How to create graph from wireless signal (negative)
  • tomasi
    • Nov 2016
    • 15
    This is my first post
    I need help to solve the following issue:
    I got some OID from Mimosa Site:
    Then, I've created 4 items, one for each of these OID:
    HTML Code:
    1.3.6.1.4.1.43356.2.1.2.6.1.1.3.1 	mimosaRxPower.1
    1.3.6.1.4.1.43356.2.1.2.6.1.1.3.2	mimosaRxPower.2
    1.3.6.1.4.1.43356.2.1.2.6.1.1.3.3	mimosaRxPower.3
    1.3.6.1.4.1.43356.2.1.2.6.1.1.3.4	mimosaRxPower.4
    Type of information: numeric (unsigned)
    Data type: decimal
    Store value: as is
    Show value: as is
    After that, I've created a graph that have these 4 items together
    But... the graph, after 12h, is not showing any information.
    Then, I've made a snmpget to see if these OID really return a value. They are correct.
    root@zabbix:~# snmpget -v1 -cpublic 172.16.200.170 1.3.6.1.4.1.43356.2.1.2.6.1.1.3.1
    iso.3.6.1.4.1.43356.2.1.2.6.1.1.3.1 = INTEGER: -61
    root@zabbix:~# snmpget -v1 -cpublic 172.16.200.170 1.3.6.1.4.1.43356.2.1.2.6.1.1.3.2
    iso.3.6.1.4.1.43356.2.1.2.6.1.1.3.2 = INTEGER: -61
    root@zabbix:~#
    These OID are intendend to show wireless receive signal - in negative numbers, like -40dbm or -80dBm.
    Which point is wrong? I didn't find a way to solve this yet
    I'm using Zabbix 3.2.1
    Thank you!
  • tomasi
    • Nov 2016
    • 15
    Solved
    I solved this issue changing the Type of Information to Numeric (float)
    Now, it's ok - showing values from -50dBm to -70dBm
