GCP Instance Montoring
  • bdobson
    • Feb 2024
    • 19
    Zabbix Version: 6.4.14
    I am trying to set up monitoring of our GCP project and am running across an error that I can so far find no way around in the documentation. Hopefully, I have not missed something.
    Some checks are working so I know that I have the proper key, project id, and other information. However, when it tries to pull in instances I get the error:
    HTML Code:
    Failed: Required field "shieldedInstanceConfig.enableIntegrityMonitoring" is not present in data received.
    We do not use shield instances and is there a way to disable this requirement somewhere?
    Thank you
