different (not multiple sort of...ips) for zabbix concentrator
  • samuellsk
    • Jun 2024
    Hellou
    Due to some unforseen events I need to have 2 (but not at the same time) different ips on a zabbix concentrator where other proxies (their ip is not changing) are sending their data.
    So 1 zabbix server (that for example this week has ip A , and in the next week might get ip A or might get ip B , but always having either A or B ... there is NO C , D...etc..)
    A lot of proxies sending data.
    Question is:
    Will data get duplicated if proxy is unable to send to one of the server IPs specified ? Than suddenly next day or next week this ip is going to get online ?
    Am i supposed to be expecting some anomalies ?
    Thank you
  • Markku
    • Sep 2018
    • 1788
    I think you should be fine when using the semicolon-separated server addresses in proxy configurations:
    The proxies will then try the first IP, and if it doesn't work, it will try the second, and revert back to the first one again if needed. There shouldn't be any duplicates.
    Markku
