153,76156,76222,76223,76224,76228,76229,76230,76635,76636,76637,76641,76642,76643,76665,76666,76667,76701,76702,77117,77120,77201,77202,77203,77207,77208,77209,77599,77600,77602,77603,77605,77606,77607,77903,78220,78222,78548,78551,79179,79236,79237,79403,79404,79405,79408,79410,79411,79413,79416,79417,79454,79455,79456,79459,79460,79461,79462,79463,79464,79465,79466,79467,79468,79469,79470,79471,79473,79474,79475,79476,79477,79478,79479,79480,79481,79482,79483,79484,79485,79486,79487,79488,79489,79515,79516,79517,79518,79591,79599,79600,79610,79635,79636,79721,79722,79723,79724,79727,79728,79729,79730,79754,79755,79756,79757,79758,79759,79760,79761,79762,79763,79764,79765,79766,79767,79768,79769,79770,79771,79772,79773,79774,79775,79776,79777,79778,79779,79780,79781,79782,79846,79847,79848,79849,80369,80370,80376,80378,80379,80381,80386,80387,80415,80416,80417,80418,80421,80422,80423,80424,80425,80426,80427,80428,80429,80430,80431,80432,80433,80435,80436,80437,80438,80439,80440,80441,80442,80443,80444,80445,80446,80447,80448,80449,80475,80476,80477,80478,80600,80601,80602,80607,80609,80610,80612,80617,80618,80661,80662,80663,80664,80666,80668,80669,80670,80671,80672,80673,80674,80675,80676,80677,80678,80679,80680,80682,80683,80684,80685,80686,80687,80688,80689,80714,80715,80716,80717,80718,80719,80720,80729,80738,80739,80747,80748,80775,80776,80778,80783,80784,80797,80798,80834,80835,80836,80837,80838,80839,80840,80841,80842,80843,80844,80845,80846,80847,80848,80849,80850,80851,80852,80853,80854,80855,80856,80857,80858,80859,80860,80861,80862,80863,80864,80865,80866,80867,80868,80869,80899,80900,80901,80906,80908,80909,80911,80916,80917,80954,80955,80957,80958,80959,80960,80961,80962,80963,80964,80965,80966,80967,80968,80969,80970,80971,80972,80973,80974,80975,80976,80977,80978,80979,80980,80981,80982,80983,80984,80985,80986,80987,80988,80989,81019,81020,81021,81026,81028,81029,81031,81036,81037,81078,81079,81080,81083,81084,81085,81086,81087,81088,81089,81090,81091,81092,81094,81095,81096,81097,81098,81099,81100,81101,81102,81103,81104,81105,81106,81107,81108,81109,81142,81445,81453,81454,81464,81504,81505,81506,81507,81554,81555,81556,81557,81558,81559,81560,81561,81562,81563,81564,81565,81566,81567,81568,81569,81570,81571,81572,81573,81574,81575,81576,81577,81578,81579,81580,81581,81582,81583,81584,81585,81586,81587,81588,81589,81615,81623,81624,81625,81630,81632,81633,81635,81640,81641,81684,81685,81686,81689,81690,81691,81692,81693,81694,81695,81696,81697,81698,81700,81701,81702,81703,81704,81705,81706,81707,81708,81709,81734,81735,81736,81737,81738,81739,81740,81741,81742,82483,82491,82517,82519,82520,82522,82527,82528,82542,82543,82544,82545,82701,82702,82703,82704,82707,82708,82709,82710,82711,82712,82713,82714,82715,82716,82717,82718,82719,82721,82722,82723,82724,82725,82726,82727,82728,82729,82754,82755,82756,82757,82758,82759,82760,85026,85027,85329,85333,85334,85335,85336,85337,85338,85663,85667,85668,85669,85673,85674,85675,85676,85677,85678,85679,85680,85681,85682,85683,85684,85688,85689,85690,85691,85692,85696,85700,85704,85708,85712,85716,85720,85724,85728,85732,85736,85740,85744,85748,85752,85809,85810,85811,85812,85813,85814,85815,85816,85817,85818,85819,85820,85821,85822,85824,85825,85826,85827,85828,85829,85830,85831,85832,85833,85834,85835,85836,85837,85838,85839,85840,85841,85842,85843,85845,85846,85847,85848,85849,85850,85851,85852,85853,85854,85855,85856,85857,85858,85859,85860,85861,85862,85863,85864,85865,85866,85867,85868,85869,85870,85871,85872,85873,85874,85876,85877,85878,85879,85880,85881,85882,85883,85884,85885,85886,85887,85888,85889,85890,85892,85893,85894,85895,85896,85897,85898,85899,85900,85901,85902,85903,85904,86235,86243,86244,86245,86250,86252,86253,86255,86260,86261,86317,86354,86355,86356,86357,86358,86359,86360,86361,86362,86363,86364,86365,86366,86367,86368,86369,86370,86371,86372,86373,86374,86375,86376,86377,86378,86379,86380)"
        1289:20240416:092109.499 slow query: 4.512592 sec, "select itemid from trends_uint where clock>=1713258000 and itemid in (86381,86382,86383,86384,86385,86386,86387,86388,86616,86624,86625,86655,86660,86661,86673,86681,86682,86717,86718,86730,86738,86739,86749,86774,86775,86787,86795,86796,86806,86846,86847,86848,86849,86861,86862,86863,86864,86918,86994,87030,87075,87076,87077,87078,87079,87082,87083,87084,87085,87086,87087,87088,87089,87090,87091,87092,87093,87094,87095,87096,87097,87098,87099,87100,87101,87102,87103,87104,87105,87106,87107,87108,87109,87134,87135,87136,87137,87138,87139,87140,87141,87142,87143,87144,87145,87146,87147,87148,87149,87207,87215,87216,87226,87264,87272,87273,87283,87321,87322,87323,87324,87326,87328,87329,87330,87331,87332,87333,87334,87335,87336,87337,87338,87339,87340,87341,87342,87343,87344,87345,87346,87347,87348,87349,87374,87375,87376,87377,87380,87381,87382,87383,87384,87385,87386,87387,87388,87389,87390,87391,87392,87393,87394,87395,87396,87397,87398,87399,87400,87401,87402,87403,87404,87405,87406,87407,87408,87409,87447,87448,87449,87452,87453,87454,87455,87456,87457,87458,87459,87460,87461,87462,87463,87464,87465,87466,87467,87468,87469,87494,87495,87496,87497,87505,87506,87516,87524,87525,87526,87633,87641,87642,87677,87678,87690,87698,87699,87709,87734,87735,87794,87795,87796,87809,87810,87811,87812,87813,87814,87827,87828,87829,87830,87884,87885,87886,87887,87974,87977,87978,87979,87980,87981,87982,87983,87984,87985,87986,87987,87988,87989,87990,87991,87992,87993,87994,87995,87996,87997,87998,87999,88000,88001,88002,88003,88004,88005,88006,88007,88008,88009,88010,88094,88095,88096,88097,88098,88099,88100,88101,88102,88103,88104,88105,88106,88107,88108,88109,88110,88111,88112,88113,88114,88115,88116,88117,88118,88119,88120,88121,88122,88123,88124,88154,88155,88156,88157,88158,88160,88161,88162,88163,88164,88165,88166,88167,88168,88169,88170,88171,88172,88173,88174,88175,88176,88178,88179,88180,88181,88182,88183,88184,88185,88186,88187,88188,88189,88190,88214,88215,88216,88217,88218,88219,88220,88221,88222,88223,88224,88225,88226,88227,88228,88229,88230,88231,88232,88233,88234,88235,88236,88237,88238,88239,88240,88241,88242,88243,88244,88245,88246,88247,88248,88249,88250,88334,88335,88336,88337,88338,88339,88340,88341,88342,88343,88344,88345,88346,88347,88348,88349,88350,88351,88352,88353,88354,88355,88356,88357,88358,88359,88360,88361,88362,88363,88364,88365,88366,88367,88368,88369,88370,88422,88542,88645,89060,89068,89069,89070,89075,89077,89078,89080,89085,89086,89117,89125,89126,89127,89132,89134,89135,89137,89142,89143,89174,89182,89183,89184,89189,89191,89192,89194,89199,89200,89239,89240,89241,89246,89248,89249,89251,89256,89257,89269,89296,89297,89298,89303,89305,89306,89308,89313,89314,89440,89441,89442,89443,89444,89445,89446,89447,89449,89450,89474,89475,89476,89477,89478,89479,89480,89481,89482,89483,89484,89485,89486,89487,89488,89489,89490,89491,89492,89493,89494,89495,89496,89497,89498,89499,89500,89501,89502,89503,89504,89505,89506,89507,89508,89509,89510,89535,89536,89537,89538,89539,89540,89541,89542,89544,89545,89546,89547,89550,89551,89552,89553,89554,89555,89556,89559,89560,89561,89562,89563,89564,89565,89566,89567,89568,89569,89570,89594,89595,89596,89597,89598,89599,89600,89601,89602,89603,89604,89605,89606,89607,89608,89609,89610,89611,89612,89613,89614,89615,89616,89617,89618,89619,89620,89621,89623,89624,89625,89626,89629,89630,89654,89655,89656,89657,89658,89659,89660,89661,89662,89663,89664,89665,89666,89667,89668,89669,89670,89671,89672,89673,89674,89675,89676,89677,89678,89679,89680,89681,89682,89683,89684,89685,89686,89687,89688,89689,89690,89716,89717,89718,89719,89720,89721,89722,89723,89724,89725,89726,89727,89728,89729,89730,89731,89732,89733,89734,89735,89736,89737,89738,89739,89740,89741,89742,89743,89744,89745,89746,89747,89748,89749,89750,89774,89775,89776,89777,89778,89779,89780,89781,89782,89783,89784,89786,89787,89788,89789,89790,89793,89794,89795,89796,89798,89799,89800,89801,89802,89803,89804,89805,89806,89807,89808,89809,89810,89834,89835,89836,89837,89838,89839,89840,89841,89842,89843,89844,89845,89846,89847,89848,89849,89850,89851,89852,89853,89854,89855,89856,89857,89858,89859,89860,89861,89894,89895,89896,89897,89918,89919,89920,89921,89980,89981,89982,89983,90020,90021,90022,90023,90255,90263,90264,90265,90270,90272,90273,90275,90280,90281,90333,90335,90336,90337,90339,90341,90342,90343,90344,90345,90346,90347,90348,90349,90374,90375,90376,90377,90378,90379,90380,90381,90382,90383,90384,90385,90386,90387,90388,90389,90390,90391,90392,90393,90394,90395,90396,90397,90398,90399,90400,90401,90402,90403,90404,90405,90406,90407,90452,90465,90473,90494,90499,90501,90502,90504,90509,90510,90554,90556,90557,90558,90560,90561,90563,90564,90565,90566,90567,90568,90569,90570,90571,90572,90573,90574,90575,90576,90577,90578,90579,90580,90581,90582,90583,90584,90585,90586,90587,90588,90589,90614,90615,90616,90617,90618,90619,90620,90621,90622,90623,90624,90625,90626,90702,90703,90704,90705,91243,91244,91294,91295,91296,91297,91298,91299,91300,91301,91302,91303,91304,91305,91306,91307,91308,91309,91310,91311,91312,91313,91314,91315,91316,91317,91318,91319,91320,91321,91322,91323,91324,91325,91326,91327,91328,91329,91330,91331,91332,91333,91334,91335,91336,91337,91338,91339,91340,91341,91342,91343,91348,91349,91350,91351,91356,91362,91363,91364,91365,91370,91376,91377,91378,91379,91384,91390,91391,91392,91393,91398,91424,91425,91426,91427,91428,91429,91430,91431,91432,91433,91434,91435,91436,91437,91438,91439,91440,91441,91442,91443,91444,91447,91448,91450,91451,91734,91864,91994,92124,93676,93818,93991,93993,94051,94069,94112,94114,94156,94158,94159,94171,94173,94174,94178,94183,94186,94187,94188,94189,94190,94191,94193,94198,94201,94202,94203,94204,94205,94206,94208,94213,94216,94217,94218,94219,94220,94221,94334,94342,94343,94347,94350,94351,94352,94355,94357,94358,94360,94363,94364,94402,94403,94404,94405,94406,94407,94408,94409,94410,94411,94412,94413,94414,94415,94416,94417,94418,94419,94420,94421,94422,94423,94424,94425,94426)"
        1289:20240416:092109.846 syncing trend data done
        1289:20240416:092109.887 Zabbix Server stopped. Zabbix 6.4.11 (revision fb6439a26e3).
      • jros
        • Mar 2023
        • 16
        When I restart service using "systemctl restart zabbix-server.service" I can find it on journalctl:
        abr 17 06:32:20 SZabbix sudo[7609]: administrador : TTY=pts/0 ; PWD=/home/administrador ; USER=root ; COMMAND=/usr/bin/systemctl restart zabbix-server.service
        abr 17 06:32:20 SZabbix sudo[7609]: pam_unix(sudo:session): session opened for user root(uid=0) by administrador(uid=1000)
        abr 17 06:32:20 SZabbix systemd[1]: Stopping zabbix-server.service - LSB: Start zabbix-server daemon...
        ░░ Subject: A stop job for unit zabbix-server.service has begun execution
        ░░ Defined-By: systemd
        ░░ Support: http://www.ubuntu.com/support
        ░░ A stop job for unit zabbix-server.service has begun execution.
        ░░ The job identifier is 8750.
        abr 17 06:32:20 SZabbix systemd[1]: zabbix-server.service: Deactivated successfully.
        ░░ Subject: Unit succeeded
        ░░ The unit zabbix-server.service has successfully entered the 'dead' state.
        abr 17 06:32:20 SZabbix systemd[1]: Stopped zabbix-server.service - LSB: Start zabbix-server daemon.
        ░░ Subject: A stop job for unit zabbix-server.service has finished
        ░░ A stop job for unit zabbix-server.service has finished.
        ░░ The job identifier is 8750 and the job result is done.
        abr 17 06:32:20 SZabbix systemd[1]: Starting zabbix-server.service - LSB: Start zabbix-server daemon...
        ░░ Subject: A start job for unit zabbix-server.service has begun execution
        ░░ A start job for unit zabbix-server.service has begun execution.
        abr 17 06:32:20 SZabbix systemd[1]: Started zabbix-server.service - LSB: Start zabbix-server daemon.
        ░░ Subject: A start job for unit zabbix-server.service has finished successfully
        ░░ A start job for unit zabbix-server.service has finished successfully.
        abr 17 06:32:20 SZabbix sudo[7609]: pam_unix(sudo:session): session closed for user root
        • jros
          • Mar 2023
          • 16
          I have been able to appreciate that zabbix-server don't write on the log file, the content of log file is not changed from I stoped services to upgrade packages, dont change when restart service ... Is strange ...
          Perhaps problem with file permissions??
          administrador@SZabbix:~$ ll /var/log/zabbix
          total 362480
          drwxr-xr-x  2 zabbix zabbix      4096 abr 16 14:31 ./
          drwxrwxr-x 15 root   syslog      4096 abr 17 00:00 ../
          -rw-r-----  1 zabbix zabbix     14690 abr 16 15:03 zabbix_agentd.log
          -rw-r-----  1 zabbix zabbix     13597 abr 13 06:54 zabbix_agentd.log.1
          -rw-r-----  1 zabbix zabbix       448 jul 31  2023 zabbix_agentd.log.10.gz
          -rw-r-----  1 zabbix zabbix       107 jun 19  2023 zabbix_agentd.log.11.gz
          -rw-r-----  1 zabbix zabbix       539 jun  6  2023 zabbix_agentd.log.12.gz
          -rw-r-----  1 zabbix zabbix       697 abr  6 10:47 zabbix_agentd.log.2.gz
          -rw-r-----  1 zabbix zabbix       691 abr  5 11:11 zabbix_agentd.log.3.gz
          -rw-r-----  1 zabbix zabbix      1068 feb  5 11:29 zabbix_agentd.log.4.gz
          -rw-r-----  1 zabbix zabbix       997 feb  2 12:26 zabbix_agentd.log.5.gz
          -rw-r-----  1 zabbix zabbix       405 ene 30 08:59 zabbix_agentd.log.6.gz
          -rw-r-----  1 zabbix zabbix       405 ago 28  2023 zabbix_agentd.log.7.gz
          -rw-r-----  1 zabbix zabbix      8828 ago 11  2023 zabbix_agentd.log.8.gz
          -rw-r-----  1 zabbix zabbix       576 ago  9  2023 zabbix_agentd.log.9.gz
          -rw-r-----  1 zabbix zabbix  92313057 abr 16 09:21 zabbix_server.log
          -rw-r-----  1 zabbix zabbix 214502027 abr 14 00:00 zabbix_server.log.1
          -rw-r-----  1 zabbix zabbix    988507 feb 10 23:59 zabbix_server.log.10.gz
          -rw-r-----  1 zabbix zabbix   1517721 feb  3 23:59 zabbix_server.log.11.gz
          -rw-r-----  1 zabbix zabbix   1960212 ago 31  2023 zabbix_server.log.12.gz
          -rw-r-----  1 zabbix zabbix  10973096 abr  6 23:59 zabbix_server.log.2.gz
          -rw-r-----  1 zabbix zabbix  12572639 mar 31 00:00 zabbix_server.log.3.gz
          -rw-r-----  1 zabbix zabbix  12079698 mar 24 00:00 zabbix_server.log.4.gz
          -rw-r-----  1 zabbix zabbix  11732035 mar 17 00:00 zabbix_server.log.5.gz
          -rw-r-----  1 zabbix zabbix   8830238 mar 10 00:00 zabbix_server.log.6.gz
          -rw-r-----  1 zabbix zabbix   1321805 mar  2 23:59 zabbix_server.log.7.gz
          -rw-r-----  1 zabbix zabbix   1310103 feb 25 00:00 zabbix_server.log.8.gz
          -rw-r-----  1 zabbix zabbix    953146 feb 18 00:00 zabbix_server.log.9.gz
          • jros
            • Mar 2023
            • 16
            I think that perhaps If I execute zabbix_server binary manually I can see some error but ... surprise!! I can found zabbix_server binary ...
            I'm starting to think that zabbix_server is not present ...
            • jros
              • Mar 2023
              • 16
              # apt update
              Solved!!
