I can't monitor some specific process in windows
  • RoyPeng
    • Dec 2016
    I need to monitor SQL Server SQL agent process: DTExec.exe,
    And I used a command below:
    C:\Zabbix> zabbix_agentd.exe -t proc_info[DTExec.exe,wkset,sum]
    proc_info[DTExec.exe,wkset,sum] [d|0.000000]
    I always get zero, but I'm sure it's running.
    And I can sure I used the currect agentd version(x64) on server.
    Can someone help me solve this troubled me for several days of the problem?
    Thanks.
    (Zabbix Version 3.2)
  • GPegel
    • Dec 2015
    • 113
    Have you tried using proc.num instead of proc_info?
