zabbix server won't start
  • elham_jahany
    • Jan 2017
    I compile zabbix 3.2 on centos (with db2)
    when I enable "DBSchema" configuration (in zabbix_server.conf) the zabbix_server can not start.
    I change the debug level of zabbix server to 5 and the result is :
    tail -f /var/log/zabbix_server.log
    4293:20170108:082441.986 In DBcheck_version()
    4293:20170108:082441.986 In DBconnect() flag:0
    4293:20170108:082441.998 query without transaction detected
    4293:20170108:082441.999 query [txnlev:0] [set current schema='ZABBIX']
    4293:20170108:082441.999 End of DBconnect():0
    4293:20170108:082441.999 query [txnlev:0] [select 1 from syscat.tables where tabschema=user and lower(tabname)='dbversion']
    4293:20170108:082442.031 DBcheck_version() "dbversion" does not exist
    4293:20170108:082442.031 query [txnlev:0] [select 1 from syscat.columns where tabschema=user and lower(tabname)='config' and lower(colname)='server_check_interval']
    4293:20170108:082442.051 Cannot upgrade database: the database must correspond to version 2.0 or later. Exiting ...
    4293:20170108:082442.053 End of DBcheck_version():FAIL
    i have no idea about this problem.
    db2 configuration is set and every things is OK and web installation steps is pass but zabbix_server can not start
