website certificate by zabbix agent 2 "failed to verify certicate"
  • Sieniu
    • Jul 2024
    HI,
    I have same wildcare certificate (*.domain.com) on two urls: https://example1.domain.com and https://example2.domain.com
    I use "website certificate by zabbix agent 2" to check validate certificate. When I check example1.domain.com by agent 2 installed on centos 8.10 it returns result that certificate is invalid and "failed to verify certificate: x509: certificate signed by unknown authority""
    when I check second url example2.domain.com by agent 2 installed on centos 8.5 it returns correct result "valid".
    Where could be the problem?
    I used zabbix 6.4.15
  • Answer selected by Sieniu at 15-07-2024, 11:10.
    Markku
    • Sep 2018
    • 1784
    Are the websites configured correctly to return both the site certificate and the intermediate certificate(s) (= the chain)? If the website does not provide the intermediate certificate (that is usually used in the trust chain) then the TLS client cannot verify the certificate.
    You can use command like
    echo | openssl s_client -connect example1.domain.com:443
    to test the connection.
    Markku
    • Markku
      • Sep 2018
      • 1784
      Markku
      • Sieniu
        • Jul 2024
        Markku Thank you very much, exactly problem was that one server doesn't have chain
