Zabbix disk space variable
  • hasnainw
    • Jul 2024
    We are fairly new to Zabbix in our environment and are trying to better understand how the triggers and items work. We are trying to change the disk percentage to which triggers and alert. Instead of it being 90 percent for critical and 80 for warning, how is this changed. Is it necessary to create our own item and trigger?
    Where can we find these variable to configure. Thank you
  • Markku
    • Sep 2018
    • 1784
    Which template are you using? There should be macros defined in the template, so go to the host's Macros tab and click "Inherited and host macros" to see the inherited macros. Then you can customize the values at the host level.
    Markku
