Zabbix 7.0: custom global scripts executed on server instead of proxy
  • PsP
    • Mar 2023
    Custom global scripts defined as Execute on "Zabbix proxy or server" are always started on server (as per logs trace).
    Official doc states:"Zabbix proxy or server - the script will be executed by Zabbix proxy or server - depending on whether the host is monitored by proxy or server."
    Any thoughts?
  • Markku
    • Sep 2018
    • 1788
    If you think that's a bug (you did ask this earlier already), you can open a ticket in the Zabbix support portal (shortlink).
    Markku
    • PsP
      PsP commented
      I will do. Sorry for double post.
      Thanks for your feedback.
  • Markku
    • Sep 2018
    • 1788
    I didn't find an issue for this, so I opened one: ZBX-24800 ("Remote command not executed on proxy but on server")
    Please vote for that issue if you experience the same problem.
    Markku
    • PsP
      • Mar 2023
      Thanks Markku, we have exactly the problem you described. Since we use this method for many pro-active actions, as a temporary workaround for our high priority actions here is one (less than ideal) solution:
      1. On every proxy install zabbix-agent2
      2. Move the Command defined in Action Script from the server to the relevant Proxy (or Proxies) as UserParameter
      3. Invoke the Action Script using zabbix_get command passing the right Proxy as a parameter (defined for example as a tag in the trigger): zabbix_get -s {EVENT.TAGS.proxyagent} -k CommandName[...]
      Of course in this way we have to "statically" indicate the proper Proxy that monitor the host instead of using the one defined in the standard configuration...
      • PsP
        • Mar 2023
        Upgraded to v7.0.1, same issue (actually ZBX-24800 in not present on release notes as fixed).
        • Markku
          • Sep 2018
          • 1788
          Yeah, there isn't any kind of progress logged yet in the issue.
          Markku
          • PsP
            • Mar 2023
            Just a quick update: thanks to Markku the issue has been raised and managed. It is currently under QA state.
            • PsP
              • Mar 2023
              I can confirm that v.7.0.3 fixes ZBX-24800. Custom global scripts are now properly executed.
