I'v installed zabbix proxy on my RPi3 (OS RASPBIAN JESSIE WITH PIXEL)
zabbix_proxy.conf has been configured
Database are created and schema.sql imported
When i try to start Zabbix-Proxy service i get this:
pi@raspberrypi:/ $ sudo systemctl status zabbix-proxy.service
● zabbix-proxy.service - Zabbix Proxy (MySQL/MariaDB)
Loaded: loaded (/lib/systemd/system/zabbix-proxy.service; disabled)
Active: failed (Result: start-limit) since Tue 2016-11-29 19:46:29 UTC; 4min 42s ago
Docs: man:zabbix_proxy
Process: 5398 ExecStart=/usr/sbin/zabbix_proxy --foreground (code=killed, signal=SEGV)
Main PID: 5398 (code=killed, signal=SEGV)
Nov 29 19:46:28 raspberrypi systemd[1]: zabbix-proxy.service: main process exited, code=killed, status=11/SEGV
Nov 29 19:46:28 raspberrypi systemd[1]: Unit zabbix-proxy.service entered failed state.
Nov 29 19:46:29 raspberrypi systemd[1]: zabbix-proxy.service holdoff time over, scheduling restart.
Nov 29 19:46:29 raspberrypi systemd[1]: Stopping Zabbix Proxy (MySQL/MariaDB)...
Nov 29 19:46:29 raspberrypi systemd[1]: Starting Zabbix Proxy (MySQL/MariaDB)...
Nov 29 19:46:29 raspberrypi systemd[1]: zabbix-proxy.service start request repeated too quickly, refusing to start.
Nov 29 19:46:29 raspberrypi systemd[1]: Failed to start Zabbix Proxy (MySQL/MariaDB).
Nov 29 19:46:29 raspberrypi systemd[1]: Unit zabbix-proxy.service entered failed state.
Anyone can help me?
zabbix_proxy.log is empty
Anyone can help me?
