Need help with smartmontools
  • Durwin
    • Apr 2015
    • 19
    I am using smartmontools.
    I have everything working but windows. When I run the command below from the Windows machine I get what is expected.
    powershell -NoProfile -ExecutionPolicy Bypass -File "D:\home\Administrator\zbx-smartctl\discovery-scripts\windows\smartctl-disks-discovery.ps1"
     "data":[
                    "{#DISKNAME}":"/dev/hda",
                    "{#SMART_ENABLED}":"1"
                    "{#DISKNAME}":"/dev/hdb",
                    "{#DISKNAME}":"/dev/hdc",
                    "{#DISKNAME}":"/dev/hdd",
    But when I execute this command, It returns '0' where it should show '1'.
    zabbix_get -s 172.23.93.4 -k uHDD.discovery
     "data":[
                    "{#SMART_ENABLED}":"0"
    I have Cygwin installed and using smartctl from the installation. It *does* work when run on the Windows machine, but not remotely using zabbix_get. When I run the 'zabbix_get' command on the windows machine, I also get zeros.
    Anyone have an idea on what to look at or how to further test?
    Thank you,
    Durwin
  • nobodysu
    • Sep 2016
    • 84
    Guess thats the case. Try using native windows smartmontools.
    • Durwin
      • Apr 2015
      • 19
      That is certainly worth a try. I'll try it when I get back to work next week.
      Thank you.
      • Durwin
        • Apr 2015
        • 19
        [solved]
        Turns out using Windows Smartctl does work. There must be something odd with using Cygwin's build.
