HI all,
I've just finished attempting to upgrade a long-running 1.0 server to 1.1.4. The frontend is in place, all of the patches have been applied in sequence (The last being 1.1beta12_to_1.1) and the server/agents have been compiled and installed. I've created a server config and when I attempt to start the server, I get the following in the logs:
There's a few of those, then:
...until it quits.
As far as I can make out, the 1.1beta5_to_1.1beta6 mysql patch dropped network_errors from the table and nothing since has reinstated it.
The zabbix_server binary version, however, is reporting as 1.1beta2. Is this normal? I've compiled it from a fresh download of the 1.1.4 source, but perhaps the server binary hasn't changed since beta2?
After patching, the hosts table structure is as follows:
Versions:
Config:
031142:20061206:110718 server #9 started [Poller. SNMP:OFF]
031134:20061206:110718 Query::select i.itemid,i.key_,h.host,h.port,i.delay,i.description,i.nextcheck,i.type,i.snmp_community,i.snmp_oid,h.useip,h.ip,i.history,i.lastvalue,i.prevvalue,i.hostid,h.status,i.value_type,h.network_errors,i.snmp_port,i.delta,i.prevorgvalue,i.lastclock,i.units,i.multiplier,i.snmpv3_securityname,i.snmpv3_securitylevel,i.snmpv3_authpassphrase,i.snmpv3_privpassphrase,i.formula,h.available from items i,hosts h where i.nextcheck<=1165403238 and i.status=0 and i.type not in (2,7) and ((h.status=0 and h.available!=2) or (h.status=0 and h.available=2 and h.disable_until<=1165403238)) and h.hostid=i.hostid and i.itemid%6=0 and i.key_ not in ('status','icmpping','icmppingsec','zabbix[log]') order by i.nextcheck
031134:20061206:110718 Query failed:Unknown column 'h.network_errors' in 'field list' [1054]
031140:20061206:110718 Query failed:Unknown column 'h.network_errors' in 'field list' [1054] 031124:20061206:110718 One child process died. Exiting ... 031124:20061206:110718 Got QUIT or INT or TERM or PIPE signal. Exiting...
mysql> show columns from hosts; +---------------+--------------+------+-----+-----------+----------------+ | Field | Type | Null | Key | Default | Extra | +---------------+--------------+------+-----+-----------+----------------+ | hostid | int(4) | | PRI | NULL | auto_increment | | host | varchar(64) | | UNI | | | | useip | int(1) | | | 1 | | | ip | varchar(15) | | | 127.0.0.1 | | | port | int(4) | | | 0 | | | status | int(4) | | MUL | 0 | | | disable_until | int(4) | | | 0 | | | error | varchar(128) | | | | | | available | int(4) | | | 0 | | | errors_from | int(4) | | | 0 | | | templateid | int(4) | | | 0 | | +---------------+--------------+------+-----+-----------+----------------+
Apache/2.0.54 (Debian GNU/Linux) DAV/2 SVN/1.2.3 mod_python/3.1.3 Python/2.3.5 PHP/4.4.0-4 mysql Ver 14.7 Distrib 4.1.14, for pc-linux-gnu (i486) using readline 5.0
Server=1 StartPollers=5 StartTrappers=2 ListenIP=127.0.0.1 ListenPort=10051 HousekeepingFrequency=1 SenderFrequency=30 DebugLevel=3 Timeout=5 UnreachablePeriod=300 UnavailableDelay=15 UnavailableDelay=120 PidFile=/var/run/zabbix/zabbix_server.pid LogFile=/var/log/zabbix/zabbix_server.log AlertScriptsPath=/home/zabbix/bin/ DBHost=localhost DBName=zabbix DBUser=zabbix DBPassword=xxxxxx
