Cisco Meraki showing " There are errors in "Get data" metric
  • vireak
    • May 2024
    • 11
    Hello Team,
    I am currently onboard Cisco Meraki via dashboard by HTTP into Zabbix, After i done with Discovery Meraki node, I cannot get data from Meraki dashboard and device node is showing like this.
    Thanks,
    Vireak
  • owentl
    • Jul 2024
    Did you set the Macro on your host for the Meraki API key? The Macro is {$MERAKI.TOKEN}
    • vireak
      • May 2024
      • 11
      Hi Owen, i have set Macro for API token already, as i have read some document, it also require API URL too. I am not sure i put API URL right. I use the login dashboard URL for this.
      • owentl
        • Jul 2024
        I didn't have to update the URL, it inherited it from the template. One gotcha I did find, even though there is a Macro for filtering Orgs it does not respect that for devices. My API key has access to multiple orgs and it only brought in the single org but all devices for all orgs I can access!
        • sfuller
          sfuller commented
          Owentl,
          I am in a similar situation right now. Did you figure out a way around this issue?
      • vireak
        • May 2024
        • 11
        Hi Owentl, thanks. this case has been resolved. So far, i put API key and API url correctly. the issue relate to firewall policy.
