Value cache memory percent used increase problem between 6.0.18 and 6.0.28
  • yurtesen
    • Aug 2008
    • 130
    I had value cache under 40% normally. I have upgraded from 6.0.18 to 6.0.28 on 12th of April. The value cache usage started increasing.
    Is there others which use 6.0.28 seeing a similar pattern?
    Is there a practical way to check what is using the cache?
    Thanks!
  • yurtesen
    • Aug 2008
    • 130
    I found:
    I will upgrade to 6.0.29 and see if it helps...
    • markosa
      • Aug 2022
      • 107
      Try to update 6.0.29.
      ZBX-24264 Fixed value cache being filled with values of newly added items with triggers
      Maybe that's causing issues.
      • markosa
        • Aug 2022
        • 107
        there's one zbx stating: Fixed value cache being filled with values of newly added items with triggers
