Bandwidth not correct after 1.1.4 upgrade
  • nbakker
    • May 2006
    • 14
    After upgrading to 1.1.4 the bandwidth on a T1 connection (1.5Mbit/s) is registering at up to 2Mbit/s. What has changed in 1.1.4 that could cause this I am using If(In/Out)Octets.IfIndex, Numeric (float), Units bps, Multiplier 8, Delta (speed per second). Earlier graphs (data collected prior to the 1.1.4 upgrade) have changed to showing the speed to be up to 2MBit/s, while these where correct at a maximum of 1.5MBit/s.
  • vrtareg
    • May 2006
    • 293
    Hi
    Please see this thread: http://www.zabbix.com/forum/showthread.php?t=4659
    May be it can help you.
    • nbakker
      • May 2006
      • 14
      Thanks, however I will wait for the official patch....as I understood that the values in the database are correct.
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Yes, the collected values are absolutely correct, it is just wrong representation of the data. Sorry for the issue, it was accidently overlooked while testing 1.1.4.
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
