pagefile perf_counters only partially working
  • tomstocker
    • Jan 2024
    • 16
    Hi all
    Only the _Total perf counter are working. Agent2 v7.0, windows server 2022.
    # zabbix_get -s hostname -k 'perf_counter["\Paging File(\??\c:\pagefile.sys\)\% Usage"]' -p 10050
    zabbix_get [1916354]: Check access restrictions in Zabbix agent configuration
    # zabbix_get -s hostname -k 'perf_counter["\Paging File(\??\c:\pagefile.sys\)\% Usage Peak"]' -p 10050
    zabbix_get [1916719]: Check access restrictions in Zabbix agent configuration
    # zabbix_get -s hostname -k 'perf_counter["\Paging File(_Total)\% Usage"]' -p 10050
    14.957886
    # zabbix_get -s hostname -k 'perf_counter["\Paging File(_Total)\% Usage Peak"]' -p 10050
    15.463867
    any idea why?
  • Answer selected by Markku at 03-07-2024, 16:57.
    Markku
    • Sep 2018
    • 1788
    You have an extra backslash in the pagefile name. Without it works here:
    PS C:\Program Files\Zabbix Agent> .\zabbix_agentd.exe -t 'perf_counter["\Paging File(\??\C:\pagefile.sys)\% Usage Peak"]'
    perf_counter[\Paging File(\??\C:\pagefile.sys)\% Usage Peak] [d|25.936247173108551]
    PS C:\Program Files\Zabbix Agent> .\zabbix_agentd.exe -t 'perf_counter["\Paging File(\??\C:\pagefile.sys\)\% Usage Peak"]'
    perf_counter[\Paging File(\??\C:\pagefile.sys\)\% Usage Peak] [m|ZBX_NOTSUPPORTED] [Cannot obtain performance information from collector.]
    Markku
    • Markku
      • Sep 2018
      • 1788
      Markku
      • tomstocker
        • Jan 2024
        • 16
        Your're absolutely right, thanks for spotting. PEBCAK error :-)
        (Get-Counter -ListSet * | select -expand PathsWithInstances | Select-String -Pattern "Paging")
