Zabbix 6.0 API HTTP error 412 ~ Precondition failed
  • Cejay
    • Mar 2024
    • 11
    We are using Zabbix 6.0 And are trying to do an API Call, and get the following error when using the api url
    We have checked the API user permissions and the post request header and it all checks out okay.
    We are using PHP, and Zabbix 6.0.
    I did do a search and didn't come across anything solid, apart from the API User permissions setting which we checked.
    Any help would be appreciated
  • Markku
    • Sep 2018
    • 1788
    What is the error message?
    Markku
    • Cejay
      • Mar 2024
      • 11
      Markku
      See above picture showing the error.
      • Markku
        • Sep 2018
        • 1788
        And can you show the request that you are trying? With all the relevant headers.
        If you are doing the call in a software, can you repeat the same error with a simple curl command?
        Markku
        • Cejay
          • Mar 2024
          • 11
          I've talked to our developer and this is what they are seeing. Please note I have removed some information that we do not want to share
          cURL Error: Recv failure: Connection was reset cURL Error Number: 35 Request Info: Array ( [url] =>
          https://ourzabbix server/zabbix/api_jsonrpc.php
          [content_type] => [http_code] => 0 [header_size] => 0 [request_size] => 0 [filetime] => -1 [ssl_verify_result] => 1 [redirect_count] => 0 [total_time] => 19.25754 [namelookup_time] => 0.001542 [connect_time] => 0.045024 [pretransfer_time] => 0 [size_upload] => 0 [size_download] => 0 [speed_download] => 0 [speed_upload] => 0 [download_content_length] => -1 [upload_content_length] => -1 [starttransfer_time] => 0 [redirect_time] => 0 [redirect_url] => [primary_ip] => x.x.x.x [certinfo] => Array ( ) [primary_port] => x [local_ip] => x.x.x.x [local_port] => x [http_version] => 0 [protocol] => 2 [ssl_verifyresult] => 0 [scheme] => HTTPS [appconnect_time_us] => 0 [connect_time_us] => 45024 [namelookup_time_us] => 1542 [pretransfer_time_us] => 0 [redirect_time_us] => 0 [starttransfer_time_us] => 0 [total_time_us] => 19257540 [effective_method] => POST )
          • Markku
            • Sep 2018
            • 1788
            Umm, ok, you are using some Windows command, not the stardard curl, and you are not giving any command to the API, right. You do realize that you are not yet providing any meaningful input for anyone else to help you with this?
            Markku
