Zabbix 7.0 - Previously entered hosts, host groups, actions & templates all gone
  • Steve1964
    • Jun 2024
    Hi -
    This is a new install of Ubuntu 24.04 LTS and Zabbix 7.0. I opted to use the Postgres database.
    After my install yesterday, everything looked normal. I have several of the built in templates visible and the one host (Zabbix Server) was monitoring itself.
    Since I wanted to start from scratch, I created some host groups, configured discovery to find all things pingable and add those hosts to the appropriate host groups.
    This was working fine.
    Today, I log into the system and it's all gone. Not just the stuff I created yesterday, but the built in templates are also missing. (I'm actually surprised my local login still worked...).
    I see several postgres processes running (idle) and Zabbix Server pollers running.
    I tried rebooting the server but no change.
    I thought this may be just a display issue, so I should see the discovery process scanning some of my networks. Running netstat, it only shows connections to/from 127.0.0.1.
    So I'm kinda stuck at this point. This feels like a database issue, but if so, why would my local login work ?
    Any ideas ?
    Here's the /var/log/zabbix/zabbix_server.log from startup to about 10 mins later:
    1040:20240628:184114.388 Starting Zabbix Server. Zabbix 7.0.0 (revision 49955f1fb5c).
    1040:20240628:184114.447 ****** Enabled features ******
    1040:20240628:184114.447 SNMP monitoring: YES
    1040:20240628:184114.447 IPMI monitoring: YES
    1040:20240628:184114.447 Web monitoring: YES
    1040:20240628:184114.447 VMware monitoring: YES
    1040:20240628:184114.447 SMTP authentication: YES
    1040:20240628:184114.447 ODBC: YES
    1040:20240628:184114.447 SSH support: YES
    1040:20240628:184114.447 IPv6 support: YES
    1040:20240628:184114.447 TLS support: YES
    1040:20240628:184114.447 ******************************
    1040:20240628:184114.447 using configuration file: /etc/zabbix/zabbix_server.conf
    1040:20240628:184115.550 current database version (mandatory/optional): 07000000/07000000
    1040:20240628:184115.550 required mandatory version: 07000000
    1051:20240628:184115.805 starting HA manager
    1051:20240628:184115.991 HA manager started in active mode
    1040:20240628:184116.007 server #0 started [main process]
    1053:20240628:184116.008 server #1 started [service manager #1]
    1054:20240628:184116.009 server #2 started [configuration syncer #1]
    1058:20240628:184118.681 server #3 started [alert manager #1]
    1059:20240628:184118.682 server #4 started [alerter #1]
    1060:20240628:184118.682 server #5 started [alerter #2]
    1061:20240628:184118.683 server #6 started [alerter #3]
    1063:20240628:184118.684 server #7 started [preprocessing manager #1]
    1064:20240628:184118.685 server #8 started [lld manager #1]
    1065:20240628:184118.686 server #9 started [lld worker #1]
    1066:20240628:184118.686 server #10 started [lld worker #2]
    1073:20240628:184118.690 server #15 started [discovery manager #1]
    1074:20240628:184118.691 server #16 started [history syncer #1]
    1075:20240628:184118.692 server #17 started [history syncer #2]
    1076:20240628:184118.693 server #18 started [history syncer #3]
    1078:20240628:184118.694 server #19 started [history syncer #4]
    1084:20240628:184118.696 server #22 started [self-monitoring #1]
    1067:20240628:184118.702 server #11 started [housekeeper #1]
    1068:20240628:184118.702 server #12 started [timer #1]
    1070:20240628:184118.703 server #13 started [http poller #1]
    1093:20240628:184118.704 server #30 started [trapper #1]
    1072:20240628:184118.704 server #14 started [browser poller #1]
    1094:20240628:184118.706 server #31 started [trapper #2]
    1087:20240628:184118.707 server #24 started [poller #1]
    1095:20240628:184118.708 server #32 started [trapper #3]
    1088:20240628:184118.709 server #25 started [poller #2]
    1089:20240628:184118.711 server #26 started [poller #3]
    1090:20240628:184118.712 server #27 started [poller #4]
    1091:20240628:184118.713 server #28 started [poller #5]
    1097:20240628:184118.714 server #33 started [trapper #4]
    1092:20240628:184118.715 server #29 started [unreachable poller #1]
    1103:20240628:184118.717 server #35 started [icmp pinger #1]
    1104:20240628:184118.717 server #36 started [alert syncer #1]
    1099:20240628:184118.718 server #34 started [trapper #5]
    1086:20240628:184118.719 server #23 started [task manager #1]
    1106:20240628:184118.721 server #37 started [history poller #1]
    1080:20240628:184118.722 server #20 started [escalator #1]
    1110:20240628:184118.725 server #38 started [history poller #2]
    1082:20240628:184118.728 server #21 started [proxy poller #1]
    1111:20240628:184118.729 server #39 started [history poller #3]
    1118:20240628:184118.741 server #40 started [history poller #4]
    1119:20240628:184118.743 server #41 started [history poller #5]
    1120:20240628:184118.744 server #42 started [availability manager #1]
    1121:20240628:184118.745 server #43 started [trigger housekeeper #1]
    1073:20240628:184118.760 for a discovery process with 5 workers, the user limit of 1024 file descriptors is insufficient. The maximum number of concurrent checks pe
    r worker has been reduced to 122
    1125:20240628:184118.770 server #44 started [odbc poller #1]
    1130:20240628:184118.787 server #48 started [configuration syncer worker #1]
    1131:20240628:184118.788 server #49 started [internal poller #1]
    1126:20240628:184118.793 server #45 started [http agent poller #1]
    1128:20240628:184118.794 server #46 started [agent poller #1]
    1129:20240628:184118.795 server #47 started [snmp poller #1]
    1126:20240628:184118.796 thread started
    1129:20240628:184118.799 thread started
    1128:20240628:184118.802 thread started
    1136:20240628:184118.806 server #50 started [proxy group manager #1]
    1063:20240628:184118.854 [1] thread started [preprocessing worker #1]
    1063:20240628:184118.854 [2] thread started [preprocessing worker #2]
    1063:20240628:184118.854 [3] thread started [preprocessing worker #3]
    1073:20240628:184118.964 thread started [discovery worker #1]
    1073:20240628:184118.964 thread started [discovery worker #2]
    1073:20240628:184118.964 thread started [discovery worker #3]
    1073:20240628:184118.965 thread started [discovery worker #4]
    1073:20240628:184118.965 thread started [discovery worker #5]
    1063:20240628:184129.797 [3] cannot convert value from double to uint64
    1063:20240628:184629.796 [3] cannot convert value from double to uint64
    1063:20240628:185129.796 [1] cannot convert value from double to uint64
    1063:20240628:185629.797 [3] cannot convert value from double to uint64
    1063:20240628:190129.797 [3] cannot convert value from double to uint64
    Thanks!
  • Answer selected by Markku at 04-07-2024, 08:03.
    Steve1964
    • Jun 2024
    Solved: This was a user error. When I created a local admin user, I made the role "admin". I should have made the role "Super Admin". Hope this helps someone else.
    • Steve1964
      • Jun 2024
