Setting StartDiscoverers in a docker installation of Zabbix
  • Zululander
    • May 2024
    I am getting the below error
    Zabbix server: Utilization of discoverer processes over 75%
    Google searches seam to indicate that I need to set StartDiscovers in the server config file.
    I am however not too show how to do this in a docker install.
  • Markku
    • Sep 2018
    • 1788
    https://www.zabbix.com/documentation...ment-variables says:
    All Zabbix component images provide environment variables to control configuration. Supported environment variables are listed in the component repository.
    These environment variables are options from Zabbix configuration files, but with different naming method. For example, ZBX_LOGSLOWQUERIES is equal to LogSlowQueries from Zabbix server and Zabbix proxy configuration files.
    Markku
