Upgrade zabbix server from 5.4 to 6.4
  • Maissa DRIDI
    • Apr 2023
    • 13
    Recently, I attempted to upgrade the Zabbix server from version 5.4.6 to 6.4 following the documentation provided at https://www.zabbix.com/documentation.../debian_ubuntu
    However, when I ran the command
    apt-get install --only-upgrade zabbix-server-mysql zabbix-frontend-php zabbix-agent
    encountered the following error:
    Some packages could not be installed. This may mean that you have
    requested an impossible situation or if you are using the unstable
    distribution that some required packages have not yet been created
    or been moved out of Incoming.
    The following information may help to resolve the situation:
    The following packages have unmet dependencies:
    zabbix-server-mysql : Depends: libc6 (>= 2.34) but 2.31-0ubuntu9.15 is to be installed
    Depends: libldap-2.5-0 (>= 2.5.4) but it is not installable
    Depends: libodbc2 (>= 2.3.1) but it is not installable
    Depends: libopenipmi0 (>= 2.0.29) but 2.0.27-0ubuntu2 is to be installed
    Depends: libsnmp40 (>= 5.9.1+dfsg) but it is not installable
    Depends: libssl3 (>= 3.0.0~~alpha1) but it is not installable
    E: Unable to correct problems, you have held broken packages.
    I attempted to update and upgrade the server before rerunning the command, but unfortunately, I still received the same error.
    Server : Ubuntu 20.04.3 LTS
    MySQL version : Server version: 10.3.39-MariaDB-0ubuntu0.20.04.2 Ubuntu 20.04
    libssh version : Version: 0.9.3-2ubuntu2.5
    Thank you for your assistance.
