Zabbix Agent Active: Trigger System time is out of sync not working!
  • rockandstone
    • Mar 2021
    • 24
    Good morning everyone. I would like to raise a case:
    • Zabbix Server installed on Ubuntu 22.04 with Postgresql as DB (Zabbix version 6.4.5)
    • Official Zabbix active agent template for Linux
    • Item: System local time (system.localtime) of active type
    • Trigger: “System time is out of sync” that uses fuzzytime
    I had a serious problem on a server with the time monitored through an installed and working active agent (6.4): I was not notified about the wrong system time of the Linux server.
    I know fuzzytime's function (immediately checked the time on the server, db, fe, be, correctly synchronized with the NTP server) and the trigger.
    There is a problem: fuzzytime only works with passive checks!
    Using the active Zabbix Agent and the related template, the item "System local time" is a Zabbix active checks
    How can we solve this in case an active agent is used to have a working trigger comparable to the passive one “System time is out of sync”?
    Thank you,
    Best Regard.
