Template import issue
  • gbiondi
    • Nov 2016
    • 75
    importing this template: zbx-upc-apc-smart-rt.xml I receive a 'import error' with this..
    Details–Created: Application "Information(s)" on "ZBX-APC-SMART-RT".
    –Created: Application "Operational" on "ZBX-APC-SMART-RT".
    –Cannot find value map "apcBatteryReplaceIndicator" used for item "Battery replacement status" on "ZBX-APC-SMART-RT".
    the key is 'apcBatteryReplaceIndicator' but I don't have idea how create this value map.. have some hints?
    All the best.
  • LenR
    • Sep 2009
    • 1011
    Administration panel, general tab, value maps in the selection area in the upper right. If you can create at 1 value, that is enough to import the template.
    • LenR
      • Sep 2009
      • 1011
      I have that mapping, maybe it's the same:
      1 ⇒ unknown
      2 ⇒ notInstalled
      3 ⇒ ok
      4 ⇒ failed
      5 ⇒ highTemperature
      6 ⇒ replaceImmediately
      7 ⇒ lowCapacity
