Snmptrapd don't catch all traps (but seen in tcpdump)
  • Fenris
    • Jun 2024
    Hi everyone,
    I'm new to the zabbix environment so please forgive me if I make mistakes ^^
    I have deployed a zabbix server and a zabbix proxy which are on two different networks (interconnected via wireguard).
    On my zabbix_proxy I work with snmp traps only (I don't have access to the devices I'm monitoring).
    So I've deployed snmptrapd and snmptt.
    I capture and translate some traps correctly (CPU Threshold, Link UP/Down for example).
    But for some devices, my snmptrapd doesn't capture traps that seem to be the same as other traps. I can't see anything in the snmp logs (which are at maximum debug level), but I can see the traps in tcpdump. An example below:
    This trap is correctly captured and translated by snmp :
    17:33:56.006773 eth0 In IP 10.250.19.129.162 > 10.250.7.10.162: C="public" V2Trap(205) .1.3.6.1.2.1.1.3.0=261164752 .1.3.6.1.6.3.1.1.4.1.0=.1.3.6.1.6.3.1.1.5.4 .1.3.6.1.2.1.2.2.1.1.15=15 .1.3.6.1.2.1.2.2.1.7.15=1 .1.3.6.1.2.1.2.2.1.8.15=1 .1.3.6.1.4.1.12356.100.1.1.1.0="MODEL" .1.3.6.1.2.1.1.5.0="HOSTNAME" .1.3.6.1.2.1.31.1.1.1.1.15="internal8" .1.3.6.1.2.1.2.2.1.2.15=""
    And this one is just captured in my tcpdump but doesn't appear in snmp:
    17:34:12.012959 eth0 In IP 10.250.8.253.162 > 10.250.7.10.162: C="public" V2Trap(204) .1.3.6.1.2.1.1.3.0=1130382605 .1.3.6.1.6.3.1.1.4.1.0=.1.3.6.1.6.3.1.1.5.4 .1.3.6.1.2.1.2.2.1.1.22=22 .1.3.6.1.2.1.2.2.1.7.22=1 .1.3.6.1.2.1.2.2.1.8.22=1 .1.3.6.1.4.1.12356.100.1.1.1.0="MODEL" .1.3.6.1.2.1.1.5.0="HOSTNAME" .1.3.6.1.2.1.31.1.1.1.1.22="port10" .1.3.6.1.2.1.2.2.1.2.22=""
    I have this problem for some traps and I don't understand why.
    I don't have any problems in journalctl of the different daemons.
    Thank you in advance for your help.
  • Fenris
    • Jun 2024
    Hi there,
    Can anyone help me solve this snmp trap problem with the SNMPTT module?
    Thank you in advance.
    • tim.mooney
      • Dec 2012
      • 1434
      When you say "...but doesn't appear in snmp", what do you mean?
      Current versions of Zabbix use an intermediate file as a kind of "queue" of SNMP traps. If snmptrapd doesn't write some information to that file for a TRAP that it receives, then Zabbix will never see it.
      So, the big question is whether snmptrapd wrote something to the intermediate file for the TRAPs in question? If snmptrapd didn't write something to that file, then the problem is not with Zabbix, it's somewhere with the initial reception.
      If snmptrapd did use snmptt to write to the intermediate file, but Zabbix didn't see it, then the problem is with your Zabbix config.
      snmptrapd listens on a UDP port, not TCP. The second packet capture you show above proves that the packets were on the network, but it's not clear to me whether that proves that the packets were received by snmptrapd. The 2nd TRAP is from a different host on a different network. Is it possible a firewall or something else may have blocked reception of those packets by your snmptrapd?
