Zabbix VMWare Datastore space monitoring
  • Kevin Nelson
    • Feb 2024
    I have the VMWare template monitoring my datastores with the default threshold of 10%. I have a couple of datastores within this set up to have a different threshold. I have tried cloning an existing 'Trigger Prototype' but I get an error each time. Is there a method to follow to do this or a better way to have a separate threshold for a datastore?
    Thank you
  • Markku
    • Sep 2018
    • 1788
    What is the template you are using? I don't directly find a VMware template that has trigger prototype for datastore space.
    But in general, usually disk space trigger prototypes use user macros with context in the expression: https://www.zabbix.com/documentation...macros_context
    Markku
    • paulb007
      • May 2025
      Hi
      Just following up on this...
      I see on the Windows and Linux Templates the following Triggers
      WINDOWS - Trigger Expression
      min(/Windows by Zabbix agent updated dashboards/vfs.fs.dependent.size[{#FSNAME},pused],5m)>{$VFS.FS.PUSED.MAX.WARN:"{#FSLABEL}({#FSNAME} )"}
      Linux - Trigger Expression
      min(/Linux by Zabbix agent updated dashboards/vfs.fs.dependent.size[{#FSNAME},pused],5m)>{$VFS.FS.PUSED.MAX.CRIT:"{#FSNAME}"}
      However, the VMWARE Template (https://git.zabbix.com/projects/ZBX/...at=release/7.4)
      Trigger Expression
      last(/VMware/vmware.datastore.size[{$VMWARE.URL},{#DATASTORE.UUID},pfree])<{$VMWARE.DATASTORE.SPACE.WARN}
      Based on this it seems that you cannot create different thresholds for different datastores... What I am wondering is, should the trigger have the {#DATASTORE.UUID} after the {$VMWARE.DATASTORE.SPACE.WARN}
      Something like this
      last(/VMware/vmware.datastore.size[{$VMWARE.URL},{#DATASTORE.UUID},pfree])<{$VMWARE.DATASTORE.SPACE.WARN:"{#DATASTORE.UUID} "}
      Thanks​
      • Markku
        • Sep 2018
        • 1788
        Originally posted by paulb007
        Something like this
        That would make it possible to customize the trigger threshold for each datastore, yes, by defining separate context macros for them.
        (Edit: There was an extra space inside the quotes, but it could have been a typical error in this forum software)
        Markku
        • paulb007
          • May 2025
          Is this something that should be added to official template? If so, is there a process to get the template updated? I think the Template VMware Hypervisor, and VMware FQDN would also need to be updated.
          • Markku
            • Sep 2018
            • 1788
            Feature request ticket for improving the official templates can be opened at https://support.zabbix.com/.
            Markku
