I'm using dockerized zabbix 5.0. It've worked fine until in-place upgrade from Centos7 to Rocky linux 8. Now it works only from inside of the zabbix-web-apache-mysql container. From the docker host it has no connection.
curl from the web container:
curl from the docker host:
lsof -Pi
docker ps | grep zabbix
firewall-cmd --zone=docker --list-all
docker-compose.yaml:
curl -vvv http://127.0.0.1:8080
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="X-UA-Compatible" content="IE=Edge"/>
<meta charset="utf-8" />
<meta name="viewport" content="width=device-width, initial-scale=1">
<meta name="Author" content="Zabbix SIA" />
<title>Composed installation: Zabbix</title>
<link rel="icon" href="favicon.ico">
curl -vvv 127.0.0.1:8080 * Rebuilt URL to: 127.0.0.1:8080/ * Trying 127.0.0.1... * TCP_NODELAY set * Connected to 127.0.0.1 (127.0.0.1) port 8080 (#0) > GET / HTTP/1.1 > Host: 127.0.0.1:8080 > User-Agent: curl/7.61.1 > Accept: */* > * Recv failure: Connection reset by peer * Closing connection 0 curl: (56) Recv failure: Connection reset by peer
lsof -Pi | grep "8080" docker-pr 1152020 root 4u IPv4 9603312 0t0 TCP localhost:8080 (LISTEN)
docker ps | grep zabbix b312fa9d9fcb zabbix/zabbix-agent:alpine-5.0.22 "/sbin/tini -- /usr/…" 4 hours ago Up 4 hours zabbix-docker-50_zabbix-agent_1 af75ba9a841a zabbix/zabbix-web-apache-mysql:alpine-5.0.22 "docker-entrypoint.s…" 4 hours ago Up 4 hours (healthy) 127.0.0.1:8080->8080/tcp, 8443/tcp zabbix-docker-50_zabbix-web-apache-mysql_1 9fa9b3aea444 my/zabbix "/sbin/tini -- /usr/…" 4 hours ago Up 4 hours 0.0.0.0:10051->10051/tcp, :::10051->10051/tcp zabbix-docker-50_zabbix-server_1 0ff85d1af06e mysql:8.0 "docker-entrypoint.s…" 4 hours ago Up 4 hours zabbix-docker-50_mysql-server_1
docker (active) target: ACCEPT icmp-block-inversion: no interfaces: be17954e014c ... docker0 ... sources: services: ports: protocols: forward: no masquerade: no forward-ports: source-ports: icmp-blocks: rich rules:
version: '3.5'
services:
zabbix-server:
#image: zabbix/zabbix-server-mysql:alpine-5.0-latest
image: my/zabbix
ports:
- "10051:10051"
volumes:
- /etc/localtime:/etc/localtime:ro
#- /etc/timezone:/etc/timezone:ro
- ./zbx_env/usr/lib/zabbix/alertscripts:/usr/lib/zabbix/alertscripts:ro
- ./zbx_env/usr/lib/zabbix/externalscripts:/usr/lib/zabbix/externalscripts:ro
- ./zbx_env/var/lib/zabbix/export:/var/lib/zabbix/export:rw
- ./zbx_env/var/lib/zabbix/modules:/var/lib/zabbix/modules:ro
- ./zbx_env/var/lib/zabbix/enc:/var/lib/zabbix/enc:ro
- ./zbx_env/var/lib/zabbix/ssh_keys:/var/lib/zabbix/ssh_keys:ro
- ./zbx_env/var/lib/zabbix/mibs:/var/lib/zabbix/mibs:ro
#- snmptraps:/var/lib/zabbix/snmptraps:rw
links:
- mysql-server:mysql-server
# - zabbix-java-gateway:zabbix-java-gateway
ulimits:
nproc: 65535
nofile:
soft: 20000
hard: 40000
deploy:
resources:
limits:
cpus: '0.50'
memory: 1G
reservations:
cpus: '0.3'
memory: 512M
env_file:
- .env_db_mysql
- .env_srv
secrets:
- MYSQL_USER
- MYSQL_PASSWORD
- MYSQL_ROOT_PASSWORD
depends_on:
- mysql-server
networks:
zbx_net_backend:
aliases:
- zabbix-server
- zabbix-server-mysql
- zabbix-server-alpine-mysql
- zabbix-server-mysql-alpine
zbx_net_frontend:
stop_grace_period: 30s
sysctls:
- net.ipv4.ip_local_port_range=1024 65000
- net.ipv4.conf.all.accept_redirects=0
- net.ipv4.conf.all.secure_redirects=0
- net.ipv4.conf.all.send_redirects=0
labels:
com.zabbix.description: "Zabbix server with MySQL database support"
com.zabbix.company: "Zabbix LLC"
com.zabbix.component: "zabbix-server"
com.zabbix.dbtype: "mysql"
com.zabbix.os: "alpine"
image: zabbix/zabbix-web-apache-mysql:alpine-5.0.22
ports:
- "127.0.0.1:8080:8080"
links:
- zabbix-server:zabbix-server
volumes:
# - /etc/timezone:/etc/timezone:ro
- ./zbx_env/etc/ssl/apache2:/etc/ssl/apache2:ro
- ./zbx_env/usr/share/zabbix/modules/:/usr/share/zabbix/modules/:ro
- ./zbx_env/etc/zabbix/apache.conf:/etc/zabbix/apache.conf
deploy:
resources:
limits:
cpus: '0.50'
memory: 512M
reservations:
cpus: '0.3'
memory: 256M
env_file:
- .env_db_mysql
- .env_web
secrets:
- MYSQL_USER
- MYSQL_PASSWORD
depends_on:
- mysql-server
- zabbix-server
healthcheck:
test: ["CMD", "curl", "-f", "http://localhost:8080/"]
interval: 10s
timeout: 5s
retries: 3
start_period: 30s
networks:
zbx_net_backend:
aliases:
- zabbix-web-apache-mysql
- zabbix-web-apache-alpine-mysql
- zabbix-web-apache-mysql-alpine
zbx_net_frontend:
stop_grace_period: 10s
sysctls:
- net.core.somaxconn=65535
labels:
com.zabbix.description: "Zabbix frontend on Apache web-server with MySQL database support"
com.zabbix.component: "zabbix-frontend"
com.zabbix.webserver: "apache2"
zabbix-agent:
image: zabbix/zabbix-agent:alpine-5.0.22
ports:
- "10050:10050"
volumes:
- ./zbx_env/etc/zabbix/zabbix_agentd.d:/etc/zabbix/zabbix_agentd.d:ro
links:
deploy:
resources:
limits:
cpus: '0.2'
memory: 128M
reservations:
cpus: '0.1'
memory: 64M
mode: global
env_file:
- .env_agent
privileged: true
pid: "host"
networks:
zbx_net_backend:
aliases:
- zabbix-agent
- zabbix-agent-passive
- zabbix-agent-alpine
stop_grace_period: 5s
labels:
com.zabbix.description: "Zabbix agent"
com.zabbix.component: "zabbix-agentd"
mysql-server:
image: mysql:8.0
command:
- mysqld
- --character-set-server=utf8
- --collation-server=utf8_bin
- --default-authentication-plugin=mysql_native_password
volumes:
- ./zbx_env/var/lib/mysql:/var/lib/mysql:rw
env_file:
- .env_db_mysql
secrets:
- MYSQL_USER
- MYSQL_PASSWORD
stop_grace_period: 1m
networks:
zbx_net_backend:
aliases:
- mysql-server
- zabbix-database
- mysql-database
db_data_mysql:
image: busybox
volumes:
networks:
zbx_net_frontend:
driver: bridge
driver_opts:
com.docker.network.enable_ipv6: "true"
ipam:
driver: default
config:
- subnet: 172.16.238.0/24
zbx_net_backend:
driver: bridge
driver_opts:
internal: true
ipam:
driver: default
config:
- subnet: 172.16.239.0/24
secrets:
MYSQL_USER:
file: ./.MYSQL_USER
MYSQL_PASSWORD:
file: ./.MYSQL_PASSWORD
MYSQL_ROOT_PASSWORD:
file: ./.MYSQL_ROOT_PASSWORD
