Upgrade zabbix 7 pre-release to 7 LTS
  • rezsfathi
    • Jun 2024
    Hi
    We have zabbix 7 pre-release version in our company and I wanted to upgrade to version 7 LTS . Would you please give me the instrauctions step by step on how to upgrade?
    Thanks.
  • kbuska
    • Dec 2023
    Check out https://www.zabbix.com/documentation...lation/upgrade
      • 5004
      Update your repos, so they would point to 7.0 not 6.5 any more. Then just update packages...
      • vegushka
        • Feb 2023
        Same errors for update from 7.0.0.beta3 to 7.0
        Error:
         Problem 1: cannot install the best update candidate for package fping-5.1-1.el8.x86_64
          - nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by fping-5.1-1.el9.x86_64 from zabbix-non-supported
         Problem 2: cannot install the best update candidate for package zabbix-agent-7.0.0-beta3.release1.el8.x86_64
          - nothing provides libldap.so.2()(64bit) needed by zabbix-agent-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libcrypto.so.3()(64bit) needed by zabbix-agent-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by zabbix-agent-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libldap.so.2(OPENLDAP_2.200)(64bit) needed by zabbix-agent-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides liblber.so.2()(64bit) needed by zabbix-agent-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by zabbix-agent-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides liblber.so.2(OPENLDAP_2.200)(64bit) needed by zabbix-agent-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libssl.so.3()(64bit) needed by zabbix-agent-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libssl.so.3(OPENSSL_3.0.0)(64bit) needed by zabbix-agent-7.0.0-release1.el9.x86_64 from zabbix
         Problem 3: cannot install the best update candidate for package zabbix-get-7.0.0-beta3.release1.el8.x86_64
          - nothing provides libcrypto.so.3()(64bit) needed by zabbix-get-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by zabbix-get-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by zabbix-get-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libssl.so.3()(64bit) needed by zabbix-get-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libssl.so.3(OPENSSL_3.0.0)(64bit) needed by zabbix-get-7.0.0-release1.el9.x86_64 from zabbix
         Problem 4: cannot install the best update candidate for package zabbix-sender-7.0.0-beta3.release1.el8.x86_64
          - nothing provides libcrypto.so.3()(64bit) needed by zabbix-sender-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by zabbix-sender-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by zabbix-sender-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libssl.so.3()(64bit) needed by zabbix-sender-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libssl.so.3(OPENSSL_3.0.0)(64bit) needed by zabbix-sender-7.0.0-release1.el9.x86_64 from zabbix
         Problem 5: cannot install the best update candidate for package zabbix-server-mysql-7.0.0-beta3.release1.el8.x86_64
          - nothing provides libldap.so.2()(64bit) needed by zabbix-server-mysql-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libcrypto.so.3()(64bit) needed by zabbix-server-mysql-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by zabbix-server-mysql-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libldap.so.2(OPENLDAP_2.200)(64bit) needed by zabbix-server-mysql-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides liblber.so.2()(64bit) needed by zabbix-server-mysql-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by zabbix-server-mysql-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides liblber.so.2(OPENLDAP_2.200)(64bit) needed by zabbix-server-mysql-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libssl.so.3()(64bit) needed by zabbix-server-mysql-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libssl.so.3(OPENSSL_3.0.0)(64bit) needed by zabbix-server-mysql-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libm.so.6(GLIBC_2.29)(64bit) needed by zabbix-server-mysql-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libevent-2.1.so.7()(64bit) needed by zabbix-server-mysql-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libevent_pthreads-2.1.so.7()(64bit) needed by zabbix-server-mysql-7.0.0-release1.el9.x86_64 from zabbix
          - nothing provides libnetsnmp.so.40()(64bit) needed by zabbix-server-mysql-7.0.0-release1.el9.x86_64 from zabbix
        (try to add '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
        • tim.mooney
          • Dec 2012
          • 1437
          Originally posted by vegushka
          Error:
          Look carefully at what the message is telling you.
          You have fping 5.1 for RHEL 8 (note the .el8. in the package name) installed, but you're trying to apply updates for RHEL 9 (note the .el9. in the "nothing provides" error message).
          You need to point the system at the repo for the correct version of your OS.
          • vegushka
            • Feb 2023
            I don't like AlmaLinux. I installed the latest Zabbix on Ubuntu and transferred the database. Everything is working.
