Zabbix action.update failing post upgrade from 5.4.4 to 6.0.9
  • maries
    • May 2024
    Team,
    We had an ansible playbook which will be update the new email distro's to the existing Zabbix Action Operations using action.update API (version 5.4.4)
    We upgraded Zabbix from 5.4.4 to 6.0.9 and post to that script is failing with the below error
    "json": {
    "error": {
    "code": -32602,
    "data": "Invalid parameter "/1/operations/1": unexpected parameter "operationid".",
    "message": "Invalid params."
    Ansible Playbook Module
    - name: Update action with new user email
    uri:
    url: "{{ zabbix_url }}"
    method: POST
    headers:
    Content-Type: "application/json"
    body:
    "jsonrpc": "2.0",
    "method": "action.update",
    "params": {
    "actionid": "{{ action_id }}",
    "operations": "{{ modified_operations }}"
    "auth": "{{ zabbix_token }}",
    "id": 1
    body_format: json
    status_code: 200
    register: result
    modified_operations => Input Details ​
    TASK [Loop through existing operations] => Current Operations Data
    ok: [localhost] => (item={'operationid': '2247', 'actionid': '291', 'operationtype': '0', 'esc_period': '0', 'esc_step_from': '1', 'esc_step_to': '1', 'evaltype': '0', 'opconditions': [], 'opmessage': {'default_msg': '1', 'subject': '', 'message': '', 'mediatypeid': '0'}, 'opmessage_grp': [], 'opmessage_usr': [{'userid': '225'}]})
    TASK [Display modified_operations] = > Contains the new user ID for the new email
    ok: [localhost] => {
    "msg": [
    "actionid": "291",
    "esc_period": "0",
    "esc_step_from": "1",
    "esc_step_to": "1",
    "evaltype": "0",
    "opconditions": [],
    "operationid": "2247",
    "operationtype": "0",
    "opmessage": {
    "default_msg": "1",
    "mediatypeid": "0",
    "message": "",
    "subject": ""
    "opmessage_grp": [],
    "opmessage_usr": [
    "userid": "225"
    "userid": "274"
    This script was working fine with the version 5.4.4 and getting error for the newer version 6.0.9
