After Upgrade to 7.0, optional language works not (german)
  • Simon74
    • Oct 2021
    I have successfully updated to 7.0.
    However, I cannot switch to German.
    I have followed the article:
    root@zab /etc/zabbix > locale -a
    C
    C.utf8
    POSIX
    de_DE.utf8
    en_US.utf8
    root@zab /etc/zabbix > locale-gen
    Generating locales (this might take a while)...
      de_DE.UTF-8... done
      en_US.UTF-8... done
    Generation complete.
    I can successfully execute the commands and then change the language under Administration/General/GUI, but nothing happens. And yes in the user settings I have set to system-default.
    ps. Also, I can no longer find the setting for the 24-hour time format?
  • Markku
    • Sep 2018
    • 1788
    I am also unable to get 24-hour time format when trying to enable en_GB (instead of the default en_US).
    I opened ZBX-24659 (shortlink to Zabbix support portal) for that.
    Markku
    • Simon74
      Simon74 commented
      Thanks for info
  • markosa
    • Aug 2022
    • 107
    Regarding timeformat, just upgraded from 6.0.31 to 7.0, but before made upgrade changed en_US to en_GB and then upgraded, and 24h timeformat works ok. Ofcourse there was OS upgrade before Zabbix upgrade too(CentOS 8 Stream to 9 Stream)
