Zabbix 3.2 problem configuring DB connection
  • mmulligan
    • Dec 2016
    Installing on Debian 8.x.x Jessie, third step "configure DB connection" fail .
    "Unable to Select configuration"
    Previous steps were Ok.
    There exists zabbix user and zabbix password and all permissions on zabbix DB.
    Anyone can help me.
    Thanks.
  • LenR
    • Sep 2009
    • 1011
    Have you loaded the initial data into the database?
    These steps https://www.zabbix.com/documentation...all/db_scripts
    But when I installed 3.2, it seemed the 3 zabbix < xxxx.sql steps were replaced with unzipping a single create.sql file and loading it.
    • Atsushi
      • Aug 2013
      • 2028
      Can not select database type?
      If so, try installing PHP's DB access module according to your database.
      ex. php5-mysqlnd or php5-pgsql
