Zabbix server is not running
  • skritek
    • Jul 2024
    Please help. I'm not a Linux expert. After restarting the Linux server on the Zabbix website, I got the message: "Zabbix server is not running". I read a lot of guides to fix this problem but none helped. The server has been running for almost a year without a reboot and Ubuntu has been updated several times in the meantime.
    Zabbix 6.2 runs on Ubuntu 22.04.4.
    The zabbix-server service is active (exited). It doesn't even create a log file. The zabbix-agent service is running.
    Thanks in advance for any suggestions.
    Good day Miroslav
  • Markku
    • Sep 2018
    • 1788
    sudo systemctl restart zabbix-server
    sudo tail -100 /var/log/zabbix/zabbix_server.log
    Markku
    • skritek
      • Jul 2024
      Hello Markku,
      thank you for answer. I have tried these commands before. The zabbix-server service is still active (exited). The Zabbix-server starts and immediately stops. Even creating a log file is not enough.
      Miroslav
      • Markku
        • Sep 2018
        • 1788
        sudo journalctl -u zabbix-server
        If the Zabbix log file stays empty, I don't think the service even starts.
        Markku
        • millnet-maho
          • Nov 2022
          The .deb packages published by Zabbix themselves run zabbix_server as a forking daemon, which means that if it immediately exits with a non-zero status (or if systemd fails to execute it at all), systemd should consider it to have failed to start, but if it exists with a zero status, but without forking off any child process, or the child process(es) exit(s) with a zero status, systemd will show it as "active (exited)". But in that case I'd expect it to have written something to its log.
          • skritek
            • Jul 2024
            Hallo,
            Thanks for both answers.
            I did:
            Result:
            Jun 31 12:12:59 COS-LS1 systemd[1]: Stopping LSB: Start zabbix-server daemon...
            Jun 31 12:12:59 COS-LS1 systemd[1]: zabbix-server.service: Deactivated successfully.
            Jun 31 12:12:59 COS-LS1 systemd[1]: Stopped LSB: Start zabbix-server daemon.
            Jun 31 12:12:59 COS-LS1 systemd[1]: Starting LSB: Start zabbix-server daemon...
            Jun 31 12:12:59 COS-LS1 systemd[1]: Started LSB: Start zabbix-server daemon.
            Log file is still without update:
            -rw-r----- 1 zabbix zabbix 3099395 čec 28 13:21 zabbix_server.log
            Last rows:
            1322:20240728:132128.014 Got signal [signal:15(SIGTERM),sender_pid:1,sender_uid:0,reaso n:0]. Exiting ...
            1419:20240728:132128.015 HA manager has been paused
            1536:20240728:132128.015 syncing history data in progress...
            1536:20240728:132128.015 syncing history data done
            1527:20240728:132128.016 [2] thread stopped [preprocessing worker #2]
            1527:20240728:132128.016 [1] thread stopped [preprocessing worker #1]
            1527:20240728:132128.017 [3] thread stopped [preprocessing worker #3]
            1419:20240728:132129.084 HA manager has been stopped
            1322:20240728:132129.090 syncing trend data...
            1322:20240728:132129.177 syncing trend data done
            1322:20240728:132129.185 Zabbix Server stopped. Zabbix 6.4.11 (revision fb6439a26e3).
            ​Best regards Miroslav
            • Markku
              • Sep 2018
              • 1788
              So journalctl just shows that the service (apparently 6.4.11, not 6.2, but anyway) has been started, and no output in the log file. Please show the full output of "sudo systemctl status zabbix-server"
              Markku
              • millnet-maho
                • Nov 2022
                What language is "Jun 31"? Surely not the same as "čec 28"? There are no languages where July is abbreviated "Jun", are there? But there are only 30 days in June...
                Regardless, are you showing the most recent journal entries?
                • skritek
                  • Jul 2024
                  root@COS-LS1:/var/log/zabbix# sudo systemctl status zabbix-server
                  ● zabbix-server.service - LSB: Start zabbix-server daemon
                  Loaded: loaded (/etc/init.d/zabbix-server; generated)
                  Active: active (exited) since Wed 2024-07-31 12:12:59 CEST; 2h 46min ago
                  Docs: man:systemd-sysv-generator(8)
                  Process: 17471 ExecStart=/etc/init.d/zabbix-server start (code=exited, status=0/SUCCESS)
                  CPU: 1ms
                  čec 31 12:12:59 COS-LS1 systemd[1]: Starting LSB: Start zabbix-server daemon...
                  čec 31 12:12:59 COS-LS1 systemd[1]: Started LSB: Start zabbix-server daemon.
                  Thank you.
                  Miroslav
                  • Markku
                    • Sep 2018
                    • 1788
                    That "/etc/init.d/zabbix-server; generated" looks strange. I don't use Ubuntu, but it just smells something that was not-Zabbix-provided, and is very different from the config files on Debian.
                    Since you have an existing installation (and not a newly setup one), you may want to be careful, but I would just make relevant backups, then "sudo apt purge zabbix\*" (to remove any existing packages about Zabbix), and install Zabbix 6.4 from the official Zabbix download page instructions (except the database of course, use the existing settings for it).
                    Markku
                    • skritek
                      • Jul 2024
                      Hello Markku,
                      Thank you for your answer. I assumed a Zabbix fix.
                      After uninstalling "sudo apt purge zabbix\*" can I use the upgrade steps: "https://www.zabbix.com/documentation/6.4/en/manual/installation/upgrade/packages/debian_ubuntu" ?
                      Best regards, Miroslav
                      • Markku
                        • Sep 2018
                        • 1788
                        You need to follow the new install instructions (except to create new Zabbix database) because after purging the packages there aren't any Zabbix packages to upgrade anymore.
                        Markku
                        • skritek
                          • Jul 2024
                          Hallo Markku,
                          thank You. I will try it.
                          Best regards. Miroslav
                          • skritek
                            • Jul 2024
                            Hallo Makku,
                            all happened well.
                            Many thanks.
                            Miroslav
