Zabbix 7.0 crashing after upgrade from 6.0 LTS (Debian 12 / postgres + timescaledb)
  • MikansOnTap456
    • Jun 2024
    Hi all,
    I've performed an upgrade from Zabbix 6.0 LTS to 7.0 LTS.
    I am running Debian 12 with postgres + timescaledb. The Zabbix upgrade was preceded by a postgres upgrade from 13 to 16.
    Here is the upgrade steps I went through:
    1. Upgrade timescaledb extension in existing postgres 13 to latest version available, verified Zabbix 6 still running fine at this point
    2. Install postgres 16
    3. Migrate existing zabbix database from postgres 13 to postgres 16 (no errors reported here), followed by vaccumdb and reindexing, verified Zabbix 6 still running fine at this point
    4. Upgrade timescaledb extension again, this time to the latest version available for postgres 16, verified Zabbix 6 still running fine at this point
    5. Upgraded Zabbix from 6.0 to 7.0
    6. Applied the new timescaledb\schema.sql file to the postgres 16 database.
    7. Start Zabbix server, crashes with below output
    The crash seems to be occurring on a particular database query, but beyond that, I have no idea how to further diagnose or resolve this issue. Would greatly appreciate some help.
    I'm aware the log is reporting that my timescaledb version is too high, however this same version was working under 6.0 and furthermore I have seen other people reporting that this version is working for them under 7.0 as well. I changed the flag in the zabbix_server.conf file to allow unsupported DB versions.
    I have a debug level log output more detailed than the one below, but I can't seem to attach it as the file is too big.
     21636:20240628:165538.315 Starting Zabbix Server. Zabbix 7.0.0 (revision 49955f1fb5c).
     21636:20240628:165538.315 ****** Enabled features ******
     21636:20240628:165538.315 SNMP monitoring:           YES
     21636:20240628:165538.315 IPMI monitoring:           YES
     21636:20240628:165538.315 Web monitoring:            YES
     21636:20240628:165538.315 VMware monitoring:         YES
     21636:20240628:165538.315 SMTP authentication:       YES
     21636:20240628:165538.315 ODBC:                      YES
     21636:20240628:165538.315 SSH support:               YES
     21636:20240628:165538.315 IPv6 support:              YES
     21636:20240628:165538.315 TLS support:               YES
     21636:20240628:165538.315 ******************************
     21636:20240628:165538.315 using configuration file: /etc/zabbix/zabbix_server.conf
     21636:20240628:165538.412 Unsupported DB! timescaledb version 21502 is newer than 21499
     21636:20240628:165538.412 TimescaleDB version is too new. Recommended version is up to TimescaleDB Community Edition 2.14.
     21636:20240628:165538.452 current database version (mandatory/optional): 07000000/07000000
     21636:20240628:165538.453 required mandatory version: 07000000
     21637:20240628:165538.555 starting HA manager
     21637:20240628:165538.584 HA manager started in active mode
     21636:20240628:165538.586 server #0 started [main process]
     21638:20240628:165538.587 server #1 started [service manager #1]
     21639:20240628:165538.587 server #2 started [configuration syncer #1]
     21639:20240628:165539.086 Got signal [signal:11(SIGSEGV),reason:1,refaddr:(nil)]. Crashing ...
     21639:20240628:165539.086 ====== Fatal information: ======
     21639:20240628:165539.086 Program counter: 0x56038a838ee0
     21639:20240628:165539.086 === Registers: ===
     21639:20240628:165539.086 r8      =     7fc62ce78cc0 =      140489133624512 =      140489133624512
     21639:20240628:165539.086 r9      =               40 =                   64 =                   64
     21639:20240628:165539.086 r10     =                0 =                    0 =                    0
     21639:20240628:165539.086 r11     =               20 =                   32 =                   32
     21639:20240628:165539.086 r12     =     7ffc7aaefda9 =      140722366774697 =      140722366774697
     21639:20240628:165539.086 r13     =     7ffc7aaefd68 =      140722366774632 =      140722366774632
     21639:20240628:165539.086 r14     =     7ffc7aaefcf8 =      140722366774520 =      140722366774520
     21639:20240628:165539.086 r15     =     7ffc7aaefd08 =      140722366774536 =      140722366774536
     21639:20240628:165539.086 rdi     =     7ffc7aaefd68 =      140722366774632 =      140722366774632
     21639:20240628:165539.086 rsi     =                0 =                    0 =                    0
     21639:20240628:165539.086 rbp     =     7fc5e7239ae0 =      140487963155168 =      140487963155168
     21639:20240628:165539.086 rbx     =     7ffc7aaefd60 =      140722366774624 =      140722366774624
     21639:20240628:165539.086 rdx     =     7ffc7aaefda8 =      140722366774696 =      140722366774696
     21639:20240628:165539.086 rax     =               41 =                   65 =                   65
     21639:20240628:165539.086 rcx     =                0 =                    0 =                    0
     21639:20240628:165539.086 rsp     =     7ffc7aaefc58 =      140722366774360 =      140722366774360
     21639:20240628:165539.086 rip     =     56038a838ee0 =       94573208768224 =       94573208768224
     21639:20240628:165539.086 efl     =            10202 =                66050 =                66050
     21639:20240628:165539.086 csgsfs  =   2b000000000033 =    12103423998558259 =    12103423998558259
     21639:20240628:165539.086 err     =                4 =                    4 =                    4
     21639:20240628:165539.086 trapno  =                e =                   14 =                   14
     21639:20240628:165539.086 oldmask =                0 =                    0 =                    0
     21639:20240628:165539.086 cr2     =                0 =                    0 =                    0
     21639:20240628:165539.086 === Backtrace: ===
     21639:20240628:165539.088 18: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_backtrace+0x3b) [0x56038a81151b]
     21639:20240628:165539.088 17: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_log_fatal_info+0x17d) [0x56038a81178d]
     21639:20240628:165539.088 16: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x3c2e46) [0x56038a811e46]
     21639:20240628:165539.088 15: /lib/x86_64-linux-gnu/libc.so.6(+0x3c050) [0x7fc62cce2050]
     21639:20240628:165539.088 14: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_strlcpy+0x30) [0x56038a838ee0]
     21639:20240628:165539.088 13: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCget_interface+0x38) [0x56038a6bb3f8]
     21639:20240628:165539.088 12: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_dc_config_get_interface_by_type+0x4f) [0x56038a6bdc5f]
     21639:20240628:165539.088 11: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x26ef0b) [0x56038a6bdf0b]
     21639:20240628:165539.088 10: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x26eff5) [0x56038a6bdff5]
     21639:20240628:165539.088 9: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x26f623) [0x56038a6be623]
     21639:20240628:165539.089 8: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_dc_sync_configuration+0x2a4b) [0x56038a6c9e3b]
     21639:20240628:165539.089 7: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](dbconfig_thread+0xeb) [0x56038a52519b]
     21639:20240628:165539.089 6: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_thread_start+0x20) [0x56038a746170]
     21639:20240628:165539.089 5: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0xcf26b) [0x56038a51e26b]
     21639:20240628:165539.089 4: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](MAIN_ZABBIX_ENTRY+0xefa) [0x56038a51f89a]
     21639:20240628:165539.089 3: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](main+0x37e) [0x56038a513b0e]
     21639:20240628:165539.089 2: /lib/x86_64-linux-gnu/libc.so.6(+0x2724a) [0x7fc62cccd24a]
     21639:20240628:165539.089 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7fc62cccd305]
     21639:20240628:165539.089 0: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](_start+0x21) [0x56038a51ab61]
     21639:20240628:165539.089 === Memory map: ===
     21639:20240628:165539.089 56038a44f000-56038a50c000 r--p 00000000 08:01 785234                     /usr/sbin/zabbix_server
     21639:20240628:165539.089 56038a50c000-56038a844000 r-xp 000bd000 08:01 785234                     /usr/sbin/zabbix_server
     21639:20240628:165539.089 56038a844000-56038a977000 r--p 003f5000 08:01 785234                     /usr/sbin/zabbix_server
     21639:20240628:165539.089 56038a977000-56038a97b000 r--p 00528000 08:01 785234                     /usr/sbin/zabbix_server
     21639:20240628:165539.089 56038a97b000-56038aa7a000 rw-p 0052c000 08:01 785234                     /usr/sbin/zabbix_server
     21639:20240628:165539.089 56038aa7a000-56038aa8c000 rw-p 00000000 00:00 0
     21639:20240628:165539.089 56038c240000-56038c282000 rw-p 00000000 00:00 0                          [heap]
     21639:20240628:165539.089 56038c282000-56038c339000 rw-p 00000000 00:00 0                          [heap]
     21639:20240628:165539.089 56038c339000-56038ec6b000 rw-p 00000000 00:00 0                          [heap]
     21639:20240628:165539.089 7fc5e26a7000-7fc5e2728000 rw-p 00000000 00:00 0
     21639:20240628:165539.089 7fc5e2769000-7fc5e282c000 rw-p 00000000 00:00 0
     21639:20240628:165539.089 7fc5e282c000-7fc5e286c000 rw-s 00000000 00:01 917561                     /SYSV00000000 (deleted)
     21639:20240628:165539.089 7fc5e286c000-7fc5e306c000 rw-s 00000000 00:01 917560                     /SYSV00000000 (deleted)
     21639:20240628:165539.089 7fc5e306c000-7fc5e706c000 rw-s 00000000 00:01 917559                     /SYSV00000000 (deleted)
     21639:20240628:165539.089 7fc5e706c000-7fc5e708c000 rw-s 00000000 00:01 917558                     /SYSV00000000 (deleted)
     21639:20240628:165539.089 7fc5e708c000-7fc62708c000 rw-s 00000000 00:01 917557                     /SYSV00000000 (deleted)
     21639:20240628:165539.089 7fc62708c000-7fc62788c000 rw-s 00000000 00:01 917556                     /SYSV00000000 (deleted)
     21639:20240628:165539.089 7fc62788c000-7fc62808c000 rw-s 00000000 00:01 917555                     /SYSV00000000 (deleted)
     21639:20240628:165539.089 7fc62808c000-7fc62a08c000 rw-s 00000000 00:01 917554                     /SYSV00000000 (deleted)
     21639:20240628:165539.089 7fc62a08c000-7fc62a08f000 r--p 00000000 08:01 785406                     /usr/lib/x86_64-linux-gnu/libcap.so.2.66
     21639:20240628:165539.089 7fc62a08f000-7fc62a094000 r-xp 00003000 08:01 785406                     /usr/lib/x86_64-linux-gnu/libcap.so.2.66
     21639:20240628:165539.089 7fc62a094000-7fc62a096000 r--p 00008000 08:01 785406                     /usr/lib/x86_64-linux-gnu/libcap.so.2.66
     21639:20240628:165539.089 7fc62a096000-7fc62a097000 r--p 0000a000 08:01 785406                     /usr/lib/x86_64-linux-gnu/libcap.so.2.66
     21639:20240628:165539.089 7fc62a097000-7fc62a098000 rw-p 0000b000 08:01 785406                     /usr/lib/x86_64-linux-gnu/libcap.so.2.66
     21639:20240628:165539.089 7fc62a098000-7fc62a09f000 r--p 00000000 08:01 785613                     /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
     21639:20240628:165539.089 7fc62a09f000-7fc62a0d3000 r-xp 00007000 08:01 785613                     /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
     21639:20240628:165539.089 7fc62a0d3000-7fc62a0e3000 r--p 0003b000 08:01 785613                     /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
     21639:20240628:165539.089 7fc62a0e3000-7fc62a0e7000 r--p 0004b000 08:01 785613                     /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
     21639:20240628:165539.089 7fc62a0e7000-7fc62a0e8000 rw-p 0004f000 08:01 785613                     /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
     21639:20240628:165539.089 7fc62a0e8000-7fc62a0f3000 r--p 00000000 08:01 786216                     /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
     21639:20240628:165539.089 7fc62a0f3000-7fc62a150000 r-xp 0000b000 08:01 786216                     /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
     21639:20240628:165539.089 7fc62a150000-7fc62a167000 r--p 00068000 08:01 786216                     /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
     21639:20240628:165539.089 7fc62a167000-7fc62a168000 r--p 0007f000 08:01 786216                     /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
     21639:20240628:165539.089 7fc62a168000-7fc62a169000 rw-p 00080000 08:01 786216                     /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
     21639:20240628:165539.089 7fc62a169000-7fc62a172000 r--p 00000000 08:01 786003                     /usr/lib/x86_64-linux-gnu/libhogweed.so.6.6
     21639:20240628:165539.089 7fc62a172000-7fc62a185000 r-xp 00009000 08:01 786003                     /usr/lib/x86_64-linux-gnu/libhogweed.so.6.6
     21639:20240628:165539.089 7fc62a185000-7fc62a1af000 r--p 0001c000 08:01 786003                     /usr/lib/x86_64-linux-gnu/libhogweed.so.6.6
     21639:20240628:165539.089 7fc62a1af000-7fc62a1b1000 r--p 00045000 08:01 786003                     /usr/lib/x86_64-linux-gnu/libhogweed.so.6.6
     21639:20240628:165539.090 7fc62a1b1000-7fc62a1b2000 rw-p 00047000 08:01 786003                     /usr/lib/x86_64-linux-gnu/libhogweed.so.6.6
     21639:20240628:165539.090 7fc62a1b2000-7fc62a1bf000 r--p 00000000 08:01 785784                     /usr/lib/x86_64-linux-gnu/libnettle.so.8.6
     21639:20240628:165539.090 7fc62a1bf000-7fc62a1e6000 r-xp 0000d000 08:01 785784                     /usr/lib/x86_64-linux-gnu/libnettle.so.8.6
     21639:20240628:165539.090 7fc62a1e6000-7fc62a1fd000 r--p 00034000 08:01 785784                     /usr/lib/x86_64-linux-gnu/libnettle.so.8.6
     21639:20240628:165539.090 7fc62a1fd000-7fc62a1ff000 r--p 0004b000 08:01 785784                     /usr/lib/x86_64-linux-gnu/libnettle.so.8.6
     21639:20240628:165539.090 7fc62a1ff000-7fc62a200000 rw-p 0004d000 08:01 785784                     /usr/lib/x86_64-linux-gnu/libnettle.so.8.6
     21639:20240628:165539.090 7fc62a200000-7fc62a299000 r--p 00000000 08:01 784908                     /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30
     21639:20240628:165539.090 7fc62a299000-7fc62a39a000 r-xp 00099000 08:01 784908                     /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30
     21639:20240628:165539.090 7fc62a39a000-7fc62a409000 r--p 0019a000 08:01 784908                     /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30
     21639:20240628:165539.090 7fc62a409000-7fc62a414000 r--p 00209000 08:01 784908                     /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30
     21639:20240628:165539.090 7fc62a414000-7fc62a417000 rw-p 00214000 08:01 784908                     /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30
     21639:20240628:165539.090 7fc62a417000-7fc62a41a000 rw-p 00000000 00:00 0
     21639:20240628:165539.090 7fc62a41f000-7fc62a42d000 rw-p 00000000 00:00 0
     21639:20240628:165539.090 7fc62a42d000-7fc62a42f000 r--p 00000000 08:01 785623                     /usr/lib/x86_64-linux-gnu/libffi.so.8.1.2
     21639:20240628:165539.090 7fc62a42f000-7fc62a435000 r-xp 00002000 08:01 785623                     /usr/lib/x86_64-linux-gnu/libffi.so.8.1.2
     21639:20240628:165539.090 7fc62a435000-7fc62a437000 r--p 00008000 08:01 785623                     /usr/lib/x86_64-linux-gnu/libffi.so.8.1.2
     21639:20240628:165539.090 7fc62a437000-7fc62a438000 r--p 00009000 08:01 785623                     /usr/lib/x86_64-linux-gnu/libffi.so.8.1.2
     21639:20240628:165539.090 7fc62a438000-7fc62a439000 rw-p 0000a000 08:01 785623                     /usr/lib/x86_64-linux-gnu/libffi.so.8.1.2
     21639:20240628:165539.090 7fc62a439000-7fc62a43c000 r--p 00000000 08:01 788894                     /usr/lib/x86_64-linux-gnu/libresolv.so.2
     21639:20240628:165539.090 7fc62a43c000-7fc62a444000 r-xp 00003000 08:01 788894                     /usr/lib/x86_64-linux-gnu/libresolv.so.2
     21639:20240628:165539.090 7fc62a444000-7fc62a446000 r--p 0000b000 08:01 788894                     /usr/lib/x86_64-linux-gnu/libresolv.so.2
     21639:20240628:165539.090 7fc62a446000-7fc62a447000 r--p 0000d000 08:01 788894                     /usr/lib/x86_64-linux-gnu/libresolv.so.2
     21639:20240628:165539.090 7fc62a447000-7fc62a448000 rw-p 0000e000 08:01 788894                     /usr/lib/x86_64-linux-gnu/libresolv.so.2
     21639:20240628:165539.090 7fc62a448000-7fc62a44a000 rw-p 00000000 00:00 0
     21639:20240628:165539.090 7fc62a44a000-7fc62a45c000 r--p 00000000 08:01 785853                     /usr/lib/x86_64-linux-gnu/libunistring.so.2.2.0
     21639:20240628:165539.090 7fc62a45c000-7fc62a49c000 r-xp 00012000 08:01 785853                     /usr/lib/x86_64-linux-gnu/libunistring.so.2.2.0
     21639:20240628:165539.090 7fc62a49c000-7fc62a5fb000 r--p 00052000 08:01 785853                     /usr/lib/x86_64-linux-gnu/libunistring.so.2.2.0
     21639:20240628:165539.090 7fc62a5fb000-7fc62a5ff000 r--p 001b1000 08:01 785853                     /usr/lib/x86_64-linux-gnu/libunistring.so.2.2.0
     21639:20240628:165539.090 7fc62a5ff000-7fc62a600000 rw-p 001b5000 08:01 785853                     /usr/lib/x86_64-linux-gnu/libunistring.so.2.2.0
     21639:20240628:165539.090 7fc62a600000-7fc62a601000 r--p 00000000 08:01 785042                     /usr/lib/x86_64-linux-gnu/libicudata.so.72.1
     21639:20240628:165539.090 7fc62a601000-7fc62a602000 r-xp 00001000 08:01 785042                     /usr/lib/x86_64-linux-gnu/libicudata.so.72.1
     21639:20240628:165539.090 7fc62a602000-7fc62c3d0000 r--p 00002000 08:01 785042                     /usr/lib/x86_64-linux-gnu/libicudata.so.72.1
     21639:20240628:165539.090 7fc62c3d0000-7fc62c3d1000 r--p 01dcf000 08:01 785042                     /usr/lib/x86_64-linux-gnu/libicudata.so.72.1
     21639:20240628:165539.090 7fc62c3d1000-7fc62c3d2000 rw-p 01dd0000 08:01 785042                     /usr/lib/x86_64-linux-gnu/libicudata.so.72.1
     21639:20240628:165539.090 7fc62c3d2000-7fc62c3d4000 rw-p 00000000 00:00 0
     21639:20240628:165539.090 7fc62c3d4000-7fc62c3d6000 r--p 00000000 08:01 788550                     /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.10
     21639:20240628:165539.090 7fc62c3d6000-7fc62c3d8000 r-xp 00002000 08:01 788550                     /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.10
     21639:20240628:165539.090 7fc62c3d8000-7fc62c3d9000 r--p 00004000 08:01 788550                     /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.10
     21639:20240628:165539.090 7fc62c3d9000-7fc62c3da000 r--p 00004000 08:01 788550                     /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.10
     21639:20240628:165539.090 7fc62c3da000-7fc62c3db000 rw-p 00005000 08:01 788550                     /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.10
     21639:20240628:165539.090 7fc62c3db000-7fc62c3dc000 r--p 00000000 08:01 789172                     /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.9
     21639:20240628:165539.090 7fc62c3dc000-7fc62c3dd000 r-xp 00001000 08:01 789172                     /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.9
     21639:20240628:165539.090 7fc62c3dd000-7fc62c3fc000 r--p 00002000 08:01 789172                     /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.9
     21639:20240628:165539.090 7fc62c3fc000-7fc62c3fd000 r--p 00020000 08:01 789172                     /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.9
     21639:20240628:165539.090 7fc62c3fd000-7fc62c3fe000 rw-p 00021000 08:01 789172                     /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.9
     21639:20240628:165539.090 7fc62c3fe000-7fc62c401000 r--p 00000000 08:01 785352                     /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.3
     21639:20240628:165539.090 7fc62c401000-7fc62c40d000 r-xp 00003000 08:01 785352                     /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.3
     21639:20240628:165539.090 7fc62c40d000-7fc62c411000 r--p 0000f000 08:01 785352                     /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.3
     21639:20240628:165539.090 7fc62c411000-7fc62c412000 r--p 00013000 08:01 785352                     /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.3
     21639:20240628:165539.090 7fc62c412000-7fc62c413000 rw-p 00014000 08:01 785352                     /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.3
     21639:20240628:165539.090 7fc62c413000-7fc62c43e000 r--p 00000000 08:01 787508                     /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
     21639:20240628:165539.090 7fc62c43e000-7fc62c4d7000 r-xp 0002b000 08:01 787508                     /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
     21639:20240628:165539.090 7fc62c4d7000-7fc62c532000 r--p 000c4000 08:01 787508                     /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
     21639:20240628:165539.090 7fc62c532000-7fc62c53d000 r--p 0011f000 08:01 787508                     /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
     21639:20240628:165539.090 7fc62c53d000-7fc62c547000 rw-p 0012a000 08:01 787508                     /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
     21639:20240628:165539.091 7fc62c547000-7fc62c54a000 r--p 00000000 08:01 785546                     /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
     21639:20240628:165539.091 7fc62c54a000-7fc62c561000 r-xp 00003000 08:01 785546                     /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
     21639:20240628:165539.091 7fc62c561000-7fc62c565000 r--p 0001a000 08:01 785546                     /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
     21639:20240628:165539.091 7fc62c565000-7fc62c566000 r--p 0001d000 08:01 785546                     /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
     21639:20240628:165539.091 7fc62c566000-7fc62c567000 rw-p 0001e000 08:01 785546                     /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
     21639:20240628:165539.091 7fc62c567000-7fc62c56a000 r--p 00000000 08:01 784922                     /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
     21639:20240628:165539.091 7fc62c56a000-7fc62c570000 r-xp 00003000 08:01 784922                     /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
     21639:20240628:165539.091 7fc62c570000-7fc62c573000 r--p 00009000 08:01 784922                     /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
     21639:20240628:165539.091 7fc62c573000-7fc62c574000 r--p 0000b000 08:01 784922                     /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
     21639:20240628:165539.091 7fc62c574000-7fc62c575000 rw-p 0000c000 08:01 784922                     /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
     21639:20240628:165539.091 7fc62c575000-7fc62c577000 r--p 00000000 08:01 788976                     /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
     21639:20240628:165539.091 7fc62c577000-7fc62c578000 r-xp 00002000 08:01 788976                     /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
     21639:20240628:165539.091 7fc62c578000-7fc62c579000 r--p 00003000 08:01 788976                     /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
     21639:20240628:165539.091 7fc62c579000-7fc62c57a000 r--p 00003000 08:01 788976                     /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
     21639:20240628:165539.091 7fc62c57a000-7fc62c57b000 rw-p 00004000 08:01 788976                     /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
     21639:20240628:165539.091 7fc62c57b000-7fc62c57f000 r--p 00000000 08:01 785246                     /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
     21639:20240628:165539.091 7fc62c57f000-7fc62c599000 r-xp 00004000 08:01 785246                     /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
     21639:20240628:165539.091 7fc62c599000-7fc62c5a6000 r--p 0001e000 08:01 785246                     /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
     21639:20240628:165539.091 7fc62c5a6000-7fc62c5a7000 r--p 0002b000 08:01 785246                     /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
     21639:20240628:165539.091 7fc62c5a7000-7fc62c5a8000 rw-p 0002c000 08:01 785246                     /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
     21639:20240628:165539.091 7fc62c5a8000-7fc62c5cb000 r--p 00000000 08:01 787821                     /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
     21639:20240628:165539.091 7fc62c5cb000-7fc62c62a000 r-xp 00023000 08:01 787821                     /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
     21639:20240628:165539.091 7fc62c62a000-7fc62c672000 r--p 00082000 08:01 787821                     /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
     21639:20240628:165539.091 7fc62c672000-7fc62c67f000 r--p 000c9000 08:01 787821                     /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
     21639:20240628:165539.091 7fc62c67f000-7fc62c682000 rw-p 000d6000 08:01 787821                     /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
     21639:20240628:165539.091 7fc62c682000-7fc62c683000 r--p 00000000 08:01 789174                     /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.9
     21639:20240628:165539.091 7fc62c683000-7fc62c68a000 r-xp 00001000 08:01 789174                     /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.9
     21639:20240628:165539.091 7fc62c68a000-7fc62c68d000 r--p 00008000 08:01 789174                     /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.9
     21639:20240628:165539.091 7fc62c68d000-7fc62c68e000 r--p 0000a000 08:01 789174                     /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.9
     21639:20240628:165539.091 7fc62c68e000-7fc62c68f000 rw-p 0000b000 08:01 789174                     /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.9
     21639:20240628:165539.091 7fc62c68f000-7fc62c694000 r--p 00000000 08:01 786470                     /usr/lib/x86_64-linux-gnu/libzstd.so.1.5.4
     21639:20240628:165539.091 7fc62c694000-7fc62c735000 r-xp 00005000 08:01 786470                     /usr/lib/x86_64-linux-gnu/libzstd.so.1.5.4
     21639:20240628:165539.091 7fc62c735000-7fc62c749000 r--p 000a6000 08:01 786470                     /usr/lib/x86_64-linux-gnu/libzstd.so.1.5.4
     21639:20240628:165539.091 7fc62c749000-7fc62c74a000 r--p 000b9000 08:01 786470                     /usr/lib/x86_64-linux-gnu/libzstd.so.1.5.4
     21639:20240628:165539.091 7fc62c74a000-7fc62c74b000 rw-p 000ba000 08:01 786470                     /usr/lib/x86_64-linux-gnu/libzstd.so.1.5.4
     21639:20240628:165539.091 7fc62c74b000-7fc62c74d000 r--p 00000000 08:01 788974                     /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.4
     21639:20240628:165539.091 7fc62c74d000-7fc62c74f000 r-xp 00002000 08:01 788974                     /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.4
     21639:20240628:165539.091 7fc62c74f000-7fc62c75d000 r--p 00004000 08:01 788974                     /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.4
     21639:20240628:165539.091 7fc62c75d000-7fc62c75e000 r--p 00011000 08:01 788974                     /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.4
     21639:20240628:165539.091 7fc62c75e000-7fc62c75f000 rw-p 00012000 08:01 788974                     /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.4
     21639:20240628:165539.091 7fc62c75f000-7fc62c766000 r--p 00000000 08:01 785113                     /usr/lib/x86_64-linux-gnu/libssh2.so.1.0.1
     21639:20240628:165539.091 7fc62c766000-7fc62c78f000 r-xp 00007000 08:01 785113                     /usr/lib/x86_64-linux-gnu/libssh2.so.1.0.1
     21639:20240628:165539.091 7fc62c78f000-7fc62c79d000 r--p 00030000 08:01 785113                     /usr/lib/x86_64-linux-gnu/libssh2.so.1.0.1
     21639:20240628:165539.091 7fc62c79d000-7fc62c79f000 r--p 0003d000 08:01 785113                     /usr/lib/x86_64-linux-gnu/libssh2.so.1.0.1
     21639:20240628:165539.091 7fc62c79f000-7fc62c7a0000 rw-p 0003f000 08:01 785113                     /usr/lib/x86_64-linux-gnu/libssh2.so.1.0.1
     21639:20240628:165539.091 7fc62c7a0000-7fc62c7a2000 r--p 00000000 08:01 787087                     /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.8
     21639:20240628:165539.091 7fc62c7a2000-7fc62c7a9000 r-xp 00002000 08:01 787087                     /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.8
     21639:20240628:165539.091 7fc62c7a9000-7fc62c7cf000 r--p 00009000 08:01 787087                     /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.8
     21639:20240628:165539.091 7fc62c7cf000-7fc62c7d0000 r--p 0002f000 08:01 787087                     /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.8
     21639:20240628:165539.091 7fc62c7d0000-7fc62c7d1000 rw-p 00030000 08:01 787087                     /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.8
     21639:20240628:165539.091 7fc62c7d1000-7fc62c7d6000 r--p 00000000 08:01 789868                     /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.24.1
     21639:20240628:165539.092 7fc62c7d6000-7fc62c7ed000 r-xp 00005000 08:01 789868                     /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.24.1
     21639:20240628:165539.092 7fc62c7ed000-7fc62c7fc000 r--p 0001c000 08:01 789868                     /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.24.1
     21639:20240628:165539.092 7fc62c7fc000-7fc62c7ff000 r--p 0002b000 08:01 789868                     /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.24.1
     21639:20240628:165539.092 7fc62c7ff000-7fc62c800000 rw-p 0002e000 08:01 789868                     /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.24.1
     21639:20240628:165539.092 7fc62c800000-7fc62c837000 r--p 00000000 08:01 785356                     /usr/lib/x86_64-linux-gnu/libgnutls.so.30.34.3
     21639:20240628:165539.092 7fc62c837000-7fc62c96a000 r-xp 00037000 08:01 785356                     /usr/lib/x86_64-linux-gnu/libgnutls.so.30.34.3
     21639:20240628:165539.092 7fc62c96a000-7fc62ca05000 r--p 0016a000 08:01 785356                     /usr/lib/x86_64-linux-gnu/libgnutls.so.30.34.3
     21639:20240628:165539.092 7fc62ca05000-7fc62ca16000 r--p 00205000 08:01 785356                     /usr/lib/x86_64-linux-gnu/libgnutls.so.30.34.3
     21639:20240628:165539.092 7fc62ca16000-7fc62ca18000 rw-p 00216000 08:01 785356                     /usr/lib/x86_64-linux-gnu/libgnutls.so.30.34.3
     21639:20240628:165539.092 7fc62ca18000-7fc62ca1c000 rw-p 00000000 00:00 0
     21639:20240628:165539.092 7fc62ca1c000-7fc62ca20000 rw-p 00000000 00:00 0
     21639:20240628:165539.092 7fc62ca20000-7fc62ca25000 r--p 00000000 08:01 793635                     /usr/lib/x86_64-linux-gnu/librtmp.so.1
     21639:20240628:165539.092 7fc62ca25000-7fc62ca35000 r-xp 00005000 08:01 793635                     /usr/lib/x86_64-linux-gnu/librtmp.so.1
     21639:20240628:165539.092 7fc62ca35000-7fc62ca3c000 r--p 00015000 08:01 793635                     /usr/lib/x86_64-linux-gnu/librtmp.so.1
     21639:20240628:165539.092 7fc62ca3c000-7fc62ca3d000 ---p 0001c000 08:01 793635                     /usr/lib/x86_64-linux-gnu/librtmp.so.1
     21639:20240628:165539.092 7fc62ca3d000-7fc62ca3e000 r--p 0001c000 08:01 793635                     /usr/lib/x86_64-linux-gnu/librtmp.so.1
     21639:20240628:165539.092 7fc62ca3e000-7fc62ca3f000 rw-p 0001d000 08:01 793635                     /usr/lib/x86_64-linux-gnu/librtmp.so.1
     21639:20240628:165539.092 7fc62ca3f000-7fc62ca42000 r--p 00000000 08:01 788030                     /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
     21639:20240628:165539.092 7fc62ca42000-7fc62ca54000 r-xp 00003000 08:01 788030                     /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
     21639:20240628:165539.092 7fc62ca54000-7fc62ca5a000 r--p 00015000 08:01 788030                     /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
     21639:20240628:165539.092 7fc62ca5a000-7fc62ca5b000 r--p 0001a000 08:01 788030                     /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
     21639:20240628:165539.092 7fc62ca5b000-7fc62ca5c000 rw-p 0001b000 08:01 788030                     /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
     21639:20240628:165539.092 7fc62ca5c000-7fc62ca66000 r--p 00000000 08:01 789161                     /usr/lib/x86_64-linux-gnu/libevent_core-2.1.so.7.0.1
     21639:20240628:165539.092 7fc62ca66000-7fc62ca84000 r-xp 0000a000 08:01 789161                     /usr/lib/x86_64-linux-gnu/libevent_core-2.1.so.7.0.1
     21639:20240628:165539.092 7fc62ca84000-7fc62ca90000 r--p 00028000 08:01 789161                     /usr/lib/x86_64-linux-gnu/libevent_core-2.1.so.7.0.1
     21639:20240628:165539.092 7fc62ca90000-7fc62ca91000 r--p 00034000 08:01 789161                     /usr/lib/x86_64-linux-gnu/libevent_core-2.1.so.7.0.1
     21639:20240628:165539.092 7fc62ca91000-7fc62ca92000 rw-p 00035000 08:01 789161                     /usr/lib/x86_64-linux-gnu/libevent_core-2.1.so.7.0.1
     21639:20240628:165539.092 7fc62ca92000-7fc62ca94000 r--p 00000000 08:01 790658                     /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
     21639:20240628:165539.092 7fc62ca94000-7fc62ca99000 r-xp 00002000 08:01 790658                     /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
     21639:20240628:165539.092 7fc62ca99000-7fc62ca9b000 r--p 00007000 08:01 790658                     /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
     21639:20240628:165539.092 7fc62ca9b000-7fc62ca9c000 r--p 00008000 08:01 790658                     /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
     21639:20240628:165539.092 7fc62ca9c000-7fc62ca9d000 rw-p 00009000 08:01 790658                     /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
     21639:20240628:165539.092 7fc62ca9d000-7fc62ca9f000 r--p 00000000 08:01 789860                     /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.2
     21639:20240628:165539.092 7fc62ca9f000-7fc62caa4000 r-xp 00002000 08:01 789860                     /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.2
     21639:20240628:165539.092 7fc62caa4000-7fc62caa6000 r--p 00007000 08:01 789860                     /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.2
     21639:20240628:165539.092 7fc62caa6000-7fc62caa7000 r--p 00008000 08:01 789860                     /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.2
     21639:20240628:165539.092 7fc62caa7000-7fc62caa8000 rw-p 00009000 08:01 789860                     /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.2
     21639:20240628:165539.092 7fc62caa8000-7fc62cb11000 r--p 00000000 08:01 785047                     /usr/lib/x86_64-linux-gnu/libicuuc.so.72.1
     21639:20240628:165539.092 7fc62cb11000-7fc62cc02000 r-xp 00069000 08:01 785047                     /usr/lib/x86_64-linux-gnu/libicuuc.so.72.1
     21639:20240628:165539.092 7fc62cc02000-7fc62cc90000 r--p 0015a000 08:01 785047                     /usr/lib/x86_64-linux-gnu/libicuuc.so.72.1
     21639:20240628:165539.092 7fc62cc90000-7fc62cca3000 r--p 001e8000 08:01 785047                     /usr/lib/x86_64-linux-gnu/libicuuc.so.72.1
     21639:20240628:165539.092 7fc62cca3000-7fc62cca4000 rw-p 001fb000 08:01 785047                     /usr/lib/x86_64-linux-gnu/libicuuc.so.72.1
     21639:20240628:165539.092 7fc62cca4000-7fc62cca6000 rw-p 00000000 00:00 0
     21639:20240628:165539.092 7fc62cca6000-7fc62cccc000 r--p 00000000 08:01 788721                     /usr/lib/x86_64-linux-gnu/libc.so.6
     21639:20240628:165539.092 7fc62cccc000-7fc62ce21000 r-xp 00026000 08:01 788721                     /usr/lib/x86_64-linux-gnu/libc.so.6
     21639:20240628:165539.092 7fc62ce21000-7fc62ce74000 r--p 0017b000 08:01 788721                     /usr/lib/x86_64-linux-gnu/libc.so.6
     21639:20240628:165539.092 7fc62ce74000-7fc62ce78000 r--p 001ce000 08:01 788721                     /usr/lib/x86_64-linux-gnu/libc.so.6
     21639:20240628:165539.092 7fc62ce78000-7fc62ce7a000 rw-p 001d2000 08:01 788721                     /usr/lib/x86_64-linux-gnu/libc.so.6
     21639:20240628:165539.092 7fc62ce7a000-7fc62ce87000 rw-p 00000000 00:00 0
     21639:20240628:165539.092 7fc62ce87000-7fc62ce89000 r--p 00000000 08:01 786225                     /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.11.2
     21639:20240628:165539.092 7fc62ce89000-7fc62cef4000 r-xp 00002000 08:01 786225                     /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.11.2
     21639:20240628:165539.092 7fc62cef4000-7fc62cf1f000 r--p 0006d000 08:01 786225                     /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.11.2
     21639:20240628:165539.093 7fc62cf1f000-7fc62cf20000 r--p 00098000 08:01 786225                     /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.11.2
     21639:20240628:165539.093 7fc62cf20000-7fc62cf21000 rw-p 00099000 08:01 786225                     /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.11.2
     21639:20240628:165539.093 7fc62cf21000-7fc62cf31000 r--p 00000000 08:01 788726                     /usr/lib/x86_64-linux-gnu/libm.so.6
     21639:20240628:165539.093 7fc62cf31000-7fc62cfa4000 r-xp 00010000 08:01 788726                     /usr/lib/x86_64-linux-gnu/libm.so.6
     21639:20240628:165539.093 7fc62cfa4000-7fc62cffe000 r--p 00083000 08:01 788726                     /usr/lib/x86_64-linux-gnu/libm.so.6
     21639:20240628:165539.093 7fc62cffe000-7fc62cfff000 r--p 000dc000 08:01 788726                     /usr/lib/x86_64-linux-gnu/libm.so.6
     21639:20240628:165539.093 7fc62cfff000-7fc62d000000 rw-p 000dd000 08:01 788726                     /usr/lib/x86_64-linux-gnu/libm.so.6
     21639:20240628:165539.093 7fc62d000000-7fc62d0c5000 r--p 00000000 08:01 785566                     /usr/lib/x86_64-linux-gnu/libcrypto.so.3
     21639:20240628:165539.093 7fc62d0c5000-7fc62d33e000 r-xp 000c5000 08:01 785566                     /usr/lib/x86_64-linux-gnu/libcrypto.so.3
     21639:20240628:165539.093 7fc62d33e000-7fc62d41b000 r--p 0033e000 08:01 785566                     /usr/lib/x86_64-linux-gnu/libcrypto.so.3
     21639:20240628:165539.093 7fc62d41b000-7fc62d47c000 r--p 0041b000 08:01 785566                     /usr/lib/x86_64-linux-gnu/libcrypto.so.3
     21639:20240628:165539.093 7fc62d47c000-7fc62d47f000 rw-p 0047c000 08:01 785566                     /usr/lib/x86_64-linux-gnu/libcrypto.so.3
     21639:20240628:165539.093 7fc62d47f000-7fc62d482000 rw-p 00000000 00:00 0
     21639:20240628:165539.093 7fc62d483000-7fc62d489000 rw-p 00000000 00:00 0
     21639:20240628:165539.093 7fc62d489000-7fc62d48d000 r--p 00000000 08:01 786462                     /usr/lib/x86_64-linux-gnu/liblzma.so.5.4.1
     21639:20240628:165539.093 7fc62d48d000-7fc62d4aa000 r-xp 00004000 08:01 786462                     /usr/lib/x86_64-linux-gnu/liblzma.so.5.4.1
     21639:20240628:165539.093 7fc62d4aa000-7fc62d4b6000 r--p 00021000 08:01 786462                     /usr/lib/x86_64-linux-gnu/liblzma.so.5.4.1
     21639:20240628:165539.093 7fc62d4b6000-7fc62d4b7000 r--p 0002d000 08:01 786462                     /usr/lib/x86_64-linux-gnu/liblzma.so.5.4.1
     21639:20240628:165539.093 7fc62d4b7000-7fc62d4b8000 rw-p 0002e000 08:01 786462                     /usr/lib/x86_64-linux-gnu/liblzma.so.5.4.1
     21639:20240628:165539.093 7fc62d4b8000-7fc62d4c4000 r--p 00000000 08:01 788053                     /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
     21639:20240628:165539.093 7fc62d4c4000-7fc62d4f9000 r-xp 0000c000 08:01 788053                     /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
     21639:20240628:165539.093 7fc62d4f9000-7fc62d506000 r--p 00041000 08:01 788053                     /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
     21639:20240628:165539.093 7fc62d506000-7fc62d508000 r--p 0004e000 08:01 788053                     /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
     21639:20240628:165539.093 7fc62d508000-7fc62d50a000 rw-p 00050000 08:01 788053                     /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
     21639:20240628:165539.093 7fc62d50a000-7fc62d50c000 rw-p 00000000 00:00 0
     21639:20240628:165539.093 7fc62d50c000-7fc62d51d000 r--p 00000000 08:01 785115                     /usr/lib/x86_64-linux-gnu/libcurl.so.4.8.0
     21639:20240628:165539.093 7fc62d51d000-7fc62d593000 r-xp 00011000 08:01 785115                     /usr/lib/x86_64-linux-gnu/libcurl.so.4.8.0
     21639:20240628:165539.093 7fc62d593000-7fc62d5b5000 r--p 00087000 08:01 785115                     /usr/lib/x86_64-linux-gnu/libcurl.so.4.8.0
     21639:20240628:165539.093 7fc62d5b5000-7fc62d5b9000 r--p 000a8000 08:01 785115                     /usr/lib/x86_64-linux-gnu/libcurl.so.4.8.0
     21639:20240628:165539.093 7fc62d5b9000-7fc62d5bc000 rw-p 000ac000 08:01 785115                     /usr/lib/x86_64-linux-gnu/libcurl.so.4.8.0
     21639:20240628:165539.093 7fc62d5bc000-7fc62d5bf000 r--p 00000000 08:01 788035                     /usr/lib/x86_64-linux-gnu/liblber-2.5.so.0.1.8
     21639:20240628:165539.093 7fc62d5bf000-7fc62d5c7000 r-xp 00003000 08:01 788035                     /usr/lib/x86_64-linux-gnu/liblber-2.5.so.0.1.8
     21639:20240628:165539.093 7fc62d5c7000-7fc62d5ca000 r--p 0000b000 08:01 788035                     /usr/lib/x86_64-linux-gnu/liblber-2.5.so.0.1.8
     21639:20240628:165539.093 7fc62d5ca000-7fc62d5cb000 r--p 0000e000 08:01 788035                     /usr/lib/x86_64-linux-gnu/liblber-2.5.so.0.1.8
     21639:20240628:165539.093 7fc62d5cb000-7fc62d5cc000 rw-p 0000f000 08:01 788035                     /usr/lib/x86_64-linux-gnu/liblber-2.5.so.0.1.8
     21639:20240628:165539.093 7fc62d5cc000-7fc62d5dc000 r--p 00000000 08:01 788036                     /usr/lib/x86_64-linux-gnu/libldap-2.5.so.0.1.8
     21639:20240628:165539.093 7fc62d5dc000-7fc62d615000 r-xp 00010000 08:01 788036                     /usr/lib/x86_64-linux-gnu/libldap-2.5.so.0.1.8
     21639:20240628:165539.093 7fc62d615000-7fc62d626000 r--p 00049000 08:01 788036                     /usr/lib/x86_64-linux-gnu/libldap-2.5.so.0.1.8
     21639:20240628:165539.093 7fc62d626000-7fc62d628000 r--p 0005a000 08:01 788036                     /usr/lib/x86_64-linux-gnu/libldap-2.5.so.0.1.8
     21639:20240628:165539.093 7fc62d628000-7fc62d629000 rw-p 0005c000 08:01 788036                     /usr/lib/x86_64-linux-gnu/libldap-2.5.so.0.1.8
     21639:20240628:165539.093 7fc62d629000-7fc62d62d000 rw-p 00000000 00:00 0
     21639:20240628:165539.093 7fc62d62d000-7fc62d64c000 r--p 00000000 08:01 785567                     /usr/lib/x86_64-linux-gnu/libssl.so.3
     21639:20240628:165539.093 7fc62d64c000-7fc62d6aa000 r-xp 0001f000 08:01 785567                     /usr/lib/x86_64-linux-gnu/libssl.so.3
     21639:20240628:165539.093 7fc62d6aa000-7fc62d6c9000 r--p 0007d000 08:01 785567                     /usr/lib/x86_64-linux-gnu/libssl.so.3
     21639:20240628:165539.093 7fc62d6c9000-7fc62d6d3000 r--p 0009c000 08:01 785567                     /usr/lib/x86_64-linux-gnu/libssl.so.3
     21639:20240628:165539.093 7fc62d6d3000-7fc62d6d7000 rw-p 000a6000 08:01 785567                     /usr/lib/x86_64-linux-gnu/libssl.so.3
     21639:20240628:165539.093 7fc62d6d7000-7fc62d6d8000 r--p 00000000 08:01 784907                     /usr/lib/x86_64-linux-gnu/libevent_pthreads-2.1.so.7.0.1
     21639:20240628:165539.093 7fc62d6d8000-7fc62d6d9000 r-xp 00001000 08:01 784907                     /usr/lib/x86_64-linux-gnu/libevent_pthreads-2.1.so.7.0.1
     21639:20240628:165539.093 7fc62d6d9000-7fc62d6da000 r--p 00002000 08:01 784907                     /usr/lib/x86_64-linux-gnu/libevent_pthreads-2.1.so.7.0.1
     21639:20240628:165539.093 7fc62d6da000-7fc62d6db000 r--p 00002000 08:01 784907                     /usr/lib/x86_64-linux-gnu/libevent_pthreads-2.1.so.7.0.1
     21639:20240628:165539.093 7fc62d6db000-7fc62d6dc000 rw-p 00003000 08:01 784907                     /usr/lib/x86_64-linux-gnu/libevent_pthreads-2.1.so.7.0.1
     21639:20240628:165539.094 7fc62d6dc000-7fc62d6ea000 r--p 00000000 08:01 785782                     /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.1
     21639:20240628:165539.094 7fc62d6ea000-7fc62d71b000 r-xp 0000e000 08:01 785782                     /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.1
     21639:20240628:165539.094 7fc62d71b000-7fc62d72e000 r--p 0003f000 08:01 785782                     /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.1
     21639:20240628:165539.094 7fc62d72e000-7fc62d730000 r--p 00052000 08:01 785782                     /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.1
     21639:20240628:165539.094 7fc62d730000-7fc62d731000 rw-p 00054000 08:01 785782                     /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.1
     21639:20240628:165539.094 7fc62d731000-7fc62d734000 r--p 00000000 08:01 785705                     /usr/lib/x86_64-linux-gnu/libz.so.1.2.13
     21639:20240628:165539.094 7fc62d734000-7fc62d747000 r-xp 00003000 08:01 785705                     /usr/lib/x86_64-linux-gnu/libz.so.1.2.13
     21639:20240628:165539.094 7fc62d747000-7fc62d74e000 r--p 00016000 08:01 785705                     /usr/lib/x86_64-linux-gnu/libz.so.1.2.13
     21639:20240628:165539.094 7fc62d74e000-7fc62d74f000 r--p 0001c000 08:01 785705                     /usr/lib/x86_64-linux-gnu/libz.so.1.2.13
     21639:20240628:165539.094 7fc62d74f000-7fc62d750000 rw-p 0001d000 08:01 785705                     /usr/lib/x86_64-linux-gnu/libz.so.1.2.13
     21639:20240628:165539.094 7fc62d750000-7fc62d752000 r--p 00000000 08:01 790655                     /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
     21639:20240628:165539.094 7fc62d752000-7fc62d756000 r-xp 00002000 08:01 790655                     /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
     21639:20240628:165539.094 7fc62d756000-7fc62d757000 r--p 00006000 08:01 790655                     /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
     21639:20240628:165539.094 7fc62d757000-7fc62d758000 r--p 00007000 08:01 790655                     /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
     21639:20240628:165539.094 7fc62d758000-7fc62d759000 rw-p 00008000 08:01 790655                     /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
     21639:20240628:165539.094 7fc62d759000-7fc62d78c000 r--p 00000000 08:01 790653                     /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
     21639:20240628:165539.094 7fc62d78c000-7fc62d80e000 r-xp 00033000 08:01 790653                     /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
     21639:20240628:165539.094 7fc62d80e000-7fc62d84c000 r--p 000b5000 08:01 790653                     /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
     21639:20240628:165539.094 7fc62d84c000-7fc62d864000 r--p 000f3000 08:01 790653                     /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
     21639:20240628:165539.094 7fc62d864000-7fc62d869000 rw-p 0010b000 08:01 790653                     /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
     21639:20240628:165539.094 7fc62d869000-7fc62d86f000 rw-p 00000000 00:00 0
     21639:20240628:165539.094 7fc62d86f000-7fc62d87e000 r--p 00000000 08:01 790660                     /usr/lib/x86_64-linux-gnu/libssh.so.4.9.6
     21639:20240628:165539.094 7fc62d87e000-7fc62d8c2000 r-xp 0000f000 08:01 790660                     /usr/lib/x86_64-linux-gnu/libssh.so.4.9.6
     21639:20240628:165539.094 7fc62d8c2000-7fc62d8df000 r--p 00053000 08:01 790660                     /usr/lib/x86_64-linux-gnu/libssh.so.4.9.6
     21639:20240628:165539.094 7fc62d8df000-7fc62d8e1000 r--p 00070000 08:01 790660                     /usr/lib/x86_64-linux-gnu/libssh.so.4.9.6
     21639:20240628:165539.094 7fc62d8e1000-7fc62d8e3000 rw-p 00072000 08:01 790660                     /usr/lib/x86_64-linux-gnu/libssh.so.4.9.6
     21639:20240628:165539.094 7fc62d8e3000-7fc62d8ff000 r--p 00000000 08:01 789068                     /usr/lib/x86_64-linux-gnu/libnetsnmp.so.40.2.0
     21639:20240628:165539.094 7fc62d8ff000-7fc62d98b000 r-xp 0001c000 08:01 789068                     /usr/lib/x86_64-linux-gnu/libnetsnmp.so.40.2.0
     21639:20240628:165539.094 7fc62d98b000-7fc62d9bb000 r--p 000a8000 08:01 789068                     /usr/lib/x86_64-linux-gnu/libnetsnmp.so.40.2.0
     21639:20240628:165539.094 7fc62d9bb000-7fc62d9be000 r--p 000d8000 08:01 789068                     /usr/lib/x86_64-linux-gnu/libnetsnmp.so.40.2.0
     21639:20240628:165539.094 7fc62d9be000-7fc62d9c1000 rw-p 000db000 08:01 789068                     /usr/lib/x86_64-linux-gnu/libnetsnmp.so.40.2.0
     21639:20240628:165539.094 7fc62d9c1000-7fc62d9c6000 rw-p 00000000 00:00 0
     21639:20240628:165539.094 7fc62d9c6000-7fc62d9cd000 r--p 00000000 08:01 790539                     /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
     21639:20240628:165539.094 7fc62d9cd000-7fc62da19000 r-xp 00007000 08:01 790539                     /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
     21639:20240628:165539.094 7fc62da19000-7fc62da2b000 r--p 00053000 08:01 790539                     /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
     21639:20240628:165539.094 7fc62da2b000-7fc62da2c000 r--p 00064000 08:01 790539                     /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
     21639:20240628:165539.094 7fc62da2c000-7fc62da33000 rw-p 00065000 08:01 790539                     /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
     21639:20240628:165539.094 7fc62da33000-7fc62da37000 rw-p 00000000 00:00 0
     21639:20240628:165539.094 7fc62da37000-7fc62da66000 r--p 00000000 08:01 785058                     /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.14
     21639:20240628:165539.094 7fc62da66000-7fc62db82000 r-xp 0002f000 08:01 785058                     /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.14
     21639:20240628:165539.094 7fc62db82000-7fc62dbd8000 r--p 0014b000 08:01 785058                     /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.14
     21639:20240628:165539.094 7fc62dbd8000-7fc62dbe1000 r--p 001a1000 08:01 785058                     /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.14
     21639:20240628:165539.094 7fc62dbe1000-7fc62dbe2000 rw-p 001aa000 08:01 785058                     /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.14
     21639:20240628:165539.095 7fc62dbe2000-7fc62dbe3000 rw-p 00000000 00:00 0
     21639:20240628:165539.095 7fc62dbe3000-7fc62dbee000 r--p 00000000 08:01 787804                     /usr/lib/x86_64-linux-gnu/libpq.so.5.15
     21639:20240628:165539.095 7fc62dbee000-7fc62dc13000 r-xp 0000b000 08:01 787804                     /usr/lib/x86_64-linux-gnu/libpq.so.5.15
     21639:20240628:165539.095 7fc62dc13000-7fc62dc33000 r--p 00030000 08:01 787804                     /usr/lib/x86_64-linux-gnu/libpq.so.5.15
     21639:20240628:165539.095 7fc62dc33000-7fc62dc37000 r--p 0004f000 08:01 787804                     /usr/lib/x86_64-linux-gnu/libpq.so.5.15
     21639:20240628:165539.095 7fc62dc37000-7fc62dc38000 rw-p 00053000 08:01 787804                     /usr/lib/x86_64-linux-gnu/libpq.so.5.15
     21639:20240628:165539.095 7fc62dc3e000-7fc62dc3f000 rw-s 00000000 00:01 917553                     /SYSV00000000 (deleted)
     21639:20240628:165539.095 7fc62dc3f000-7fc62dc41000 rw-p 00000000 00:00 0
     21639:20240628:165539.095 7fc62dc41000-7fc62dc42000 r--p 00000000 08:01 788715                     /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
     21639:20240628:165539.095 7fc62dc42000-7fc62dc67000 r-xp 00001000 08:01 788715                     /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
     21639:20240628:165539.095 7fc62dc67000-7fc62dc71000 r--p 00026000 08:01 788715                     /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
     21639:20240628:165539.095 7fc62dc71000-7fc62dc73000 r--p 00030000 08:01 788715                     /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
     21639:20240628:165539.095 7fc62dc73000-7fc62dc75000 rw-p 00032000 08:01 788715                     /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
     21639:20240628:165539.095 7ffc7aad6000-7ffc7aaf7000 rw-p 00000000 00:00 0                          [stack]
     21639:20240628:165539.095 7ffc7ab89000-7ffc7ab8d000 r--p 00000000 00:00 0                          [vvar]
     21639:20240628:165539.095 7ffc7ab8d000-7ffc7ab8f000 r-xp 00000000 00:00 0                          [vdso]
     21639:20240628:165539.095 ================================
     21639:20240628:165539.095 Please consider attaching a disassembly listing to your bug report.
     21639:20240628:165539.095 This listing can be produced with, e.g., objdump -DSswx zabbix_server.
     21636:20240628:165539.100 One child process died (PID:21639,exitcode/signal:1). Exiting ...
     21637:20240628:165539.100 HA manager has been paused
     21637:20240628:165539.113 HA manager has been stopped
     21636:20240628:165539.115 Zabbix Server stopped. Zabbix 7.0.0 (revision 49955f1fb5c).
  • MikansOnTap456
    • Jun 2024
    Here is the output immediately preceding the crash with debug level 4 enabled:
      5694:20240629:003600.679 query [txnlev:0] [select i.interfaceid,i.hostid,i.type,i.main,i.useip,i.ip,i.dns,i.port,i.available,i.disable_until,i.error,i.errors_from,s.version,s.bulk,s.community,s.securityname,s.securitylevel,s.authpassphrase,s.privpassphrase,s.authprotocol,s.privprotocol,s.contextname,s.max_repetitions from interface i left join interface_snmp s on i.interfaceid=s.interfaceid]
      5694:20240629:003600.683 query [txnlev:0] [select i.itemid,i.hostid,i.status,i.type,i.value_type,i.key_,i.snmp_oid,i.ipmi_sensor,i.delay,i.trapper_hosts,i.logtimefmt,i.params,ir.state,i.authtype,i.username,i.password,i.publickey,i.privatekey,i.flags,i.interfaceid,ir.lastlogsize,ir.mtime,i.history,i.trends,i.inventory_link,i.valuemapid,i.units,ir.error,i.jmx_endpoint,i.master_itemid,i.timeout,i.url,i.query_fields,i.posts,i.status_codes,i.follow_redirects,i.post_type,i.http_proxy,i.headers,i.retrieve_mode,i.request_method,i.output_format,i.ssl_cert_file,i.ssl_key_file,i.ssl_key_password,i.verify_peer,i.verify_host,i.allow_traps,i.templateid,null from items i join item_rtdata ir on i.itemid=ir.itemid]
      5694:20240629:003600.936 query [txnlev:0] [select i.itemid,i.hostid,i.templateid from items i inner join hosts h on i.hostid=h.hostid where h.status=3]
      5694:20240629:003600.964 query [txnlev:0] [select i.itemid,i.hostid,i.templateid from items i where i.flags=2]
      5694:20240629:003600.989 query [txnlev:0] [select itemid,parent_itemid from item_discovery]
      5694:20240629:003601.013 query [txnlev:0] [select item_preprocid,itemid,type,params,step,error_handler,error_handler_params from item_preproc]
      5694:20240629:003601.080 query [txnlev:0] [select p.item_parameterid,p.itemid,p.name,p.value,i.hostid from item_parameter p,items i,hosts h where p.itemid=i.itemid and i.hostid=h.hostid and h.status in (0,1) and i.flags<>2 order by p.itemid]
      5694:20240629:003601.081 query [txnlev:0] [select functionid,itemid,name,parameter,triggerid from functions]
      5694:20240629:003601.132 In DCsync_interfaces()
      5694:20240629:003601.133 Got signal [signal:11(SIGSEGV),reason:1,refaddr:(nil)]. Crashing ...
      5694:20240629:003601.133 ====== Fatal information: ======
      5694:20240629:003601.133 Program counter: 0x56054fdd7ee0
      5694:20240629:003601.133 === Registers: ===
      5694:20240629:003601.133 r8      =     7f1e05769cc0 =      139766917405888 =      139766917405888
      5694:20240629:003601.133 r9      =               40 =                   64 =                   64
      5694:20240629:003601.133 r10     =                0 =                    0 =                    0
      5694:20240629:003601.133 r11     =               20 =                   32 =                   32
      5694:20240629:003601.134 r12     =     7ffd5fd3ab09 =      140726211160841 =      140726211160841
      5694:20240629:003601.134 r13     =     7ffd5fd3aac8 =      140726211160776 =      140726211160776
      5694:20240629:003601.134 r14     =     7ffd5fd3aa58 =      140726211160664 =      140726211160664
      5694:20240629:003601.134 r15     =     7ffd5fd3aa68 =      140726211160680 =      140726211160680
      5694:20240629:003601.134 rdi     =     7ffd5fd3aac8 =      140726211160776 =      140726211160776
      5694:20240629:003601.134 rsi     =                0 =                    0 =                    0
      5694:20240629:003601.134 rbp     =     7f1dbdae5ae0 =      139765713099488 =      139765713099488
      5694:20240629:003601.134 rbx     =     7ffd5fd3aac0 =      140726211160768 =      140726211160768
      5694:20240629:003601.134 rdx     =     7ffd5fd3ab08 =      140726211160840 =      140726211160840
      5694:20240629:003601.134 rax     =               41 =                   65 =                   65
      5694:20240629:003601.134 rcx     =                0 =                    0 =                    0
      5694:20240629:003601.134 rsp     =     7ffd5fd3a9b8 =      140726211160504 =      140726211160504
      5694:20240629:003601.134 rip     =     56054fdd7ee0 =       94580814741216 =       94580814741216
      5694:20240629:003601.134 efl     =            10202 =                66050 =                66050
      5694:20240629:003601.134 csgsfs  =   2b000000000033 =    12103423998558259 =    12103423998558259
      5694:20240629:003601.134 err     =                4 =                    4 =                    4
      5694:20240629:003601.134 trapno  =                e =                   14 =                   14
      5694:20240629:003601.134 oldmask =                0 =                    0 =                    0
      5694:20240629:003601.134 cr2     =                0 =                    0 =                    0
      5694:20240629:003601.134 === Backtrace: ===
      5694:20240629:003601.137 18: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_backtrace+0x3b) [0x56054fdb051b]
      5694:20240629:003601.137 17: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_log_fatal_info+0x17d) [0x56054fdb078d]
      5694:20240629:003601.137 16: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x3c2e46) [0x56054fdb0e46]
      5694:20240629:003601.137 15: /lib/x86_64-linux-gnu/libc.so.6(+0x3c050) [0x7f1e055d3050]
      5694:20240629:003601.137 14: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_strlcpy+0x30) [0x56054fdd7ee0]
      5694:20240629:003601.137 13: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCget_interface+0x38) [0x56054fc5a3f8]
      5694:20240629:003601.137 12: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_dc_config_get_interface_by_type+0x4f) [0x56054fc5cc5f]
      5694:20240629:003601.137 11: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x26ef0b) [0x56054fc5cf0b]
      5694:20240629:003601.137 10: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x26eff5) [0x56054fc5cff5]
      5694:20240629:003601.137 9: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x26f623) [0x56054fc5d623]
      5694:20240629:003601.137 8: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_dc_sync_configuration+0x2a4b) [0x56054fc68e3b]
      5694:20240629:003601.137 7: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](dbconfig_thread+0xeb) [0x56054fac419b]
      5694:20240629:003601.137 6: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_thread_start+0x20) [0x56054fce5170]
      5694:20240629:003601.137 5: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0xcf26b) [0x56054fabd26b]
      5694:20240629:003601.137 4: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](MAIN_ZABBIX_ENTRY+0xefa) [0x56054fabe89a]
      5694:20240629:003601.137 3: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](main+0x37e) [0x56054fab2b0e]
      5694:20240629:003601.137 2: /lib/x86_64-linux-gnu/libc.so.6(+0x2724a) [0x7f1e055be24a]
      5694:20240629:003601.137 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7f1e055be305]
      5694:20240629:003601.137 0: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](_start+0x21) [0x56054fab9b61]
    • millnet-maho
      • Nov 2022
      Ouch! As you can see, it says "Unsupported DB! timescaledb version 21502 is newer than 21499". When using TimescaleDB, you have to be very careful not to upgrade to a too new version, because if you do, Zabbix will refuse to start and you can't downgrade. This may require holding the timescaledb packages back to prevent automatic upgrades (with dpkg-hold or by pressing = in aptitude). I'm afraid the only options in this situation might be to wait for a newer Zabbix version that supports TimescaleDB 2.15 or to create a new database and copy the configuration tables from the old database.
      However, by now, Zabbix has gained support for TimescaleDB 2.15 (since 7.0.1) and 2.16 (since 7.0.4). See https://www.zabbix.com/documentation...n/requirements
        • 5004
        You can set "AllowUnsupportedDBVersions=1" in server config, then it will ignore the slightly too new TS version... But as usual, you should know, what you are doing..
