Zabbix database version problem
  • blender
    • Jul 2024
    Hello everyone,
    After the installtion, I got this error message:
    The server does not match zabbix database. Current database version (mandatory/optional): 07000000/07000000. Required version: 5000000.
    #zabbix_server --version
    5.0.17
  • sokeada
    • Jun 2024
    • 25
    looks like you have higher db version than your zabbix require.
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      You have pointed Zabbix server version 5.0 to the database of Zabbix version 7.0 . This won't work. If the database is correct you need to upgrade your Zabbix server to 7.0, instructions provided here might help: https://www.zabbix.com/download
      But make sure you know exactly what you are doing. Database backups never hurt.
