I'm monitoring mac OSX servers successfully via passive checks of Zabbix using the default template.
However, the question comes from upper to monitor a particular log file (/usr/local/aw/lexxsrv.log)
I've create the extra active item via a extra template (so far so good)
However, in the latest data tab, I'm waiting patiently to get me some logs, i don't get any error or warning.
I'm successfully using active checks on centos 7 and Windows.
I've checked the conf file and active server with the correct hostname (=same as web interface).
i've used some debugging and the proxy does get the active check.
On the client however, I'm getting this error:
56856:20161115:182907.815 active check configuration update from [192.168.10.44:10051] started to fail (ZBX_TCP_READ() failed: [54] Connection reset by peer)
with tcpdump at the same time on the proxy:
9078, win 28960, options [mss 1460,sackOK,TS val 182494162 ecr 1224623682,nop,wscale 7], length 0
0x0000: 406c 8fb8 63e8 0800 2748 a891 0800 4500 @l..c...'H....E.
0x0010: 003c 0000 4000 4006 a53e c0a8 0a2c c0a8 .<..@.@..>...,..
0x0020: 0a01 2743 ca38 1e7a aa81 9842 1ad6 a012 ..'C.8.z...B....
0x0030: 7120 95ac 0000 0204 05b4 0402 080a 0ae0 q...............
0x0040: a3d2 48fe 4642 0103 0307 ..H.FB....
19:48:42.128793 IP zabbix.local.zabbix-trapper > fileserver.51768: Flags [.], ack 77, win 227, options [nop,nop,TS val 182494162 ecr 1224623683], length 0
0x0010: 0034 0950 4000 4006 9bf6 c0a8 0a2c c0a8 .4.P@.@......,..
0x0020: 0a01 2743 ca38 1e7a aa82 9842 1b22 8010 ..'C.8.z...B."..
0x0030: 00e3 95a4 0000 0101 080a 0ae0 a3d2 48fe ..............H.
0x0040: 4643 FC
19:48:42.164707 IP zabbix.local.zabbix-trapper > fileserver.51768: Flags [R.], seq 1, ack 77, win 227, options [nop,nop,TS val 0 ecr 1224623683], length 0
0x0010: 0034 0951 4000 4006 9bf5 c0a8 0a2c c0a8 .4.Q@.@......,..
0x0020: 0a01 2743 ca38 1e7a aa82 9842 1b22 8014 ..'C.8.z...B."..
0x0030: 00e3 95a4 0000 0101 080a 0000 0000 48fe ..............H.
0x0040: 4643 FC
Config file of the mac osx server:
### Option: ServerActive
# List of comma delimited IP
ort (or hostname
ort) pairs of Zabbix servers for active checks.
# If port is not specified, default port is used.
# IPv6 addresses must be enclosed in square brackets if port for that host is specified.
# If port is not specified, square brackets for IPv6 addresses are optional.
# If this parameter is not specified, active checks are disabled.
# Example: ServerActive=127.0.0.1:20051,zabbix.domain,[::1]:30051,::1,[12fc::1]
# Mandatory: no
# Default:
# ServerActive=
ServerActive=192.168.10.44
### Option: Hostname
# Unique, case sensitive hostname.
# Required for active checks and must match hostname as configured on the server.
# Value is acquired from HostnameItem if undefined.
# Mandatory: no
# Default:
# Hostname=
Hostname=fileserver
The fileserver is being monitored as follow:
Zabbix Server --> Zabbix Active Proxy --> fileserver (passive and active)
what else can i do to debug?
0x0040: 4643 FC
0x0040: 4643 FC
ort (or hostname
ort) pairs of Zabbix servers for active checks.# If port is not specified, default port is used.
# Mandatory: no
# Default:
# ServerActive=
# Mandatory: no
# Default:
# Hostname=
Hostname=fileserver
