Need help on windows Zabbix_get
  • jaipsharma
    • Dec 2012
    • 18
    I require assistance with the Windows version of Zabbix_get. When I execute the command below in Command Prompt:
    zabbix_get -s 127.0.0.1 -p 10050 -k agent.version
    I encounter the following error message:
    zabbix_get [4112]: Get value error: ZBX_TCP_READ() failed: [0x00002746] An existing connection was forcibly closed by the remote host. zabbix_get [4112]: Check access restrictions in Zabbix agent configuration
    Interestingly, I am able to establish a Telnet connection to the Zabbix server on port 10050 from the client host where the agent is running. Any assistance would be greatly appreciated.
    • 4996
    Server setting in agent config probably has only your server/proxy address, if you add localhost (127.0.0.1) there, it most probably allows you to connect locally ...
