After Upgrading from 5.0 to 6.0 crashing server
  • M-Schmitt
    • Jun 2024
    Good Day,
    after succesfully upgrading zabbix from 5.0 to 6.0, the server is crashing.
    In short on the upgrade:
    - Was a hellish task
    - Had to delete/create/etc. a lot on Tables/Columns/etc...
    In short to the Error/Crash:
    - After the upgrade was succesfully finished the Server crashed and is not reachable.
    I don't find the problem or something which leads to it, help is much appreciated.
    If Information is needed, i am happy to provide it.
    Thanks a lot!!
    The Error log from the Zabbix-Server:
    ** Preparing Zabbix server
    ** Preparing database
    ** Using MYSQL_USER variable from secret file
    ** Using MYSQL_PASSWORD variable from secret file
    * DB_SERVER_HOST: mysql-server
    * DB_SERVER_PORT: Numbers
    * DB_SERVER_DBNAME: zabbix
    ** Database 'zabbix' already exists. Please be careful with database COLLATE!
    ** Table 'zabbix.dbversion' already exists.
    ** Preparing Zabbix server configuration file
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ListenIP": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ListenPort": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ListenBacklog": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "SourceIP": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "LogType": 'console'...updated
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "LogFile": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "LogFileSize": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "PidFile": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DebugLevel": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBHost": 'mysql-server'...updated
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBPort": '3306'...updated
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBSocket": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBName": 'zabbix'...updated
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBSchema": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "VaultDBPath": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "VaultURL": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBUser": 'zabbix'...updated
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBPassword": '****'. Enable DEBUG_MODE to view value ...updated
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "AllowUnsupportedDBVersions": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartReportWriters": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "WebServiceURL": 'http://zabbix-web-service:10053/report'...updated
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HistoryStorageURL": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HistoryStorageTypes": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HistoryStorageDateIndex": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StatsAllowedIP": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartPollers": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartIPMIPollers": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartPollersUnreachable": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartTrappers": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartPingers": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartDiscoverers": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartHistoryPollers": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartHTTPPollers": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartODBCPollers": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartPreprocessors": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartTimers": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartEscalators": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartAlerters": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartLLDProcessors": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "JavaGateway": 'zabbix-java-gateway'...updated
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "JavaGatewayPort": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartJavaPollers": '5'...updated
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartVMwareCollectors": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "VMwareFrequency": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "VMwarePerfFrequency": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "VMwareCacheSize": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "VMwareTimeout": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "SNMPTrapperFile": '/var/lib/zabbix/snmptraps/snmptraps.log'...updated
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartSNMPTrapper": '1'...updated
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HousekeepingFrequency": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "MaxHousekeeperDelete": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ProblemHousekeepingFrequency": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "CacheSize": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "CacheUpdateFrequency": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartDBSyncers": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HistoryCacheSize": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HistoryIndexCacheSize": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TrendCacheSize": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TrendFunctionCacheSize": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ValueCacheSize": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "Timeout": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TrapperTimeout": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "UnreachablePeriod": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "UnavailableDelay": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "UnreachableDelay": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "AlertScriptsPath": '/usr/lib/zabbix/alertscripts'...updated
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ExternalScripts": '/usr/lib/zabbix/externalscripts'...updated
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "FpingLocation": '/usr/bin/fping'...updated
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "Fping6Location": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "SSHKeyLocation": '/var/lib/zabbix/ssh_keys'...updated
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "LogSlowQueries": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartProxyPollers": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ProxyConfigFrequency": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ProxyDataFrequency": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "SSLCertLocation": '/var/lib/zabbix/ssl/certs/'...updated
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "SSLKeyLocation": '/var/lib/zabbix/ssl/keys/'...updated
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "SSLCALocation": '/var/lib/zabbix/ssl/ssl_ca/'...updated
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "LoadModulePath": '/var/lib/zabbix/modules/'...updated
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCAFile": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCRLFile": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCertFile": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCipherAll": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCipherAll13": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCipherCert": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCipherCert13": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCipherPSK": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCipherPSK13": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSKeyFile": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSPSKIdentity": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSPSKFile": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ServiceManagerSyncFrequency": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HANodeName": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "NodeAddress": ''...removed
    ** Updating '/etc/zabbix/zabbix_server.conf' parameter "User": 'zabbix'...updated
    Starting Zabbix Server. Zabbix 6.0.30 (revision 680df72).
    Press Ctrl+C to exit.
    7:20240610:140552.084 Starting Zabbix Server. Zabbix 6.0.30 (revision 680df72).
    7:20240610:140552.084 ****** Enabled features ******
    7:20240610:140552.084 SNMP monitoring: YES
    7:20240610:140552.084 IPMI monitoring: YES
    7:20240610:140552.084 Web monitoring: YES
    7:20240610:140552.084 VMware monitoring: YES
    7:20240610:140552.084 SMTP authentication: YES
    7:20240610:140552.084 ODBC: YES
    7:20240610:140552.084 SSH support: YES
    7:20240610:140552.084 IPv6 support: YES
    7:20240610:140552.084 TLS support: YES
    7:20240610:140552.084 ******************************
    7:20240610:140552.084 using configuration file: /etc/zabbix/zabbix_server.conf
    7:20240610:140552.129 current database version (mandatory/optional): 06000000/06000044
    7:20240610:140552.129 required mandatory version: 06000000
    7:20240610:140552.140 database could be upgraded to use primary keys in history tables
    7:20240610:140552.151 database is not upgraded to use double precision values
    179:20240610:140552.166 starting HA manager
    179:20240610:140552.178 HA manager started in active mode
    7:20240610:140552.180 server #0 started [main process]
    180:20240610:140552.181 server #1 started [service manager #1]
    181:20240610:140552.181 server #2 started [configuration syncer #1]
    181:20240610:140552.240 Got signal [signal:11(SIGSEGV),reason:1,refaddrnil)]. Crashing ...
    181:20240610:140552.240 ====== Fatal information: ======
    181:20240610:140552.240 Program counter: 0x7052f654e7fd
    181:20240610:140552.240 === Registers: ===
    181:20240610:140552.240 r8 = 7fffffffffffff00 = 9223372036854775552 = 9223372036854775552
    181:20240610:140552.240 r9 = 738 = 1848 = 1848
    181:20240610:140552.240 r10 = 768 = 1896 = 1896
    181:20240610:140552.240 r11 = 7052f65703c0 = 123501622526912 = 123501622526912
    181:20240610:140552.240 r12 = 1 = 1 = 1
    181:20240610:140552.240 r13 = 7052f0433618 = 123501520565784 = 123501520565784
    181:20240610:140552.240 r14 = 7fff85006e00 = 140735424785920 = 140735424785920
    181:20240610:140552.240 r15 = 5b0c2ebd2fe0 = 100107881885664 = 100107881885664
    181:20240610:140552.240 rdi = 0 = 0 = 0
    181:20240610:140552.240 rsi = 7052f0433640 = 123501520565824 = 123501520565824
    181:20240610:140552.240 rbp = 7052f0433640 = 123501520565824 = 123501520565824
    181:20240610:140552.240 rbx = 0 = 0 = 0
    181:20240610:140552.240 rdx = 0 = 0 = 0
    181:20240610:140552.240 rax = 0 = 0 = 0
    181:20240610:140552.240 rcx = 7052f0433670 = 123501520565872 = 123501520565872
    181:20240610:140552.240 rsp = 7fff85006d78 = 140735424785784 = 140735424785784
    181:20240610:140552.240 rip = 7052f654e7fd = 123501622388733 = 123501622388733
    181:20240610:140552.240 efl = 10283 = 66179 = 66179
    181:20240610:140552.240 csgsfs = 2b000000000033 = 12103423998558259 = 12103423998558259
    181:20240610:140552.240 err = 4 = 4 = 4
    181:20240610:140552.240 trapno = e = 14 = 14
    181:20240610:140552.240 oldmask = 0 = 0 = 0
    181:20240610:140552.240 cr2 = 0 = 0 = 0
    181:20240610:140552.240 === Backtrace: ===
    181:20240610:140552.241 15: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_backtrace+0x58) [0x5b0c2e934518]
    181:20240610:140552.241 14: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_log_fatal_info+0x2ad) [0x5b0c2e9348cd]
    181:20240610:140552.241 13: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1f3f6a) [0x5b0c2e934f6a]
    181:20240610:140552.241 12: /lib/x86_64-linux-gnu/libc.so.6(+0x42520) [0x7052f63f3520]
    181:20240610:140552.241 11: /lib/x86_64-linux-gnu/libc.so.6(+0x19d7fd) [0x7052f654e7fd]
    181:20240610:140552.241 10: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCstrpool_replace+0x35) [0x5b0c2e8ce585]
    181:20240610:140552.241 9: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x194ca0) [0x5b0c2e8d5ca0]
    181:20240610:140552.241 8: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCsync_configuration+0x367c) [0x5b0c2e8e26ac]
    181:20240610:140552.241 7: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](dbconfig_thread+0x11a) [0x5b0c2e7c624a]
    181:20240610:140552.241 6: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_thread_start+0x24) [0x5b0c2e936ad4]
    181:20240610:140552.241 5: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x7656e) [0x5b0c2e7b756e]
    181:20240610:140552.241 4: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](MAIN_ZABBIX_ENTRY+0x6fb) [0x5b0c2e7b843b]
    181:20240610:140552.241 3: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](main+0x547) [0x5b0c2e7af437]
    181:20240610:140552.241 2: /lib/x86_64-linux-gnu/libc.so.6(+0x29d90) [0x7052f63dad90]
    181:20240610:140552.241 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80) [0x7052f63dae40]
    181:20240610:140552.241 0: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](_start+0x25) [0x5b0c2e7b6785]
    181:20240610:140552.241 === Memory map: ===
    181:20240610:140552.241 5b0c2e741000-5b0c2e7a8000 r--p 00000000 00:2d 265956 /usr/sbin/zabbix_server
    181:20240610:140552.241 5b0c2e7a8000-5b0c2ea20000 r-xp 00067000 00:2d 265956 /usr/sbin/zabbix_server
    181:20240610:140552.241 5b0c2ea20000-5b0c2eaf5000 r--p 002df000 00:2d 265956 /usr/sbin/zabbix_server
    181:20240610:140552.241 5b0c2eaf6000-5b0c2eafa000 r--p 003b4000 00:2d 265956 /usr/sbin/zabbix_server
    181:20240610:140552.241 5b0c2eafa000-5b0c2ebcf000 rw-p 003b8000 00:2d 265956 /usr/sbin/zabbix_server
    181:20240610:140552.241 5b0c2ebcf000-5b0c2ebde000 rw-p 00000000 00:00 0
    181:20240610:140552.241 5b0c30178000-5b0c302d5000 rw-p 00000000 00:00 0 [heap]
    181:20240610:140552.241 5b0c302d5000-5b0c3043a000 rw-p 00000000 00:00 0 [heap]
    181:20240610:140552.241 7052ef36b000-7052ef5d5000 rw-p 00000000 00:00 0
    181:20240610:140552.241 7052ef5d5000-7052ef9d5000 rw-s 00000000 00:01 7 /SYSV00000000 (deleted)
    181:20240610:140552.241 7052ef9d5000-7052f01d5000 rw-s 00000000 00:01 6 /SYSV00000000 (deleted)
    181:20240610:140552.242 7052f01d5000-7052f01d9000 rw-s 00000000 00:01 5 /SYSV00000000 (deleted)
    181:20240610:140552.242 7052f01d9000-7052f21d9000 rw-s 00000000 00:01 4 /SYSV00000000 (deleted)
    181:20240610:140552.242 7052f21d9000-7052f25d9000 rw-s 00000000 00:01 3 /SYSV00000000 (deleted)
    181:20240610:140552.242 7052f25d9000-7052f29d9000 rw-s 00000000 00:01 2 /SYSV00000000 (deleted)
    181:20240610:140552.242 7052f29d9000-7052f39d9000 rw-s 00000000 00:01 1 /SYSV00000000 (deleted)
    181:20240610:140552.242 7052f39d9000-7052f39e4000 rw-p 00000000 00:00 0
    181:20240610:140552.242 7052f39e4000-7052f39e6000 r--p 00000000 00:2d 262389 /usr/lib/x86_64-linux-gnu/libffi.so.8.1.0
    181:20240610:140552.242 7052f39e6000-7052f39ed000 r-xp 00002000 00:2d 262389 /usr/lib/x86_64-linux-gnu/libffi.so.8.1.0
    181:20240610:140552.242 7052f39ed000-7052f39ee000 r--p 00009000 00:2d 262389 /usr/lib/x86_64-linux-gnu/libffi.so.8.1.0
    181:20240610:140552.242 7052f39ee000-7052f39ef000 ---p 0000a000 00:2d 262389 /usr/lib/x86_64-linux-gnu/libffi.so.8.1.0
    181:20240610:140552.242 7052f39ef000-7052f39f0000 r--p 0000a000 00:2d 262389 /usr/lib/x86_64-linux-gnu/libffi.so.8.1.0
    181:20240610:140552.242 7052f39f0000-7052f39f1000 rw-p 0000b000 00:2d 262389 /usr/lib/x86_64-linux-gnu/libffi.so.8.1.0
    181:20240610:140552.242 7052f39f1000-7052f39f3000 r--p 00000000 00:2d 262465 /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.9
    181:20240610:140552.242 7052f39f3000-7052f39f5000 r-xp 00002000 00:2d 262465 /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.9
    181:20240610:140552.242 7052f39f5000-7052f39f6000 r--p 00004000 00:2d 262465 /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.9
    181:20240610:140552.242 7052f39f6000-7052f39f7000 r--p 00004000 00:2d 262465 /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.9
    181:20240610:140552.242 7052f39f7000-7052f39f8000 rw-p 00005000 00:2d 262465 /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.9
    181:20240610:140552.242 7052f39f8000-7052f39f9000 r--p 00000000 00:2d 269815 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.9
    181:20240610:140552.242 7052f39f9000-7052f39fa000 r-xp 00001000 00:2d 269815 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.9
    181:20240610:140552.242 7052f39fa000-7052f3a19000 r--p 00002000 00:2d 269815 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.9
    181:20240610:140552.242 7052f3a19000-7052f3a1a000 r--p 00020000 00:2d 269815 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.9
    181:20240610:140552.242 7052f3a1a000-7052f3a1b000 rw-p 00021000 00:2d 269815 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.9
    181:20240610:140552.242 7052f3a1b000-7052f3a1d000 rw-p 00000000 00:00 0
    181:20240610:140552.242 7052f3a1d000-7052f3a27000 r--p 00000000 00:2d 262428 /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
    181:20240610:140552.242 7052f3a27000-7052f3a86000 r-xp 0000a000 00:2d 262428 /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
    181:20240610:140552.242 7052f3a86000-7052f3a9d000 r--p 00069000 00:2d 262428 /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
    181:20240610:140552.242 7052f3a9d000-7052f3a9e000 r--p 0007f000 00:2d 262428 /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
    181:20240610:140552.242 7052f3a9e000-7052f3a9f000 rw-p 00080000 00:2d 262428 /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
    181:20240610:140552.242 7052f3a9f000-7052f3aa7000 r--p 00000000 00:2d 262453 /usr/lib/x86_64-linux-gnu/libhogweed.so.6.4
    181:20240610:140552.242 7052f3aa7000-7052f3aba000 r-xp 00008000 00:2d 262453 /usr/lib/x86_64-linux-gnu/libhogweed.so.6.4
    181:20240610:140552.242 7052f3aba000-7052f3ae4000 r--p 0001b000 00:2d 262453 /usr/lib/x86_64-linux-gnu/libhogweed.so.6.4
    181:20240610:140552.242 7052f3ae4000-7052f3ae5000 ---p 00045000 00:2d 262453 /usr/lib/x86_64-linux-gnu/libhogweed.so.6.4
    181:20240610:140552.242 7052f3ae5000-7052f3ae6000 r--p 00045000 00:2d 262453 /usr/lib/x86_64-linux-gnu/libhogweed.so.6.4
    181:20240610:140552.242 7052f3ae6000-7052f3ae7000 rw-p 00046000 00:2d 262453 /usr/lib/x86_64-linux-gnu/libhogweed.so.6.4
    181:20240610:140552.242 7052f3ae7000-7052f3af1000 r--p 00000000 00:2d 262506 /usr/lib/x86_64-linux-gnu/libnettle.so.8.4
    181:20240610:140552.242 7052f3af1000-7052f3b14000 r-xp 0000a000 00:2d 262506 /usr/lib/x86_64-linux-gnu/libnettle.so.8.4
    181:20240610:140552.242 7052f3b14000-7052f3b2a000 r--p 0002d000 00:2d 262506 /usr/lib/x86_64-linux-gnu/libnettle.so.8.4
    181:20240610:140552.242 7052f3b2a000-7052f3b2c000 r--p 00042000 00:2d 262506 /usr/lib/x86_64-linux-gnu/libnettle.so.8.4
    181:20240610:140552.242 7052f3b2c000-7052f3b2d000 rw-p 00044000 00:2d 262506 /usr/lib/x86_64-linux-gnu/libnettle.so.8.4
    181:20240610:140552.242 7052f3b2d000-7052f3b30000 r--p 00000000 00:2d 262576 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.2
    181:20240610:140552.242 7052f3b30000-7052f3b3e000 r-xp 00003000 00:2d 262576 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.2
    181:20240610:140552.242 7052f3b3e000-7052f3b42000 r--p 00011000 00:2d 262576 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.2
    181:20240610:140552.242 7052f3b42000-7052f3b43000 ---p 00015000 00:2d 262576 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.2
    181:20240610:140552.242 7052f3b43000-7052f3b44000 r--p 00015000 00:2d 262576 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.2
    181:20240610:140552.242 7052f3b44000-7052f3b45000 rw-p 00016000 00:2d 262576 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.2
    181:20240610:140552.242 7052f3b45000-7052f3b56000 r--p 00000000 00:2d 262591 /usr/lib/x86_64-linux-gnu/libunistring.so.2.2.0
    181:20240610:140552.242 7052f3b56000-7052f3b8c000 r-xp 00011000 00:2d 262591 /usr/lib/x86_64-linux-gnu/libunistring.so.2.2.0
    181:20240610:140552.242 7052f3b8c000-7052f3cea000 r--p 00047000 00:2d 262591 /usr/lib/x86_64-linux-gnu/libunistring.so.2.2.0
    181:20240610:140552.242 7052f3cea000-7052f3cee000 r--p 001a5000 00:2d 262591 /usr/lib/x86_64-linux-gnu/libunistring.so.2.2.0
    181:20240610:140552.242 7052f3cee000-7052f3cef000 rw-p 001a9000 00:2d 262591 /usr/lib/x86_64-linux-gnu/libunistring.so.2.2.0
    181:20240610:140552.242 7052f3cef000-7052f3d18000 r--p 00000000 00:2d 262521 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    181:20240610:140552.242 7052f3d18000-7052f3dbc000 r-xp 00029000 00:2d 262521 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    181:20240610:140552.242 7052f3dbc000-7052f3e16000 r--p 000cd000 00:2d 262521 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    181:20240610:140552.242 7052f3e16000-7052f3e20000 r--p 00126000 00:2d 262521 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    181:20240610:140552.242 7052f3e20000-7052f3e2a000 rw-p 00130000 00:2d 262521 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    181:20240610:140552.242 7052f3e2a000-7052f3e2c000 rw-p 00000000 00:00 0
    181:20240610:140552.242 7052f3e2c000-7052f3e2f000 r--p 00000000 00:2d 262472 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    181:20240610:140552.242 7052f3e2f000-7052f3e35000 r-xp 00003000 00:2d 262472 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    181:20240610:140552.242 7052f3e35000-7052f3e37000 r--p 00009000 00:2d 262472 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    181:20240610:140552.242 7052f3e37000-7052f3e38000 ---p 0000b000 00:2d 262472 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    181:20240610:140552.242 7052f3e38000-7052f3e39000 r--p 0000b000 00:2d 262472 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    181:20240610:140552.242 7052f3e39000-7052f3e3a000 rw-p 0000c000 00:2d 262472 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    181:20240610:140552.242 7052f3e3a000-7052f3e3c000 r--p 00000000 00:2d 262351 /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
    181:20240610:140552.242 7052f3e3c000-7052f3e3d000 r-xp 00002000 00:2d 262351 /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
    181:20240610:140552.242 7052f3e3d000-7052f3e3e000 r--p 00003000 00:2d 262351 /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
    181:20240610:140552.242 7052f3e3e000-7052f3e3f000 r--p 00003000 00:2d 262351 /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
    181:20240610:140552.242 7052f3e3f000-7052f3e40000 rw-p 00004000 00:2d 262351 /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
    181:20240610:140552.242 7052f3e40000-7052f3e44000 r--p 00000000 00:2d 262461 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    181:20240610:140552.242 7052f3e44000-7052f3e5f000 r-xp 00004000 00:2d 262461 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    181:20240610:140552.242 7052f3e5f000-7052f3e6b000 r--p 0001f000 00:2d 262461 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    181:20240610:140552.242 7052f3e6b000-7052f3e6c000 ---p 0002b000 00:2d 262461 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    181:20240610:140552.242 7052f3e6c000-7052f3e6d000 r--p 0002b000 00:2d 262461 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    181:20240610:140552.242 7052f3e6d000-7052f3e6e000 rw-p 0002c000 00:2d 262461 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    181:20240610:140552.242 7052f3e6e000-7052f3e6f000 rw-p 00000000 00:00 0
    181:20240610:140552.242 7052f3e6f000-7052f3e90000 r--p 00000000 00:2d 262467 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    181:20240610:140552.242 7052f3e90000-7052f3eed000 r-xp 00021000 00:2d 262467 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    181:20240610:140552.242 7052f3eed000-7052f3f2a000 r--p 0007e000 00:2d 262467 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    181:20240610:140552.242 7052f3f2a000-7052f3f2b000 ---p 000bb000 00:2d 262467 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    181:20240610:140552.242 7052f3f2b000-7052f3f38000 r--p 000bb000 00:2d 262467 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    181:20240610:140552.242 7052f3f38000-7052f3f3a000 rw-p 000c8000 00:2d 262467 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    181:20240610:140552.242 7052f3f3a000-7052f3f3b000 r--p 00000000 00:2d 269908 /usr/lib/x86_64-linux-gnu/libicudata.so.70.1
    181:20240610:140552.242 7052f3f3b000-7052f3f3c000 r-xp 00001000 00:2d 269908 /usr/lib/x86_64-linux-gnu/libicudata.so.70.1
    181:20240610:140552.242 7052f3f3c000-7052f5b56000 r--p 00002000 00:2d 269908 /usr/lib/x86_64-linux-gnu/libicudata.so.70.1
    181:20240610:140552.242 7052f5b56000-7052f5b57000 r--p 01c1b000 00:2d 269908 /usr/lib/x86_64-linux-gnu/libicudata.so.70.1
    181:20240610:140552.242 7052f5b57000-7052f5b58000 rw-p 01c1c000 00:2d 269908 /usr/lib/x86_64-linux-gnu/libicudata.so.70.1
    181:20240610:140552.242 7052f5b58000-7052f5b5a000 rw-p 00000000 00:00 0
    181:20240610:140552.242 7052f5b5a000-7052f5b5b000 r--p 00000000 00:2d 269823 /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.9
    181:20240610:140552.242 7052f5b5b000-7052f5b63000 r-xp 00001000 00:2d 269823 /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.9
    181:20240610:140552.242 7052f5b63000-7052f5b66000 r--p 00009000 00:2d 269823 /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.9
    181:20240610:140552.242 7052f5b66000-7052f5b67000 r--p 0000b000 00:2d 269823 /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.9
    181:20240610:140552.242 7052f5b67000-7052f5b68000 rw-p 0000c000 00:2d 269823 /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.9
    181:20240610:140552.242 7052f5b68000-7052f5b6a000 r--p 00000000 00:2d 271566 /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    181:20240610:140552.242 7052f5b6a000-7052f5b6c000 r-xp 00002000 00:2d 271566 /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    181:20240610:140552.242 7052f5b6c000-7052f5b7a000 r--p 00004000 00:2d 271566 /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    181:20240610:140552.242 7052f5b7a000-7052f5b7b000 r--p 00011000 00:2d 271566 /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    181:20240610:140552.242 7052f5b7b000-7052f5b7c000 rw-p 00012000 00:2d 271566 /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    181:20240610:140552.242 7052f5b7c000-7052f5b81000 r--p 00000000 00:2d 271591 /usr/lib/x86_64-linux-gnu/librtmp.so.1
    181:20240610:140552.242 7052f5b81000-7052f5b91000 r-xp 00005000 00:2d 271591 /usr/lib/x86_64-linux-gnu/librtmp.so.1
    181:20240610:140552.242 7052f5b91000-7052f5b98000 r--p 00015000 00:2d 271591 /usr/lib/x86_64-linux-gnu/librtmp.so.1
    181:20240610:140552.242 7052f5b98000-7052f5b99000 ---p 0001c000 00:2d 271591 /usr/lib/x86_64-linux-gnu/librtmp.so.1
    181:20240610:140552.242 7052f5b99000-7052f5b9a000 r--p 0001c000 00:2d 271591 /usr/lib/x86_64-linux-gnu/librtmp.so.1
    181:20240610:140552.242 7052f5b9a000-7052f5b9b000 rw-p 0001d000 00:2d 271591 /usr/lib/x86_64-linux-gnu/librtmp.so.1
    181:20240610:140552.242 7052f5b9b000-7052f5b9d000 r--p 00000000 00:2d 262457 /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.7
    181:20240610:140552.242 7052f5b9d000-7052f5ba1000 r-xp 00002000 00:2d 262457 /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.7
    181:20240610:140552.242 7052f5ba1000-7052f5bba000 r--p 00006000 00:2d 262457 /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.7
    181:20240610:140552.242 7052f5bba000-7052f5bbb000 r--p 0001e000 00:2d 262457 /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.7
    181:20240610:140552.242 7052f5bbb000-7052f5bbc000 rw-p 0001f000 00:2d 262457 /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.7
    181:20240610:140552.242 7052f5bbc000-7052f5bc1000 r--p 00000000 00:2d 271388 /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.20.1
    181:20240610:140552.242 7052f5bc1000-7052f5bd6000 r-xp 00005000 00:2d 271388 /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.20.1
    181:20240610:140552.242 7052f5bd6000-7052f5be2000 r--p 0001a000 00:2d 271388 /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.20.1
    181:20240610:140552.242 7052f5be2000-7052f5be5000 r--p 00025000 00:2d 271388 /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.20.1
    181:20240610:140552.242 7052f5be5000-7052f5be6000 rw-p 00028000 00:2d 271388 /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.20.1
    181:20240610:140552.242 7052f5be6000-7052f5be8000 rw-p 00000000 00:00 0
    181:20240610:140552.242 7052f5be8000-7052f5c19000 r--p 00000000 00:2d 262435 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.31.0
    181:20240610:140552.242 7052f5c19000-7052f5d42000 r-xp 00031000 00:2d 262435 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.31.0
    181:20240610:140552.242 7052f5d42000-7052f5dbf000 r--p 0015a000 00:2d 262435 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.31.0
    181:20240610:140552.242 7052f5dbf000-7052f5dcf000 r--p 001d6000 00:2d 262435 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.31.0
    181:20240610:140552.242 7052f5dcf000-7052f5dd1000 rw-p 001e6000 00:2d 262435 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.31.0
    181:20240610:140552.242 7052f5dd1000-7052f5dd3000 rw-p 00000000 00:00 0
    181:20240610:140552.242 7052f5dd3000-7052f5dd6000 r--p 00000000 00:2d 271593 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    181:20240610:140552.242 7052f5dd6000-7052f5de7000 r-xp 00003000 00:2d 271593 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    181:20240610:140552.242 7052f5de7000-7052f5dec000 r--p 00014000 00:2d 271593 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    181:20240610:140552.242 7052f5dec000-7052f5ded000 r--p 00018000 00:2d 271593 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    181:20240610:140552.242 7052f5ded000-7052f5dee000 rw-p 00019000 00:2d 271593 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    181:20240610:140552.242 7052f5dee000-7052f5df0000 r--p 00000000 00:2d 269811 /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    181:20240610:140552.242 7052f5df0000-7052f5df5000 r-xp 00002000 00:2d 269811 /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    181:20240610:140552.242 7052f5df5000-7052f5df7000 r--p 00007000 00:2d 269811 /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    181:20240610:140552.242 7052f5df7000-7052f5df8000 r--p 00008000 00:2d 269811 /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    181:20240610:140552.242 7052f5df8000-7052f5df9000 rw-p 00009000 00:2d 269811 /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    181:20240610:140552.242 7052f5df9000-7052f5e04000 r--p 00000000 00:2d 262449 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    181:20240610:140552.242 7052f5e04000-7052f5e3c000 r-xp 0000b000 00:2d 262449 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    181:20240610:140552.242 7052f5e3c000-7052f5e48000 r--p 00043000 00:2d 262449 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    181:20240610:140552.242 7052f5e48000-7052f5e49000 ---p 0004f000 00:2d 262449 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    181:20240610:140552.242 7052f5e49000-7052f5e4b000 r--p 0004f000 00:2d 262449 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    181:20240610:140552.242 7052f5e4b000-7052f5e4d000 rw-p 00051000 00:2d 262449 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    181:20240610:140552.242 7052f5e4d000-7052f5e4f000 r--p 00000000 00:2d 270997 /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
    181:20240610:140552.242 7052f5e4f000-7052f5e54000 r-xp 00002000 00:2d 270997 /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
    181:20240610:140552.242 7052f5e54000-7052f5e56000 r--p 00007000 00:2d 270997 /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
    181:20240610:140552.242 7052f5e56000-7052f5e57000 r--p 00008000 00:2d 270997 /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
    181:20240610:140552.242 7052f5e57000-7052f5e58000 rw-p 00009000 00:2d 270997 /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
    181:20240610:140552.242 7052f5e58000-7052f5e5a000 rw-p 00000000 00:00 0
    181:20240610:140552.242 7052f5e5a000-7052f5e5d000 r--p 00000000 00:2d 262477 /usr/lib/x86_64-linux-gnu/liblzma.so.5.2.5
    181:20240610:140552.242 7052f5e5d000-7052f5e78000 r-xp 00003000 00:2d 262477 /usr/lib/x86_64-linux-gnu/liblzma.so.5.2.5
    181:20240610:140552.242 7052f5e78000-7052f5e83000 r--p 0001e000 00:2d 262477 /usr/lib/x86_64-linux-gnu/liblzma.so.5.2.5
    181:20240610:140552.242 7052f5e83000-7052f5e84000 r--p 00028000 00:2d 262477 /usr/lib/x86_64-linux-gnu/liblzma.so.5.2.5
    181:20240610:140552.242 7052f5e84000-7052f5e85000 rw-p 00029000 00:2d 262477 /usr/lib/x86_64-linux-gnu/liblzma.so.5.2.5
    181:20240610:140552.242 7052f5e85000-7052f5eeb000 r--p 00000000 00:2d 270905 /usr/lib/x86_64-linux-gnu/libicuuc.so.70.1
    181:20240610:140552.242 7052f5eeb000-7052f5fde000 r-xp 00066000 00:2d 270905 /usr/lib/x86_64-linux-gnu/libicuuc.so.70.1
    181:20240610:140552.242 7052f5fde000-7052f606a000 r--p 00159000 00:2d 270905 /usr/lib/x86_64-linux-gnu/libicuuc.so.70.1
    181:20240610:140552.242 7052f606a000-7052f607d000 r--p 001e4000 00:2d 270905 /usr/lib/x86_64-linux-gnu/libicuuc.so.70.1
    181:20240610:140552.242 7052f607d000-7052f607e000 rw-p 001f7000 00:2d 270905 /usr/lib/x86_64-linux-gnu/libicuuc.so.70.1
    181:20240610:140552.242 7052f607e000-7052f6080000 rw-p 00000000 00:00 0
    181:20240610:140552.242 7052f6080000-7052f6083000 r--p 00000000 00:2d 262397 /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    181:20240610:140552.242 7052f6083000-7052f609a000 r-xp 00003000 00:2d 262397 /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    181:20240610:140552.242 7052f609a000-7052f609e000 r--p 0001a000 00:2d 262397 /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    181:20240610:140552.242 7052f609e000-7052f609f000 r--p 0001d000 00:2d 262397 /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    181:20240610:140552.242 7052f609f000-7052f60a0000 rw-p 0001e000 00:2d 262397 /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    181:20240610:140552.242 7052f60a0000-7052f613a000 r--p 00000000 00:2d 262572 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30
    181:20240610:140552.242 7052f613a000-7052f624b000 r-xp 0009a000 00:2d 262572 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30
    181:20240610:140552.242 7052f624b000-7052f62ba000 r--p 001ab000 00:2d 262572 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30
    181:20240610:140552.242 7052f62ba000-7052f62bb000 ---p 0021a000 00:2d 262572 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30
    181:20240610:140552.242 7052f62bb000-7052f62c6000 r--p 0021a000 00:2d 262572 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30
    181:20240610:140552.242 7052f62c6000-7052f62c9000 rw-p 00225000 00:2d 262572 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30
    181:20240610:140552.242 7052f62c9000-7052f62cc000 rw-p 00000000 00:00 0
    181:20240610:140552.242 7052f62cc000-7052f62d6000 r--p 00000000 00:2d 262612 /usr/lib/x86_64-linux-gnu/libzstd.so.1.4.8
    181:20240610:140552.242 7052f62d6000-7052f6388000 r-xp 0000a000 00:2d 262612 /usr/lib/x86_64-linux-gnu/libzstd.so.1.4.8
    181:20240610:140552.242 7052f6388000-7052f6399000 r--p 000bc000 00:2d 262612 /usr/lib/x86_64-linux-gnu/libzstd.so.1.4.8
    181:20240610:140552.242 7052f6399000-7052f639a000 r--p 000cc000 00:2d 262612 /usr/lib/x86_64-linux-gnu/libzstd.so.1.4.8
    181:20240610:140552.242 7052f639a000-7052f639b000 rw-p 000cd000 00:2d 262612 /usr/lib/x86_64-linux-gnu/libzstd.so.1.4.8
    181:20240610:140552.242 7052f639b000-7052f639d000 rw-p 00000000 00:00 0
    181:20240610:140552.242 7052f639d000-7052f63a0000 r--p 00000000 00:2d 262559 /usr/lib/x86_64-linux-gnu/libresolv.so.2
    181:20240610:140552.242 7052f63a0000-7052f63aa000 r-xp 00003000 00:2d 262559 /usr/lib/x86_64-linux-gnu/libresolv.so.2
    181:20240610:140552.242 7052f63aa000-7052f63ad000 r--p 0000d000 00:2d 262559 /usr/lib/x86_64-linux-gnu/libresolv.so.2
    181:20240610:140552.242 7052f63ad000-7052f63ae000 r--p 0000f000 00:2d 262559 /usr/lib/x86_64-linux-gnu/libresolv.so.2
    181:20240610:140552.242 7052f63ae000-7052f63af000 rw-p 00010000 00:2d 262559 /usr/lib/x86_64-linux-gnu/libresolv.so.2
    181:20240610:140552.242 7052f63af000-7052f63b1000 rw-p 00000000 00:00 0
    181:20240610:140552.242 7052f63b1000-7052f63d9000 r--p 00000000 00:2d 262344 /usr/lib/x86_64-linux-gnu/libc.so.6
    181:20240610:140552.242 7052f63d9000-7052f656e000 r-xp 00028000 00:2d 262344 /usr/lib/x86_64-linux-gnu/libc.so.6
    181:20240610:140552.242 7052f656e000-7052f65c6000 r--p 001bd000 00:2d 262344 /usr/lib/x86_64-linux-gnu/libc.so.6
    181:20240610:140552.242 7052f65c6000-7052f65c7000 ---p 00215000 00:2d 262344 /usr/lib/x86_64-linux-gnu/libc.so.6
    181:20240610:140552.242 7052f65c7000-7052f65cb000 r--p 00215000 00:2d 262344 /usr/lib/x86_64-linux-gnu/libc.so.6
    181:20240610:140552.242 7052f65cb000-7052f65cd000 rw-p 00219000 00:2d 262344 /usr/lib/x86_64-linux-gnu/libc.so.6
    181:20240610:140552.242 7052f65cd000-7052f65da000 rw-p 00000000 00:00 0
    181:20240610:140552.242 7052f65da000-7052f65dc000 r--p 00000000 00:2d 262553 /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.10.4
    181:20240610:140552.242 7052f65dc000-7052f6647000 r-xp 00002000 00:2d 262553 /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.10.4
    181:20240610:140552.242 7052f6647000-7052f666f000 r--p 0006d000 00:2d 262553 /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.10.4
    181:20240610:140552.242 7052f666f000-7052f6670000 r--p 00094000 00:2d 262553 /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.10.4
    181:20240610:140552.242 7052f6670000-7052f6671000 rw-p 00095000 00:2d 262553 /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.10.4
    181:20240610:140552.242 7052f6671000-7052f6680000 r--p 00000000 00:2d 269847 /usr/lib/x86_64-linux-gnu/libcurl.so.4.7.0
    181:20240610:140552.242 7052f6680000-7052f66f5000 r-xp 0000f000 00:2d 269847 /usr/lib/x86_64-linux-gnu/libcurl.so.4.7.0
    181:20240610:140552.242 7052f66f5000-7052f6710000 r--p 00084000 00:2d 269847 /usr/lib/x86_64-linux-gnu/libcurl.so.4.7.0
    181:20240610:140552.242 7052f6710000-7052f6711000 ---p 0009f000 00:2d 269847 /usr/lib/x86_64-linux-gnu/libcurl.so.4.7.0
    181:20240610:140552.242 7052f6711000-7052f6715000 r--p 0009f000 00:2d 269847 /usr/lib/x86_64-linux-gnu/libcurl.so.4.7.0
    181:20240610:140552.242 7052f6715000-7052f6717000 rw-p 000a3000 00:2d 269847 /usr/lib/x86_64-linux-gnu/libcurl.so.4.7.0
    181:20240610:140552.242 7052f6717000-7052f6718000 rw-p 00000000 00:00 0
    181:20240610:140552.242 7052f6718000-7052f671b000 r--p 00000000 00:2d 270982 /usr/lib/x86_64-linux-gnu/liblber-2.5.so.0.1.12
    181:20240610:140552.242 7052f671b000-7052f6723000 r-xp 00003000 00:2d 270982 /usr/lib/x86_64-linux-gnu/liblber-2.5.so.0.1.12
    181:20240610:140552.242 7052f6723000-7052f6726000 r--p 0000b000 00:2d 270982 /usr/lib/x86_64-linux-gnu/liblber-2.5.so.0.1.12
    181:20240610:140552.242 7052f6726000-7052f6727000 ---p 0000e000 00:2d 270982 /usr/lib/x86_64-linux-gnu/liblber-2.5.so.0.1.12
    181:20240610:140552.242 7052f6727000-7052f6728000 r--p 0000e000 00:2d 270982 /usr/lib/x86_64-linux-gnu/liblber-2.5.so.0.1.12
    181:20240610:140552.242 7052f6728000-7052f6729000 rw-p 0000f000 00:2d 270982 /usr/lib/x86_64-linux-gnu/liblber-2.5.so.0.1.12
    181:20240610:140552.242 7052f6729000-7052f6737000 r--p 00000000 00:2d 270985 /usr/lib/x86_64-linux-gnu/libldap-2.5.so.0.1.12
    181:20240610:140552.243 7052f6737000-7052f6771000 r-xp 0000e000 00:2d 270985 /usr/lib/x86_64-linux-gnu/libldap-2.5.so.0.1.12
    181:20240610:140552.243 7052f6771000-7052f6782000 r--p 00048000 00:2d 270985 /usr/lib/x86_64-linux-gnu/libldap-2.5.so.0.1.12
    181:20240610:140552.243 7052f6782000-7052f6783000 ---p 00059000 00:2d 270985 /usr/lib/x86_64-linux-gnu/libldap-2.5.so.0.1.12
    181:20240610:140552.243 7052f6783000-7052f6785000 r--p 00059000 00:2d 270985 /usr/lib/x86_64-linux-gnu/libldap-2.5.so.0.1.12
    181:20240610:140552.243 7052f6785000-7052f6786000 rw-p 0005b000 00:2d 270985 /usr/lib/x86_64-linux-gnu/libldap-2.5.so.0.1.12
    181:20240610:140552.243 7052f6786000-7052f678a000 rw-p 00000000 00:00 0
    181:20240610:140552.243 7052f678a000-7052f6796000 r--p 00000000 00:2d 269884 /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.1
    181:20240610:140552.243 7052f6796000-7052f67c8000 r-xp 0000c000 00:2d 269884 /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.1
    181:20240610:140552.243 7052f67c8000-7052f67db000 r--p 0003e000 00:2d 269884 /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.1
    181:20240610:140552.243 7052f67db000-7052f67dc000 ---p 00051000 00:2d 269884 /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.1
    181:20240610:140552.243 7052f67dc000-7052f67dd000 r--p 00051000 00:2d 269884 /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.1
    181:20240610:140552.243 7052f67dd000-7052f67de000 rw-p 00052000 00:2d 269884 /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.1
    181:20240610:140552.243 7052f67de000-7052f67e0000 r--p 00000000 00:2d 262609 /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
    181:20240610:140552.243 7052f67e0000-7052f67f1000 r-xp 00002000 00:2d 262609 /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
    181:20240610:140552.243 7052f67f1000-7052f67f7000 r--p 00013000 00:2d 262609 /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
    181:20240610:140552.243 7052f67f7000-7052f67f8000 ---p 00019000 00:2d 262609 /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
    181:20240610:140552.243 7052f67f8000-7052f67f9000 r--p 00019000 00:2d 262609 /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
    181:20240610:140552.243 7052f67f9000-7052f67fa000 rw-p 0001a000 00:2d 262609 /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
    181:20240610:140552.243 7052f67fa000-7052f67fc000 r--p 00000000 00:2d 269795 /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    181:20240610:140552.243 7052f67fc000-7052f6800000 r-xp 00002000 00:2d 269795 /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    181:20240610:140552.243 7052f6800000-7052f6801000 r--p 00006000 00:2d 269795 /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    181:20240610:140552.243 7052f6801000-7052f6802000 ---p 00007000 00:2d 269795 /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    181:20240610:140552.243 7052f6802000-7052f6803000 r--p 00007000 00:2d 269795 /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    181:20240610:140552.243 7052f6803000-7052f6804000 rw-p 00008000 00:2d 269795 /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    181:20240610:140552.243 7052f6804000-7052f6832000 r--p 00000000 00:2d 269770 /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    181:20240610:140552.243 7052f6832000-7052f68b3000 r-xp 0002e000 00:2d 269770 /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    181:20240610:140552.243 7052f68b3000-7052f68f2000 r--p 000af000 00:2d 269770 /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    181:20240610:140552.243 7052f68f2000-7052f6909000 r--p 000ed000 00:2d 269770 /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    181:20240610:140552.243 7052f6909000-7052f690e000 rw-p 00104000 00:2d 269770 /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    181:20240610:140552.243 7052f690e000-7052f6912000 rw-p 00000000 00:00 0
    181:20240610:140552.243 7052f6912000-7052f691f000 r--p 00000000 00:2d 271652 /usr/lib/x86_64-linux-gnu/libssh.so.4.8.7
    181:20240610:140552.243 7052f691f000-7052f6962000 r-xp 0000d000 00:2d 271652 /usr/lib/x86_64-linux-gnu/libssh.so.4.8.7
    181:20240610:140552.243 7052f6962000-7052f697b000 r--p 00050000 00:2d 271652 /usr/lib/x86_64-linux-gnu/libssh.so.4.8.7
    181:20240610:140552.243 7052f697b000-7052f697d000 r--p 00068000 00:2d 271652 /usr/lib/x86_64-linux-gnu/libssh.so.4.8.7
    181:20240610:140552.243 7052f697d000-7052f697f000 rw-p 0006a000 00:2d 271652 /usr/lib/x86_64-linux-gnu/libssh.so.4.8.7
    181:20240610:140552.243 7052f697f000-7052f6996000 r--p 00000000 00:2d 271266 /usr/lib/x86_64-linux-gnu/libnetsnmp.so.40.1.0
    181:20240610:140552.243 7052f6996000-7052f6a23000 r-xp 00017000 00:2d 271266 /usr/lib/x86_64-linux-gnu/libnetsnmp.so.40.1.0
    181:20240610:140552.243 7052f6a23000-7052f6a53000 r--p 000a4000 00:2d 271266 /usr/lib/x86_64-linux-gnu/libnetsnmp.so.40.1.0
    181:20240610:140552.243 7052f6a53000-7052f6a55000 r--p 000d3000 00:2d 271266 /usr/lib/x86_64-linux-gnu/libnetsnmp.so.40.1.0
    181:20240610:140552.243 7052f6a55000-7052f6a58000 rw-p 000d5000 00:2d 271266 /usr/lib/x86_64-linux-gnu/libnetsnmp.so.40.1.0
    181:20240610:140552.243 7052f6a58000-7052f6a5f000 rw-p 00000000 00:00 0
    181:20240610:140552.243 7052f6a5f000-7052f6a65000 r--p 00000000 00:2d 271401 /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
    181:20240610:140552.243 7052f6a65000-7052f6ab4000 r-xp 00006000 00:2d 271401 /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
    181:20240610:140552.243 7052f6ab4000-7052f6ac2000 r--p 00055000 00:2d 271401 /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
    181:20240610:140552.243 7052f6ac2000-7052f6ac3000 r--p 00062000 00:2d 271401 /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
    181:20240610:140552.243 7052f6ac3000-7052f6aca000 rw-p 00063000 00:2d 271401 /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
    181:20240610:140552.243 7052f6aca000-7052f6ace000 rw-p 00000000 00:00 0
    181:20240610:140552.243 7052f6ace000-7052f6afd000 r--p 00000000 00:2d 271674 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.13
    181:20240610:140552.243 7052f6afd000-7052f6c50000 r-xp 0002f000 00:2d 271674 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.13
    181:20240610:140552.243 7052f6c50000-7052f6ca4000 r--p 00182000 00:2d 271674 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.13
    181:20240610:140552.243 7052f6ca4000-7052f6ca5000 ---p 001d6000 00:2d 271674 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.13
    181:20240610:140552.243 7052f6ca5000-7052f6cae000 r--p 001d6000 00:2d 271674 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.13
    181:20240610:140552.243 7052f6cae000-7052f6caf000 rw-p 001df000 00:2d 271674 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.13
    181:20240610:140552.243 7052f6caf000-7052f6cb0000 rw-p 00000000 00:00 0
    181:20240610:140552.243 7052f6cb0000-7052f6cbe000 r--p 00000000 00:2d 262478 /usr/lib/x86_64-linux-gnu/libm.so.6
    181:20240610:140552.243 7052f6cbe000-7052f6d3a000 r-xp 0000e000 00:2d 262478 /usr/lib/x86_64-linux-gnu/libm.so.6
    181:20240610:140552.243 7052f6d3a000-7052f6d95000 r--p 0008a000 00:2d 262478 /usr/lib/x86_64-linux-gnu/libm.so.6
    181:20240610:140552.243 7052f6d95000-7052f6d96000 r--p 000e4000 00:2d 262478 /usr/lib/x86_64-linux-gnu/libm.so.6
    181:20240610:140552.243 7052f6d96000-7052f6d97000 rw-p 000e5000 00:2d 262478 /usr/lib/x86_64-linux-gnu/libm.so.6
    181:20240610:140552.243 7052f6d97000-7052f6e49000 r--p 00000000 00:2d 262354 /usr/lib/x86_64-linux-gnu/libcrypto.so.3
    181:20240610:140552.243 7052f6e49000-7052f70a8000 r-xp 000b2000 00:2d 262354 /usr/lib/x86_64-linux-gnu/libcrypto.so.3
    181:20240610:140552.243 7052f70a8000-7052f717a000 r--p 00311000 00:2d 262354 /usr/lib/x86_64-linux-gnu/libcrypto.so.3
    181:20240610:140552.243 7052f717a000-7052f71d5000 r--p 003e2000 00:2d 262354 /usr/lib/x86_64-linux-gnu/libcrypto.so.3
    181:20240610:140552.243 7052f71d5000-7052f71d8000 rw-p 0043d000 00:2d 262354 /usr/lib/x86_64-linux-gnu/libcrypto.so.3
    181:20240610:140552.243 7052f71d8000-7052f71db000 rw-p 00000000 00:00 0
    181:20240610:140552.243 7052f71db000-7052f71f9000 r--p 00000000 00:2d 262570 /usr/lib/x86_64-linux-gnu/libssl.so.3
    181:20240610:140552.243 7052f71f9000-7052f7254000 r-xp 0001e000 00:2d 262570 /usr/lib/x86_64-linux-gnu/libssl.so.3
    181:20240610:140552.243 7052f7254000-7052f7271000 r--p 00079000 00:2d 262570 /usr/lib/x86_64-linux-gnu/libssl.so.3
    181:20240610:140552.243 7052f7271000-7052f727b000 r--p 00095000 00:2d 262570 /usr/lib/x86_64-linux-gnu/libssl.so.3
    181:20240610:140552.243 7052f727b000-7052f727f000 rw-p 0009f000 00:2d 262570 /usr/lib/x86_64-linux-gnu/libssl.so.3
    181:20240610:140552.243 7052f727f000-7052f72a5000 r--p 00000000 00:2d 271042 /usr/lib/x86_64-linux-gnu/libmysqlclient.so.21.2.36
    181:20240610:140552.243 7052f72a5000-7052f7331000 r-xp 00026000 00:2d 271042 /usr/lib/x86_64-linux-gnu/libmysqlclient.so.21.2.36
    181:20240610:140552.243 7052f7331000-7052f760f000 r--p 000b2000 00:2d 271042 /usr/lib/x86_64-linux-gnu/libmysqlclient.so.21.2.36
    181:20240610:140552.243 7052f760f000-7052f7616000 r--p 0038f000 00:2d 271042 /usr/lib/x86_64-linux-gnu/libmysqlclient.so.21.2.36
    181:20240610:140552.243 7052f7616000-7052f7904000 rw-p 00396000 00:2d 271042 /usr/lib/x86_64-linux-gnu/libmysqlclient.so.21.2.36
    181:20240610:140552.243 7052f7904000-7052f7909000 rw-p 00000000 00:00 0
    181:20240610:140552.243 7052f790c000-7052f790e000 rw-p 00000000 00:00 0
    181:20240610:140552.243 7052f790e000-7052f7910000 r--p 00000000 00:2d 262326 /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
    181:20240610:140552.243 7052f7910000-7052f793a000 r-xp 00002000 00:2d 262326 /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
    181:20240610:140552.243 7052f793a000-7052f7945000 r--p 0002c000 00:2d 262326 /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
    181:20240610:140552.243 7052f7945000-7052f7946000 rw-s 00000000 00:01 0 /SYSV00000000 (deleted)
    181:20240610:140552.243 7052f7946000-7052f7948000 r--p 00037000 00:2d 262326 /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
    181:20240610:140552.243 7052f7948000-7052f794a000 rw-p 00039000 00:2d 262326 /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
    181:20240610:140552.243 7fff84feb000-7fff8500c000 rw-p 00000000 00:00 0 [stack]
    181:20240610:140552.243 7fff8518b000-7fff8518f000 r--p 00000000 00:00 0 [vvar]
    181:20240610:140552.243 7fff8518f000-7fff85191000 r-xp 00000000 00:00 0 [vdso]
    181:20240610:140552.243 ffffffffff600000-ffffffffff601000 --xp 00000000 00:00 0 [vsyscall]
    181:20240610:140552.243 ================================
    181:20240610:140552.243 Please consider attaching a disassembly listing to your bug report.
    181:20240610:140552.243 This listing can be produced with, e.g., objdump -DSswx zabbix_server.
    7:20240610:140552.245 One child process died (PID:181,exitcode/signal:1). Exiting ...
    179:20240610:140552.245 HA manager has been paused
    179:20240610:140552.250 HA manager has been stopped
    7:20240610:140552.253 Zabbix Server stopped. Zabbix 6.0.30 (revision 680df72).
  • Markku
    • Sep 2018
    • 1788
    Configuration syncer seems to crash, and if I interpret the output (container?) correctly, you don't have CacheSize specified, which means to use the default of 32 MB. Have you tried setting it to something like 128 MB for a start and see if that makes a difference? If your configuration does not fit to the cache (I don't know if that would emit a clear error message or just cause a crash).
    Markku
    • M-Schmitt
      • Jun 2024
      Good Day,
      i did set the cache size to 128MB and double of that, it did sadly change nothing.
      Yes you are correct this is a Docker Container running on Ubuntu 24.04 LTS.
      I did set the other Cache configurations higher as their default Value was, just to look if it would make any difference, but it didn't.
      I put my Configuration file here too:
      File Start:
      __________________________________________________ _________________________________
      # This is a configuration file for Zabbix server daemon
      # To get more information about Zabbix, visit http://www.zabbix.com
      ### Option: ListenPort
      # Listen port for trapper.
      # Mandatory: no
      # Range: 1024-32767
      # Default:
      # ListenPort=10051
      ### Option: SourceIP
      # Source IP address for outgoing connections.
      # Mandatory: no
      # Default:
      # SourceIP=
      ### Option: LogType
      # Specifies where log messages are written to:
      # system - syslog
      # file - file specified with LogFile parameter
      # console - standard output
      # Mandatory: no
      # Default:
      # LogType=file
      LogType=console
      ### Option: LogFile
      # Log file name for LogType 'file' parameter.
      # Mandatory: yes, if LogType is set to file, otherwise no
      # Default:
      # LogFile=
      ### Option: LogFileSize
      # Maximum size of log file in MB.
      # 0 - disable automatic log rotation.
      # Mandatory: no
      # Range: 0-1024
      # Default:
      # LogFileSize=1
      ### Option: DebugLevel
      # Specifies debug level:
      # 0 - basic information about starting and stopping of Zabbix processes
      # 1 - critical information
      # 2 - error information
      # 3 - warnings
      # 4 - for debugging (produces lots of information)
      # 5 - extended debugging (produces even more information)
      # Mandatory: no
      # Range: 0-5
      # Default:
      # DebugLevel=3
      ### Option: PidFile
      # Name of PID file.
      # Mandatory: no
      # Default:
      # PidFile=/tmp/zabbix_server.pid
      ### Option: SocketDir
      # IPC socket directory.
      # Directory to store IPC sockets used by internal Zabbix services.
      # Mandatory: no
      # Default:
      # SocketDir=/tmp
      ### Option: DBHost
      # Database host name.
      # If set to localhost, socket is used for MySQL.
      # If set to empty string, socket is used for PostgreSQL.
      # If set to empty string, the Net Service Name connection method is used to connect to Oracle database; also see
      # the TNS_ADMIN environment variable to specify the directory where the tnsnames.ora file is located.
      # Mandatory: no
      # Default:
      # DBHost=localhost
      DBHost=mysql-server
      ### Option: DBName
      # Database name.
      # If the Net Service Name connection method is used to connect to Oracle database, specify the service name from
      # the tnsnames.ora file or set to empty string; also see the TWO_TASK environment variable if DBName is set to
      # empty string.
      # Mandatory: yes
      # Default:
      # DBName=
      DBName=zabbix
      ### Option: DBSchema
      # Schema name. Used for PostgreSQL.
      # Mandatory: no
      # Default:
      # DBSchema=
      ### Option: DBUser
      # Database user.
      # Mandatory: no
      # Default:
      # DBUser=
      DBUser=zabbix
      ### Option: DBPassword
      # Database password.
      # Comment this line if no password is used.
      # Mandatory: no
      # Default:
      # DBPassword=
      DBPassword=zabbix
      ### Option: DBSocket
      # Path to MySQL socket.
      # Mandatory: no
      # Default:
      # DBSocket=
      ### Option: DBPort
      # Database port when not using local socket.
      # If the Net Service Name connection method is used to connect to Oracle database, the port number from the
      # tnsnames.ora file will be used. The port number set here will be ignored.
      # Mandatory: no
      # Range: 1024-65535
      # Default:
      # DBPort=
      DBPort=3306
      ### Option: AllowUnsupportedDBVersions
      # Allow server to work with unsupported database versions.
      # 0 - do not allow
      # 1 - allow
      # Mandatory: no
      # Default:
      # AllowUnsupportedDBVersions=0
      ### Option: HistoryStorageURL
      # History storage HTTP[S] URL.
      # Mandatory: no
      # Default:
      # HistoryStorageURL=
      ### Option: HistoryStorageTypes
      # Comma separated list of value types to be sent to the history storage.
      # Mandatory: no
      # Default:
      # HistoryStorageTypes=uint,dbl,str,log,text
      ### Option: HistoryStorageDateIndex
      # Enable preprocessing of history values in history storage to store values in different indices based on date.
      # 0 - disable
      # 1 - enable
      # Mandatory: no
      # Default:
      # HistoryStorageDateIndex=0
      ### Option: ExportDir
      # Directory for real time export of events, history and trends in newline delimited JSON format.
      # If set, enables real time export.
      # Mandatory: no
      # Default:
      # ExportDir=
      ### Option: ExportFileSize
      # Maximum size per export file in bytes.
      # Only used for rotation if ExportDir is set.
      # Mandatory: no
      # Range: 1M-1G
      # Default:
      # ExportFileSize=1G
      ### Option: ExportType
      # List of comma delimited types of real time export - allows to control export entities by their
      # type (events, history, trends) individually.
      # Valid only if ExportDir is set.
      # Mandatory: no
      # Default:
      # ExportType=events,history,trends
      ############ ADVANCED PARAMETERS ################
      ### Option: StartPollers
      # Number of pre-forked instances of pollers.
      # Mandatory: no
      # Range: 0-1000
      # Default:
      # StartPollers=5
      ### Option: StartIPMIPollers
      # Number of pre-forked instances of IPMI pollers.
      # The IPMI manager process is automatically started when at least one IPMI poller is started.
      # Mandatory: no
      # Range: 0-1000
      # Default:
      # StartIPMIPollers=0
      ### Option: StartPreprocessors
      # Number of pre-forked instances of preprocessing workers.
      # The preprocessing manager process is automatically started when preprocessor worker is started.
      # Mandatory: no
      # Range: 1-1000
      # Default:
      # StartPreprocessors=3
      ### Option: StartPollersUnreachable
      # Number of pre-forked instances of pollers for unreachable hosts (including IPMI and Java).
      # At least one poller for unreachable hosts must be running if regular, IPMI or Java pollers
      # are started.
      # Mandatory: no
      # Range: 0-1000
      # Default:
      # StartPollersUnreachable=1
      ### Option: StartHistoryPollers
      # Number of pre-forked instances of history pollers.
      # Only required for calculated and internal checks.
      # A database connection is required for each history poller instance.
      # Mandatory: no
      # Range: 0-1000
      # Default:
      # StartHistoryPollers=5
      ### Option: StartTrappers
      # Number of pre-forked instances of trappers.
      # Trappers accept incoming connections from Zabbix sender, active agents and active proxies.
      # At least one trapper process must be running to display server availability and view queue
      # in the frontend.
      # Mandatory: no
      # Range: 0-1000
      # Default:
      # StartTrappers=5
      ### Option: StartPingers
      # Number of pre-forked instances of ICMP pingers.
      # Mandatory: no
      # Range: 0-1000
      # Default:
      # StartPingers=1
      ### Option: StartDiscoverers
      # Number of pre-forked instances of discoverers.
      # Mandatory: no
      # Range: 0-250
      # Default:
      # StartDiscoverers=1
      ### Option: StartHTTPPollers
      # Number of pre-forked instances of HTTP pollers.
      # Mandatory: no
      # Range: 0-1000
      # Default:
      # StartHTTPPollers=1
      ### Option: StartTimers
      # Number of pre-forked instances of timers.
      # Timers process maintenance periods.
      # Only the first timer process handles host maintenance updates. Problem suppression updates are shared
      # between all timers.
      # Mandatory: no
      # Range: 1-1000
      # Default:
      # StartTimers=1
      ### Option: StartEscalators
      # Number of pre-forked instances of escalators.
      # Mandatory: no
      # Range: 1-100
      # Default:
      # StartEscalators=1
      ### Option: StartAlerters
      # Number of pre-forked instances of alerters.
      # Alerters send the notifications created by action operations.
      # Mandatory: no
      # Range: 1-100
      # Default:
      # StartAlerters=3
      ### Option: JavaGateway
      # IP address (or hostname) of Zabbix Java gateway.
      # Only required if Java pollers are started.
      # Mandatory: no
      # Default:
      # JavaGateway=
      JavaGateway=zabbix-java-gateway
      ### Option: JavaGatewayPort
      # Port that Zabbix Java gateway listens on.
      # Mandatory: no
      # Range: 1024-32767
      # Default:
      # JavaGatewayPort=10052
      ### Option: StartJavaPollers
      # Number of pre-forked instances of Java pollers.
      # Mandatory: no
      # Range: 0-1000
      # Default:
      # StartJavaPollers=0
      StartJavaPollers=5
      ### Option: StartVMwareCollectors
      # Number of pre-forked vmware collector instances.
      # Mandatory: no
      # Range: 0-250
      # Default:
      # StartVMwareCollectors=0
      ### Option: VMwareFrequency
      # How often Zabbix will connect to VMware service to obtain a new data.
      # Mandatory: no
      # Range: 10-86400
      # Default:
      # VMwareFrequency=60
      ### Option: VMwarePerfFrequency
      # How often Zabbix will connect to VMware service to obtain performance data.
      # Mandatory: no
      # Range: 10-86400
      # Default:
      # VMwarePerfFrequency=60
      ### Option: VMwareCacheSize
      # Size of VMware cache, in bytes.
      # Shared memory size for storing VMware data.
      # Only used if VMware collectors are started.
      # Mandatory: no
      # Range: 256K-2G
      # Default:
      # VMwareCacheSize=8M
      ### Option: VMwareTimeout
      # Specifies how many seconds vmware collector waits for response from VMware service.
      # Mandatory: no
      # Range: 1-300
      # Default:
      # VMwareTimeout=10
      ### Option: SNMPTrapperFile
      # Temporary file used for passing data from SNMP trap daemon to the server.
      # Must be the same as in zabbix_trap_receiver.pl or SNMPTT configuration file.
      # Mandatory: no
      # Default:
      # SNMPTrapperFile=/tmp/zabbix_traps.tmp
      SNMPTrapperFile=/var/lib/zabbix/snmptraps/snmptraps.log
      ### Option: StartSNMPTrapper
      # If 1, SNMP trapper process is started.
      # Mandatory: no
      # Range: 0-1
      # Default:
      # StartSNMPTrapper=0
      StartSNMPTrapper=1
      ### Option: ListenIP
      # List of comma delimited IP addresses that the trapper should listen on.
      # Trapper will listen on all network interfaces if this parameter is missing.
      # Mandatory: no
      # Default:
      # ListenIP=0.0.0.0
      ### Option: HousekeepingFrequency
      # How often Zabbix will perform housekeeping procedure (in hours).
      # Housekeeping is removing outdated information from the database.
      # To prevent Housekeeper from being overloaded, no more than 4 times HousekeepingFrequency
      # hours of outdated information are deleted in one housekeeping cycle, for each item.
      # To lower load on server startup housekeeping is postponed for 30 minutes after server start.
      # With HousekeepingFrequency=0 the housekeeper can be only executed using the runtime control option.
      # In this case the period of outdated information deleted in one housekeeping cycle is 4 times the
      # period since the last housekeeping cycle, but not less than 4 hours and not greater than 4 days.
      # Mandatory: no
      # Range: 0-24
      # Default:
      # HousekeepingFrequency=1
      ### Option: MaxHousekeeperDelete
      # The table "housekeeper" contains "tasks" for housekeeping procedure in the format:
      # [housekeeperid], [tablename], [field], [value].
      # No more than 'MaxHousekeeperDelete' rows (corresponding to [tablename], [field], [value])
      # will be deleted per one task in one housekeeping cycle.
      # If set to 0 then no limit is used at all. In this case you must know what you are doing!
      # Mandatory: no
      # Range: 0-1000000
      # Default:
      # MaxHousekeeperDelete=5000
      ### Option: CacheSize
      # Size of configuration cache, in bytes.
      # Shared memory size for storing host, item and trigger data.
      # Mandatory: no
      # Range: 128K-64G
      # Default:
      # CacheSize=128MB
      CacheSize=128M
      ### Option: CacheUpdateFrequency
      # How often Zabbix will perform update of configuration cache, in seconds.
      # Mandatory: no
      # Range: 1-3600
      # Default:
      # CacheUpdateFrequency=60
      ### Option: StartDBSyncers
      # Number of pre-forked instances of DB Syncers.
      # Mandatory: no
      # Range: 1-100
      # Default:
      # StartDBSyncers=4
      ### Option: HistoryCacheSize
      # Size of history cache, in bytes.
      # Shared memory size for storing history data.
      # Mandatory: no
      # Range: 128K-2G
      # Default:
      # HistoryCacheSize=128MB
      ### Option: HistoryIndexCacheSize
      # Size of history index cache, in bytes.
      # Shared please increase CacheSizememory size for indexing history cache.
      # Mandatory: no
      # Range: 128K-2G
      # Default:
      # HistoryIndexCacheSize=128MB
      ### Option: TrendCacheSize
      # Size of trend write cache, in bytes.
      # Shared memory size for storing trends data.
      # Mandatory: no
      # Range: 128K-2G
      # Default:
      # TrendCacheSize=128MB
      TrendCacheSize=128M
      ### Option: TrendFunctionCacheSize
      # Size of trend function cache, in bytes.
      # Shared memory size for caching calculated trend function data.
      # Mandatory: no
      # Range: 128K-2G
      # Default:
      # TrendFunctionCacheSize=128MB
      ### Option: ValueCacheSize
      # Size of history value cache, in bytes.
      # Shared memory size for caching item history data requests.
      # Setting to 0 disables value cache.
      # Mandatory: no
      # Range: 0,128K-64G
      # Default:
      # ValueCacheSize=128MB
      ValueCacheSize=128M
      ### Option: Timeout
      # Specifies how long we wait for agent, SNMP device or external check (in seconds).
      # Mandatory: no
      # Range: 1-30
      # Default:
      # Timeout=3
      ### Option: TrapperTimeout
      # Specifies how many seconds trapper may spend processing new data.
      # Mandatory: no
      # Range: 1-300
      # Default:
      # TrapperTimeout=300
      ### Option: UnreachablePeriod
      # After how many seconds of unreachability treat a host as unavailable.
      # Mandatory: no
      # Range: 1-3600
      # Default:
      # UnreachablePeriod=45
      ### Option: UnavailableDelay
      # How often host is checked for availability during the unavailability period, in seconds.
      # Mandatory: no
      # Range: 1-3600
      # Default:
      # UnavailableDelay=60
      ### Option: UnreachableDelay
      # How often host is checked for availability during the unreachability period, in seconds.
      # Mandatory: no
      # Range: 1-3600
      # Default:
      # UnreachableDelay=15
      ### Option: AlertScriptsPath
      # Full path to location of custom alert scripts.
      # Default depends on compilation options.
      # To see the default path run command "zabbix_server --help".
      # Mandatory: no
      # Default:
      # AlertScriptsPath=${datadir}/zabbix/alertscripts
      AlertScriptsPath=/usr/lib/zabbix/alertscripts
      ### Option: ExternalScripts
      # Full path to location of external scripts.
      # Mandatory: no
      # Default:
      # ExternalScripts=${datadir}/zabbix/externalscripts
      ExternalScripts=/usr/lib/zabbix/externalscripts
      ### Option: FpingLocation
      # Location of fping.
      # Make sure that fping binary has root ownership and SUID flag set.
      # Mandatory: no
      # Default:
      # FpingLocation=/usr/sbin/fping
      FpingLocation=/usr/bin/fping
      ### Option: Fping6Location
      # Location of fping6.
      # Make sure that fping6 binary has root ownership and SUID flag set.
      # Make empty if your fping utility is capable to process IPv6 addresses.
      # Mandatory: no
      # Default:
      # Fping6Location=/usr/sbin/fping6
      ### Option: SSHKeyLocation
      # Location of public and private keys for SSH checks and actions.
      # Mandatory: no
      # Default:
      # SSHKeyLocation=
      SSHKeyLocation=/var/lib/zabbix/ssh_keys
      ### Option: LogSlowQueries
      # How long a database query may take before being logged (in milliseconds).
      # Only works if DebugLevel set to 3, 4 or 5.
      # 0 - don't log slow queries.
      # Mandatory: no
      # Range: 1-3600000
      # Default:
      # LogSlowQueries=0
      ### Option: TmpDir
      # Temporary directory.
      # Mandatory: no
      # Default:
      # TmpDir=/tmp
      ### Option: StartProxyPollers
      # Number of pre-forked instances of pollers for passive proxies.
      # Mandatory: no
      # Range: 0-250
      # Default:
      # StartProxyPollers=1
      ### Option: ProxyConfigFrequency
      # How often Zabbix Server sends configuration data to a Zabbix Proxy in seconds.
      # This parameter is used only for proxies in the passive mode.
      # Mandatory: no
      # Range: 1-3600*24*7
      # Default:
      # ProxyConfigFrequency=3600
      ### Option: ProxyDataFrequency
      # How often Zabbix Server requests history data from a Zabbix Proxy in seconds.
      # Mandatory: no
      # Range: 1-3600
      # Default:
      # ProxyDataFrequency=1
      ### Option: StartLLDProcessors
      # Number of pre-forked instances of low level discovery processors.
      # Mandatory: no
      # Range: 1-100
      # Default:
      # StartLLDProcessors=2
      ### Option: AllowRoot
      # Allow the server to run as 'root'. If disabled and the server is started by 'root', the server
      # will try to switch to the user specified by the User configuration option instead.
      # Has no effect if started under a regular user.
      # 0 - do not allow
      # 1 - allow
      # Mandatory: no
      # Default:
      # AllowRoot=0
      ### Option: User
      # Drop privileges to a specific, existing user on the system.
      # Only has effect if run as 'root' and AllowRoot is disabled.
      # Mandatory: no
      # Default:
      # User=zabbix
      User=zabbix
      ### Option: Include
      # You may include individual files or all files in a directory in the configuration file.
      # Installing Zabbix will create include directory in /usr/local/etc, unless modified during the compile time.
      # Mandatory: no
      # Default:
      # Include=
      # Include=/usr/local/etc/zabbix_server.general.conf
      # Include=/usr/local/etc/zabbix_server.conf.d/
      # Include=/usr/local/etc/zabbix_server.conf.d/*.conf
      ### Option: SSLCertLocation
      # Location of SSL client certificates.
      # This parameter is used only in web monitoring.
      # Mandatory: no
      # Default:
      # SSLCertLocation=${datadir}/zabbix/ssl/certs
      SSLCertLocation=/var/lib/zabbix/ssl/certs/
      ### Option: SSLKeyLocation
      # Location of private keys for SSL client certificates.
      # Mandatory: no
      # Default:
      # SSLKeyLocation=${datadir}/zabbix/ssl/keys
      SSLKeyLocation=/var/lib/zabbix/ssl/keys/
      ### Option: SSLCALocation
      # Override the location of certificate authority (CA) files for SSL server certificate verification.
      # If not set, system-wide directory will be used.
      # This parameter is used in web monitoring, SMTP authentication, HTTP agent items and for communication with Vault.
      # Mandatory: no
      # Default:
      # SSLCALocation=
      SSLCALocation=/var/lib/zabbix/ssl/ssl_ca/
      ### Option: StatsAllowedIP
      # List of comma delimited IP addresses, optionally in CIDR notation, or DNS names of external Zabbix instances.
      # Stats request will be accepted only from the addresses listed here. If this parameter is not set no stats requests
      # will be accepted.
      # If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally
      # and '::/0' will allow any IPv4 or IPv6 address.
      # '0.0.0.0/0' can be used to allow any IPv4 address.
      # Example: StatsAllowedIP=127.0.0.1,192.168.1.0/24,::1,2001:db8::/32,zabbix.example.com
      # Mandatory: no
      # Default:
      # StatsAllowedIP=
      ####### LOADABLE MODULES #######
      ### Option: LoadModulePath
      # Full path to location of server modules.
      # Mandatory: no
      # Default:
      # LoadModulePath=${libdir}/modules
      LoadModulePath=/var/lib/zabbix/modules/
      # Module to load at server startup. Modules are used to extend functionality of the server.
      # Formats:
      # LoadModule=<module.so>
      # LoadModule=<path/module.so>
      # LoadModule=</abs_path/module.so>
      # Either the module must be located in directory specified by LoadModulePath or the path must precede the module name.
      # If the preceding path is absolute (starts with '/') then LoadModulePath is ignored.
      # It is allowed to include multiple LoadModule parameters.
      # Mandatory: no
      # Default:
      # LoadModule=
      ####### TLS-RELATED PARAMETERS #######
      ### Option: TLSCAFile
      # Full pathname of a file containing the top-level CA(s) certificates for
      # peer certificate verification.
      # Mandatory: no
      # Default:
      # TLSCAFile=
      ### Option: TLSCRLFile
      # Full pathname of a file containing revoked certificates.
      # Mandatory: no
      # Default:
      # TLSCRLFile=
      ### Option: TLSCertFile
      # Full pathname of a file containing the server certificate or certificate chain.
      # Mandatory: no
      # Default:
      # TLSCertFile=
      ### Option: TLSKeyFile
      # Full pathname of a file containing the server private key.
      # Mandatory: no
      # Default:
      # TLSKeyFile=
      ####### For advanced users - TLS ciphersuite selection criteria #######
      ### Option: TLSCipherCert13
      # Cipher string for OpenSSL 1.1.1 or newer in TLS 1.3.
      # Override the default ciphersuite selection criteria for certificate-based encryption.
      # Mandatory: no
      # Default:
      # TLSCipherCert13=
      # GnuTLS priority string or OpenSSL (TLS 1.2) cipher string.
      # Example for GnuTLS:
      # NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
      # Example for OpenSSL:
      # EECDH+aRSA+AES128:RSA+aRSA+AES128
      # Mandatory: no
      # Default:
      # TLSCipherCert=
      ### Option: TLSCipherPSK13
      # Override the default ciphersuite selection criteria for PSK-based encryption.
      # Example:
      # TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA25 6
      # Mandatory: no
      # Default:
      # TLSCipherPSK13=
      # NONE:+VERS-TLS1.2:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL
      # kECDHEPSK+AES128:kPSK+AES128
      # Mandatory: no
      # Default:
      # TLSCipherPSK=
      ### Option: TLSCipherAll13
      # Override the default ciphersuite selection criteria for certificate- and PSK-based encryption.
      # Example:
      # TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA25 6:TLS_AES_128_GCM_SHA256
      # Mandatory: no
      # Default:
      # TLSCipherAll13=
      # NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
      # EECDH+aRSA+AES128:RSA+aRSA+AES128:kECDHEPSK+AES128 :kPSK+AES128
      # Mandatory: no
      # Default:
      # TLSCipherAll=
      ### Option: DBTLSConnect
      # Setting this option enforces to use TLS connection to database.
      # required - connect using TLS
      # verify_ca - connect using TLS and verify certificate
      # verify_full - connect using TLS, verify certificate and verify that database identity specified by DBHost
      # matches its certificate
      # On MySQL starting from 5.7.11 and PostgreSQL following values are supported: "required", "verify_ca" and
      # "verify_full".
      # On MariaDB starting from version 10.2.6 "required" and "verify_full" values are supported.
      # Default is not to set any option and behavior depends on database configuration
      # Mandatory: no
      # Default:
      # DBTLSConnect=
      ### Option: DBTLSCAFile
      # Full pathname of a file containing the top-level CA(s) certificates for database certificate verification.
      # Supported only for MySQL and PostgreSQL
      # Mandatory: no
      # (yes, if DBTLSConnect set to one of: verify_ca, verify_full)
      # Default:
      # DBTLSCAFile=
      ### Option: DBTLSCertFile
      # Full pathname of file containing Zabbix server certificate for authenticating to database.
      # Mandatory: no
      # Default:
      # DBTLSCertFile=
      ### Option: DBTLSKeyFile
      # Full pathname of file containing the private key for authenticating to database.
      # Mandatory: no
      # Default:
      # DBTLSKeyFile=
      ### Option: DBTLSCipher
      # The list of encryption ciphers that Zabbix server permits for TLS protocols up through TLSv1.2
      # Mandatory no
      # Default:
      # DBTLSCipher=
      ### Option: DBTLSCipher13
      # The list of encryption ciphersuites that Zabbix server permits for TLSv1.3 protocol
      # Supported only for MySQL, starting from version 8.0.16
      # Mandatory no
      # Default:
      # DBTLSCipher13=
      ### Option: VaultToken
      # Vault authentication token that should have been generated exclusively for Zabbix server with read only permission
      # to paths specified in Vault macros and read only permission to path specified in optional VaultDBPath
      # configuration parameter.
      # It is an error if VaultToken and VAULT_TOKEN environment variable are defined at the same time.
      # Mandatory: no
      # Default:
      # VaultToken=
      ### Option: VaultURL
      # Vault server HTTP[S] URL. System-wide CA certificates directory will be used if SSLCALocation is not specified.
      # Mandatory: no
      # Default:
      # VaultURL=https://127.0.0.1:8200
      ### Option: VaultDBPath
      # Vault path from where credentials for database will be retrieved by keys 'password' and 'username'.
      # Example: secret/zabbix/database
      # This option can only be used if DBUser and DBPassword are not specified.
      # Mandatory: no
      # Default:
      # VaultDBPath=
      ### Option: StartReportWriters
      # Number of pre-forked report writer instances.
      # Mandatory: no
      # Range: 0-100
      # Default:
      # StartReportWriters=0
      ### Option: WebServiceURL
      # URL to Zabbix web service, used to perform web related tasks.
      # Example: http://localhost:10053/report
      # Mandatory: no
      # Default:
      # WebServiceURL=
      WebServiceURL=http://zabbix-web-service:10053/report
      ### Option: ServiceManagerSyncFrequency
      # How often Zabbix will synchronize configuration of a service manager (in seconds).
      # Mandatory: no
      # Range: 1-3600
      # Default:
      # ServiceManagerSyncFrequency=60
      ### Option: ProblemHousekeepingFrequency
      # How often Zabbix will delete problems for deleted triggers (in seconds).
      # Mandatory: no
      # Range: 1-3600
      # Default:
      # ProblemHousekeepingFrequency=60
      ## Option: StartODBCPollers
      # Number of pre-forked ODBC poller instances.
      # Mandatory: no
      # Range: 0-1000
      # Default:
      # StartODBCPollers=1
      ####### For advanced users - TCP-related fine-tuning parameters #######
      ## Option: ListenBacklog
      # The maximum number of pending connections in the queue. This parameter is passed to
      # listen() function as argument 'backlog' (see "man listen").
      # Mandatory: no
      # Range: 0 - INT_MAX (depends on system, too large values may be silently truncated to implementation-specified maximum)
      # Default: SOMAXCONN (hard-coded constant, depends on system)
      # ListenBacklog=
      ####### High availability cluster parameters #######
      ## Option: HANodeName
      # The high availability cluster node name.
      # When empty, server is working in standalone mode; a node with empty name is registered with address for the frontend to connect to.
      # Mandatory: no
      # Default:
      # HANodeName=
      ## Option: NodeAddress
      # IP or hostname with optional port to specify how frontend should connect to the server.
      # Format: <address>[:<port>]
      # If IP or hostname is not set, then ListenIP value will be used. In case ListenIP is not set, localhost will be used.
      # If port is not set, then ListenPort value will be used. In case ListenPort is not set, 10051 will be used.
      # This option can be overridden by address specified in frontend configuration.
      # Mandatory: no
      # Default:
      # NodeAddress=localhost:10051
      __________________________________________________ __________________________________________________ ____
      File End
      Best regards Michael
      • M-Schmitt
        • Jun 2024
        F.y.i. i did write 128MB, but i didn't work so i changed it to 128M, to see if something happens.
        And my Server got the following stats:
        VCPU: 4
        RAM: 8GB
        DISK LOKAL: 160 GB
        • tim.mooney
          • Dec 2012
          • 1437
          Originally posted by M-Schmitt
          after succesfully upgrading zabbix from 5.0 to 6.0, the server is crashing.
          In short on the upgrade:
          - Was a hellish task
          - Had to delete/create/etc. a lot on Tables/Columns/etc...
          I posit that your problems with Zabbix crashing now are all because you did not have a successful upgrade. If you were manually modifying tables, columns, etc. as part of the upgrade, you likely have a database schema that doesn't match what Zabbix is expecting.
          You should compare your existing database schema to what would have been created if you had fresh-installed Zabbix 6.0.x instead and see where there may be differences. It's highly likely those differences are causing problems.
          • M-Schmitt
            • Jun 2024
            Thank you very much for the prompt reply.
            Could you possibly let me know where I can find such a schema?
            Best regards and many thanks, Michael
            • M-Schmitt
              • Jun 2024
              Good Day,
              i compared my DB Schema with the Schema from the Version 6.0.x. Had to change a lot of keys which were wrong or not there.
              After changing them all succesfully i now get this error messages.
              The Error Messages tell me that there are Unkown, but when i look up the tables the Columns are there and in the comparison DB file.
              I tried to delete it without any success.
              And i have a problem understanding the last error message ('Bad operator (INTEGER): At line 73 in /var/lib/mibs/ietf/SNMPv2-PDU ').
              Thank you in advance Michael
              211:20240611:095148.335 Zabbix agent item "system.swap.size[,free]" on host "Zabbix server" failed: first network error, wait for 15 seconds
              216:20240611:095203.422 Zabbix agent item "system.cpu.util[,system]" on host "Zabbix server" failed: another network error, wait for 15 seconds
              216:20240611:095218.436 Zabbix agent item "system.swap.size[,total]" on host "Zabbix server" failed: another network error, wait for 15 seconds
              216:20240611:095233.447 temporarily disabling Zabbix agent checks on host "Zabbix server": interface unavailable
              193:20240611:102131.287 executing housekeeper
              193:20240611:102132.963 housekeeper [deleted 0 hist/trends, 0 items/triggers, 22932 events, 0 problems, 0 sessions, 0 alarms, 0 audit, 116 autoreg_host, 0 records in 1.666842 sec, idle for 1 hour(s)]
              192:20240611:103525.146 [Z3005] query failed: [1054] Unknown column 'i.username' in 'field list' [select i.itemid,i.name,i.key_,i.type,i.value_type,i.delay ,i.history,i.trends,i.status,i.trapper_hosts,i.uni ts,i.formula,i.logtimefmt,i.valuemapid,i.params,i. ipmi_sensor,i.snmp_oid,i.authtype,i.username,i.pas sword,i.publickey,i.privatekey,i.description,i.int erfaceid,i.jmx_endpoint,i.master_itemid,i.timeout, i.url,i.query_fields,i.posts,i.status_codes,i.foll ow_redirects,i.post_type,i.http_proxy,i.headers,i. retrieve_mode,i.request_method,i.output_format,i.s sl_cert_file,i.ssl_key_file,i.ssl_key_password,i.v erify_peer,i.verify_host,i.allow_traps,i.discover from items i,item_discovery id where i.itemid=id.itemid and id.parent_itemid=39807]
              181:20240611:103537.961 [Z3005] query failed: [1054] Unknown column 'i.username' in 'field list' [select i.itemid,i.hostid,i.status,i.type,i.value_type,i.k ey_,i.snmp_oid,i.ipmi_sensor,i.delay,i.trapper_hos ts,i.logtimefmt,i.params,ir.state,i.authtype,i.use rname,i.password,i.publickey,i.privatekey,i.flags, i.interfaceid,ir.lastlogsize,ir.mtime,i.history,i. trends,i.inventory_link,i.valuemapid,i.units,ir.er ror,i.jmx_endpoint,i.master_itemid,i.timeout,i.url ,i.query_fields,i.posts,i.status_codes,i.follow_re directs,i.post_type,i.http_proxy,i.headers,i.retri eve_mode,i.request_method,i.output_format,i.ssl_ce rt_file,i.ssl_key_file,i.ssl_key_password,i.verify _peer,i.verify_host,i.allow_traps,i.templateid,nul l from items i join item_rtdata ir on i.itemid=ir.itemid inner join hosts h on i.hostid=h.hostid where (h.status=0 or h.status=1) and (i.flags=0 or i.flags=1 or i.flags=4)]
              zabbix_server [181]: ERROR [file and function: <dbconfig.c,DCsync_configuration>, revision:680df72, line:6783] Something impossible has just happened.
              181:20240611:103537.961 === Backtrace: ===
              181:20240611:103537.961 9: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 0.127737 sec, syncing configuration](zbx_backtrace+0x58) [0x64068043a518]
              181:20240611:103537.961 8: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 0.127737 sec, syncing configuration](DCsync_configuration+0x1162) [0x6406803e6192]
              181:20240611:103537.961 7: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 0.127737 sec, syncing configuration](dbconfig_thread+0x362) [0x6406802cc492]
              181:20240611:103537.961 6: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 0.127737 sec, syncing configuration](zbx_thread_start+0x24) [0x64068043cad4]
              181:20240611:103537.961 5: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 0.127737 sec, syncing configuration](+0x7656e) [0x6406802bd56e]
              181:20240611:103537.961 4: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 0.127737 sec, syncing configuration](MAIN_ZABBIX_ENTRY+0x6fb) [0x6406802be43b]
              181:20240611:103537.961 3: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 0.127737 sec, syncing configuration](main+0x547) [0x6406802b5437]
              181:20240611:103537.961 2: /lib/x86_64-linux-gnu/libc.so.6(+0x29d90) [0x7a1734180d90]
              181:20240611:103537.961 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80) [0x7a1734180e40]
              181:20240611:103537.961 0: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 0.127737 sec, syncing configuration](_start+0x25) [0x6406802bc785]
              180:20240611:111337.728 [Z3005] query failed: [1054] Unknown column 'propagation_rule' in 'field list' [select serviceid,status,algorithm,name,weight,propagation _rule,propagation_value from services]
              193:20240611:112133.063 executing housekeeper
              193:20240611:112133.593 housekeeper [deleted 0 hist/trends, 0 items/triggers, 22925 events, 0 problems, 0 sessions, 0 alarms, 0 audit, 0 autoreg_host, 0 records in 0.521663 sec, idle for 1 hour(s)]
              7:20240611:114636.497 Got signal [signal:15(SIGTERM),sender_pid:1,sender_uid:1997,re ason:0]. Exiting ...
              179:20240611:114637.100 HA manager has been paused
              199:20240611:114637.101 syncing history data in progress...
              199:20240611:114637.101 syncing history data done
              179:20240611:114638.140 HA manager has been stopped
              7:20240611:114638.213 syncing trend data...
              7:20240611:114638.220 syncing trend data done
              7:20240611:114638.224 Zabbix Server stopped. Zabbix 6.0.30 (revision 680df72).
              ** Preparing Zabbix server
              ** Preparing database
              ** Using MYSQL_USER variable from secret file
              ** Using MYSQL_PASSWORD variable from secret file
              * DB_SERVER_HOST: mysql-server
              * DB_SERVER_PORT: 3306
              * DB_SERVER_DBNAME: zabbix
              ** Database 'zabbix' already exists. Please be careful with database COLLATE!
              ** Table 'zabbix.dbversion' already exists.
              ** Preparing Zabbix server configuration file
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ListenIP": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ListenPort": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ListenBacklog": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "SourceIP": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "LogType": 'console'...updated
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "LogFile": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "LogFileSize": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "PidFile": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DebugLevel": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBHost": 'mysql-server'...updated
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBPort": '3306'...updated
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBSocket": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBName": 'zabbix'...updated
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBSchema": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "VaultDBPath": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "VaultURL": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBUser": 'zabbix'...updated
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBPassword": '****'. Enable DEBUG_MODE to view value ...updated
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "AllowUnsupportedDBVersions": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartReportWriters": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "WebServiceURL": 'http://zabbix-web-service:10053/report'...updated
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HistoryStorageURL": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HistoryStorageTypes": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HistoryStorageDateIndex": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StatsAllowedIP": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartPollers": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartIPMIPollers": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartPollersUnreachable": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartTrappers": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartPingers": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartDiscoverers": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartHistoryPollers": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartHTTPPollers": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartODBCPollers": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartPreprocessors": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartTimers": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartEscalators": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartAlerters": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartLLDProcessors": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "JavaGateway": 'zabbix-java-gateway'...updated
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "JavaGatewayPort": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartJavaPollers": '5'...updated
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartVMwareCollectors": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "VMwareFrequency": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "VMwarePerfFrequency": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "VMwareCacheSize": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "VMwareTimeout": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "SNMPTrapperFile": '/var/lib/zabbix/snmptraps/snmptraps.log'...updated
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartSNMPTrapper": '1'...updated
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HousekeepingFrequency": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "MaxHousekeeperDelete": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ProblemHousekeepingFrequency": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "CacheSize": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "CacheUpdateFrequency": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartDBSyncers": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HistoryCacheSize": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HistoryIndexCacheSize": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TrendCacheSize": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TrendFunctionCacheSize": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ValueCacheSize": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "Timeout": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TrapperTimeout": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "UnreachablePeriod": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "UnavailableDelay": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "UnreachableDelay": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "AlertScriptsPath": '/usr/lib/zabbix/alertscripts'...updated
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ExternalScripts": '/usr/lib/zabbix/externalscripts'...updated
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "FpingLocation": '/usr/bin/fping'...updated
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "Fping6Location": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "SSHKeyLocation": '/var/lib/zabbix/ssh_keys'...updated
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "LogSlowQueries": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartProxyPollers": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ProxyConfigFrequency": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ProxyDataFrequency": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "SSLCertLocation": '/var/lib/zabbix/ssl/certs/'...updated
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "SSLKeyLocation": '/var/lib/zabbix/ssl/keys/'...updated
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "SSLCALocation": '/var/lib/zabbix/ssl/ssl_ca/'...updated
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "LoadModulePath": '/var/lib/zabbix/modules/'...updated
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCAFile": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCRLFile": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCertFile": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCipherAll": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCipherAll13": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCipherCert": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCipherCert13": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCipherPSK": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCipherPSK13": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSKeyFile": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSPSKIdentity": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSPSKFile": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ServiceManagerSyncFrequency": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HANodeName": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "NodeAddress": ''...removed
              ** Updating '/etc/zabbix/zabbix_server.conf' parameter "User": 'zabbix'...updated
              Starting Zabbix Server. Zabbix 6.0.30 (revision 680df72).
              Press Ctrl+C to exit.
              7:20240611:114643.469 Starting Zabbix Server. Zabbix 6.0.30 (revision 680df72).
              7:20240611:114643.469 ****** Enabled features ******
              7:20240611:114643.469 SNMP monitoring: YES
              7:20240611:114643.469 IPMI monitoring: YES
              7:20240611:114643.469 Web monitoring: YES
              7:20240611:114643.469 VMware monitoring: YES
              7:20240611:114643.469 SMTP authentication: YES
              7:20240611:114643.469 ODBC: YES
              7:20240611:114643.469 SSH support: YES
              7:20240611:114643.469 IPv6 support: YES
              7:20240611:114643.469 TLS support: YES
              7:20240611:114643.469 ******************************
              7:20240611:114643.469 using configuration file: /etc/zabbix/zabbix_server.conf
              7:20240611:114643.520 current database version (mandatory/optional): 06000000/06000044
              7:20240611:114643.520 required mandatory version: 06000000
              7:20240611:114643.541 database could be upgraded to use primary keys in history tables
              179:20240611:114643.561 starting HA manager
              179:20240611:114643.572 HA manager started in active mode
              7:20240611:114643.573 server #0 started [main process]
              180:20240611:114643.573 server #1 started [service manager #1]
              181:20240611:114643.574 server #2 started [configuration syncer #1]
              182:20240611:114643.696 server #3 started [alert manager #1]
              183:20240611:114643.696 server #4 started [alerter #1]
              184:20240611:114643.697 server #5 started [alerter #2]
              185:20240611:114643.697 server #6 started [alerter #3]
              186:20240611:114643.698 server #7 started [preprocessing manager #1]
              187:20240611:114643.698 server #8 started [preprocessing worker #1]
              188:20240611:114643.699 server #9 started [preprocessing worker #2]
              189:20240611:114643.699 server #10 started [preprocessing worker #3]
              190:20240611:114643.700 server #11 started [lld manager #1]
              191:20240611:114643.701 server #12 started [lld worker #1]
              192:20240611:114643.701 server #13 started [lld worker #2]
              193:20240611:114643.702 server #14 started [housekeeper #1]
              194:20240611:114643.703 server #15 started [timer #1]
              195:20240611:114643.706 server #16 started [http poller #1]
              196:20240611:114643.706 server #17 started [discoverer #1]
              197:20240611:114643.733 server #18 started [history syncer #1]
              199:20240611:114643.736 server #20 started [history syncer #3]
              202:20240611:114643.740 server #23 started [java poller #1]
              198:20240611:114643.740 server #19 started [history syncer #2]
              200:20240611:114643.740 server #21 started [history syncer #4]
              203:20240611:114643.741 server #24 started [java poller #2]
              201:20240611:114643.741 server #22 started [escalator #1]
              204:20240611:114643.742 server #25 started [java poller #3]
              205:20240611:114643.749 server #26 started [java poller #4]
              207:20240611:114643.750 server #28 started [snmp trapper #1]
              206:20240611:114643.751 server #27 started [java poller #5]
              208:20240611:114643.753 server #29 started [proxy poller #1]
              209:20240611:114643.835 server #30 started [self-monitoring #1]
              210:20240611:114643.835 server #31 started [task manager #1]
              211:20240611:114643.844 server #32 started [poller #1]
              212:20240611:114643.848 server #33 started [poller #2]
              213:20240611:114643.850 server #34 started [poller #3]
              214:20240611:114643.852 server #35 started [poller #4]
              217:20240611:114643.856 server #38 started [trapper #1]
              218:20240611:114643.858 server #39 started [trapper #2]
              215:20240611:114643.858 server #36 started [poller #5]
              216:20240611:114643.933 server #37 started [unreachable poller #1]
              219:20240611:114643.937 server #40 started [trapper #3]
              220:20240611:114643.939 server #41 started [trapper #4]
              221:20240611:114643.939 server #42 started [trapper #5]
              222:20240611:114643.942 server #43 started [icmp pinger #1]
              224:20240611:114643.944 server #45 started [history poller #1]
              223:20240611:114643.945 server #44 started [alert syncer #1]
              225:20240611:114643.948 server #46 started [history poller #2]
              226:20240611:114643.950 server #47 started [history poller #3]
              227:20240611:114643.952 server #48 started [history poller #4]
              228:20240611:114644.033 server #49 started [history poller #5]
              230:20240611:114644.036 server #51 started [trigger housekeeper #1]
              229:20240611:114644.040 server #50 started [availability manager #1]
              231:20240611:114644.046 server #52 started [odbc poller #1]
              • tim.mooney
                • Dec 2012
                • 1437
                You're still missing things in your schema that should have been created by the automated upgrade process.
                Since it appears that you're using MySQL or a MySQL-compatible database server, you might want to consider taking the database schema file for your version of Zabbix and creating a new database with a different name, maybe something like zabbix_correct, then import the schema into that second database so all the tables and objects are created. Once you have this second database with known good schema, you can use a tool like 'mysqldiff' to compare your existing database to the temporary database with the correct schema. That may help you find additional areas where your database doesn't match what it should be.
                However, if columns, relations, or entire tables were missing and you manually created them, isn't it also possible that your data is now incorrect or incomplete? I would worry that even if you manage to "fix" your database so it has all the tables, columns, indexes, etc. that Zabbix expects, it might still be possible that the data in those tables is not correct or complete.
                My advice would be to figure out why you had problems upgrading from 5.0, fix those problems and re-do the upgrade so that the automated database upgrade works correctly.
