zabbix-snmptraps container, Can't find module
  • Megaman
    • Jun 2024
    I'm setting up docker on windows with zabbix-snmptraps, however I'm getting an issue as per below, any ideas on how to fix this?
    This is my docker command
    docker run --name zabbix-snmptraps -t -v /zbx_instance/snmptraps:/var/lib/zabbix/snmptraps:rw -v /var/lib/zabbix/mibs:/usr/share/snmp/mibs:ro --network=zabbix-net -p 162:1162/udp --restart unless-stopped  -d zabbix/zabbix-snmptraps:alpine-6.4-latest
    Logs
    /var/lib/zabbix/snmptraps$ /usr/sbin/snmptrapd -n -C -c /etc/snmp/snmptrapd.conf -Lo -A
    MIB search path: /usr/share/snmp/mibs:/var/lib/zabbix/mibs
    Cannot find module (SNMPv2-MIB): At line 0 in (none)
    Cannot find module (IF-MIB): At line 0 in (none)
    Cannot find module (IP-MIB): At line 0 in (none)
    Cannot find module (TCP-MIB): At line 0 in (none)
    Cannot find module (UDP-MIB): At line 0 in (none)
    Cannot find module (HOST-RESOURCES-MIB): At line 0 in (none)
    Cannot find module (NOTIFICATION-LOG-MIB): At line 0 in (none)
    Cannot find module (DISMAN-EVENT-MIB): At line 0 in (none)
    Cannot find module (DISMAN-SCHEDULE-MIB): At line 0 in (none)
    Cannot find module (UCD-SNMP-MIB): At line 0 in (none)
    Cannot find module (UCD-DEMO-MIB): At line 0 in (none)
    Cannot find module (SNMP-TARGET-MIB): At line 0 in (none)
    Cannot find module (NET-SNMP-AGENT-MIB): At line 0 in (none)
    Cannot find module (HOST-RESOURCES-TYPES): At line 0 in (none)
    Cannot find module (SNMP-FRAMEWORK-MIB): At line 0 in (none)
    Cannot find module (SNMP-MPD-MIB): At line 0 in (none)
  • Megaman
    • Jun 2024
    any ideas would be appreciated!
    • Megaman
      • Jun 2024
      • tcweb
        • Jun 2024
        • 57
        I have been desperately searching for answers on docker (on windows) monitoring. I'm not finding much. What have you learned so far? I've been exploring creating my own UserParameter commands and doing LLD. But I'm running into challenges there as well.
        -Tom
        • markfree
          • Apr 2019
          • 875
          You've set up the "-v /var/lib/zabbix/mibs:/usr/share/snmp/mibs:ro" volume and it appears to be empty.
          Since the "snmptrapd" binary can't find those default MIBs, it displays those messages.
          • Megaman
            • Jun 2024
            I did manage to get it working, although I can't remember how unfortunatley.
            I've since switched over to using Zabbix on a RasberryPi, I found if wasn't very reliable in Docker on Windows, the SNMP would constanly not be able to connect to hosts and find the correct OID's.
            RasberryPi has been flawless!
