Connecting to Zabbix problem
  • knguy7
    • Nov 2016
    I'm new to Zabbix hoping someone could help. Getting error message when connecting to Zabbix via ipaddress/zabbix/ screen is stuck showing error connecting to database:Access denied for user 'XXX'@'localhost (using password: YES) I have drop and re-create user for mysql, checked /etc/zabbix/zabbix_server.conf everything is configured properly, restarted httpd, firewall, and etc... Originally i was able to accessed webpage but sign in as guest. After create admin account webpage seem to be frozen with the pink box and error message displaying. My last option is to rebuild Zabbix again. Please shed some lights. thanks ahead!!!
  • Atsushi
    • Aug 2013
    • 2028
    Please check /etc/zabbix/web/zabbix.conf.php for the database connection setting of the Web frontend.
    • knguy7
      • Nov 2016
      Do you have an example what it should look like for /etc/zabbix/web/zabbix.conf.php?
      • Atsushi
        • Aug 2013
        • 2028
        Samples are as follows.
        <?php
        // Zabbix GUI configuration file.
        global $DB;
        $DB['TYPE']     = 'MYSQL';
        $DB['SERVER']   = 'localhost';
        $DB['PORT']     = '0';
        $DB['DATABASE'] = 'zabbix';
        $DB['USER']     = 'zabbix';
        $DB['PASSWORD'] = 'password';
        // Schema name. Used for IBM DB2 and PostgreSQL.
        $DB['SCHEMA'] = '';
        $ZBX_SERVER      = 'localhost';
        $ZBX_SERVER_PORT = '10051';
        $ZBX_SERVER_NAME = '';
        $IMAGE_FORMAT_DEFAULT = IMAGE_FORMAT_PNG;
