Zabbix 7.0: Dashboard - No permissions to referred object or it does not exist!
  • muelli
    • Jun 2021
    • 69
    Hello forum,
    I have a User that cannot see the default Dashboards that come with the "Linux Zabbix Agent Active" Template.
    It just shows the error "No permissions to referred object or it does not exist!"
    However I think the User has all the needed permissions:
    -Role User (Access to UI elements Dashboards)
    -R/W Access to the hosts in the hostgroup
    The user can access all the host data/latest data without problem.
    For testing I put the User into the "Admin Role" but still the same error.
    Also, when selecting "Dashboards" from the menu on the left, he has no permission to edit his dashboard on the top left. The button is visible but disabled.
    Can someone give me a hint?
  • muelli
    • Jun 2021
    • 69
    This problem is solved. The other problem with the Template/Host Dashboards is still unsolved.
    I came across this post:
    https://serverfault.com/questions/11...upgrade-to-6-4
    Which describes the problem I seem to have with 7.0, but the User has all the needed permissions to the modules set (all modules in fact).
    This is really puzzling.
    Maybe this problem here is still persisting in 7.0?
