Zabbix server crash in 6.0.32 on Debian 12
  • aschild
    • Sep 2014
    • 25
    since a few days our Zabbix Server service is crashing almost as soon as the service is started.
    Here the log of the zabbix server
     45671:20240806:194207.188 Starting Zabbix Server. Zabbix 6.0.32 (revision e0ebc610bbe).
     45671:20240806:194207.188 ****** Enabled features ******
     45671:20240806:194207.188 SNMP monitoring:           YES
     45671:20240806:194207.188 IPMI monitoring:           YES
     45671:20240806:194207.188 Web monitoring:            YES
     45671:20240806:194207.188 VMware monitoring:         YES
     45671:20240806:194207.188 SMTP authentication:       YES
     45671:20240806:194207.188 ODBC:                      YES
     45671:20240806:194207.188 SSH support:               YES
     45671:20240806:194207.188 IPv6 support:              YES
     45671:20240806:194207.188 TLS support:               YES
     45671:20240806:194207.188 ******************************
     45671:20240806:194207.188 using configuration file: /etc/zabbix/zabbix_server.conf
     45671:20240806:194416.784 current database version (mandatory/optional): 06000000/06000045
     45671:20240806:194416.784 required mandatory version: 06000000
     45671:20240806:194416.786 database could be upgraded to use primary keys in history tables
     45671:20240806:194416.788 database is not upgraded to use double precision values
     45689:20240806:194416.789 starting HA manager
     45671:20240806:194426.801 server #0 started [main process]
     45690:20240806:194426.802 server #1 started [service manager #1]
     45691:20240806:194426.803 server #2 started [configuration syncer #1]
     45689:20240806:194627.863 HA manager started in active mode
     45689:20240806:194627.863 cannot write to IPC socket: Broken pipe
     45743:20240806:194847.111 server #3 started [alert manager #1]
     45744:20240806:194847.111 server #4 started [alerter #1]
     45747:20240806:194847.113 server #7 started [preprocessing manager #1]
     45745:20240806:194847.113 server #5 started [alerter #2]
     45748:20240806:194847.114 server #8 started [preprocessing worker #1]
     45746:20240806:194847.114 server #6 started [alerter #3]
     45749:20240806:194847.115 server #9 started [preprocessing worker #2]
     45750:20240806:194847.115 server #10 started [preprocessing worker #3]
     45751:20240806:194847.116 server #11 started [lld manager #1]
     45752:20240806:194847.116 server #12 started [lld worker #1]
     45753:20240806:194847.117 server #13 started [lld worker #2]
     45754:20240806:194847.117 server #14 started [housekeeper #1]
     45755:20240806:194847.118 server #15 started [timer #1]
     45757:20240806:194847.125 server #17 started [http poller #2]
     45758:20240806:194847.126 server #18 started [http poller #3]
     45759:20240806:194847.127 server #19 started [http poller #4]
     45756:20240806:194847.127 server #16 started [http poller #1]
     45761:20240806:194847.131 server #21 started [discoverer #1]
     45763:20240806:194847.136 server #23 started [history syncer #2]
     45762:20240806:194847.136 server #22 started [history syncer #1]
     45760:20240806:194847.141 server #20 started [http poller #5]
     45765:20240806:194847.143 server #25 started [history syncer #4]
     45767:20240806:194847.145 server #27 started [history syncer #6]
     45768:20240806:194847.145 server #28 started [history syncer #7]
     45766:20240806:194847.146 server #26 started [history syncer #5]
     45764:20240806:194847.151 server #24 started [history syncer #3]
     45770:20240806:194847.151 server #30 started [history syncer #9]
     45771:20240806:194847.152 server #31 started [history syncer #10]
     45773:20240806:194847.153 server #33 started [java poller #1]
     45774:20240806:194847.153 server #34 started [java poller #2]
     45775:20240806:194847.154 server #35 started [java poller #3]
     45776:20240806:194847.155 server #36 started [java poller #4]
     45769:20240806:194847.158 server #29 started [history syncer #8]
     45782:20240806:194847.159 server #42 started [java poller #10]
     45780:20240806:194847.159 server #40 started [java poller #8]
     45778:20240806:194847.162 server #38 started [java poller #6]
     45772:20240806:194847.162 server #32 started [escalator #1]
     45781:20240806:194847.163 server #41 started [java poller #9]
     45779:20240806:194847.163 server #39 started [java poller #7]
     45777:20240806:194847.166 server #37 started [java poller #5]
     45783:20240806:194847.170 server #43 started [snmp trapper #1]
     45784:20240806:194847.171 server #44 started [proxy poller #1]
     45786:20240806:194847.173 server #46 started [self-monitoring #1]
     45787:20240806:194847.173 server #47 started [task manager #1]
     45788:20240806:194847.173 server #48 started [poller #1]
     45785:20240806:194847.175 server #45 started [proxy poller #2]
     45795:20240806:194847.178 server #55 started [poller #8]
     45792:20240806:194847.179 server #52 started [poller #5]
     45789:20240806:194847.179 server #49 started [poller #2]
     45794:20240806:194847.179 server #54 started [poller #7]
     45793:20240806:194847.180 server #53 started [poller #6]
     45790:20240806:194847.183 server #50 started [poller #3]
     45797:20240806:194847.184 server #56 started [poller #9]
     45791:20240806:194847.187 server #51 started [poller #4]
     45802:20240806:194847.192 server #58 started [poller #11]
     45805:20240806:194847.197 server #61 started [poller #14]
     45808:20240806:194847.198 server #64 started [poller #17]
     45804:20240806:194847.202 server #60 started [poller #13]
     45807:20240806:194847.204 server #63 started [poller #16]
     45803:20240806:194847.207 server #59 started [poller #12]
     45809:20240806:194847.211 server #65 started [poller #18]
     45800:20240806:194847.212 server #57 started [poller #10]
     45810:20240806:194847.215 server #66 started [poller #19]
     45806:20240806:194847.215 server #62 started [poller #15]
     45811:20240806:194847.223 server #67 started [poller #20]
     45816:20240806:194847.224 server #68 started [poller #21]
     45821:20240806:194847.228 server #73 started [poller #26]
     45819:20240806:194847.230 server #71 started [poller #24]
     45820:20240806:194847.232 server #72 started [poller #25]
     45818:20240806:194847.232 server #70 started [poller #23]
     45817:20240806:194847.233 server #69 started [poller #22]
     45822:20240806:194847.237 server #74 started [poller #27]
     45826:20240806:194847.243 server #77 started [poller #30]
     45827:20240806:194847.245 server #78 started [poller #31]
     45825:20240806:194847.245 server #76 started [poller #29]
     45824:20240806:194847.248 server #75 started [poller #28]
     45828:20240806:194847.261 server #79 started [poller #32]
     45831:20240806:194847.266 server #80 started [poller #33]
     45832:20240806:194847.268 server #81 started [poller #34]
     45836:20240806:194847.279 server #83 started [poller #36]
     45837:20240806:194847.281 server #84 started [poller #37]
     45835:20240806:194847.284 server #82 started [poller #35]
     45838:20240806:194847.289 server #85 started [poller #38]
     45842:20240806:194847.290 server #88 started [poller #41]
     45839:20240806:194847.292 server #86 started [poller #39]
     45843:20240806:194847.294 server #89 started [poller #42]
     45849:20240806:194847.294 server #95 started [poller #48]
     45852:20240806:194847.295 server #98 started [poller #51]
     45846:20240806:194847.296 server #92 started [poller #45]
     45845:20240806:194847.298 server #91 started [poller #44]
     45847:20240806:194847.298 server #93 started [poller #46]
     45844:20240806:194847.300 server #90 started [poller #43]
     45850:20240806:194847.302 server #96 started [poller #49]
     45841:20240806:194847.304 server #87 started [poller #40]
     45848:20240806:194847.305 server #94 started [poller #47]
     45851:20240806:194847.308 server #97 started [poller #50]
     45854:20240806:194847.309 server #99 started [poller #52]
     45858:20240806:194847.312 server #103 started [poller #56]
     45855:20240806:194847.313 server #100 started [poller #53]
     45856:20240806:194847.319 server #101 started [poller #54]
     45857:20240806:194847.321 server #102 started [poller #55]
     45859:20240806:194847.326 server #104 started [poller #57]
     45860:20240806:194847.328 server #105 started [poller #58]
     45862:20240806:194847.346 server #106 started [poller #59]
     45865:20240806:194847.350 server #109 started [poller #62]
     45863:20240806:194847.358 server #107 started [poller #60]
     45872:20240806:194847.359 server #116 started [poller #69]
     45864:20240806:194847.360 server #108 started [poller #61]
     45868:20240806:194847.360 server #112 started [poller #65]
     45875:20240806:194847.360 server #119 started [poller #72]
     45869:20240806:194847.362 server #113 started [poller #66]
     45879:20240806:194847.363 server #123 started [poller #76]
     45880:20240806:194847.364 server #124 started [poller #77]
     45870:20240806:194847.366 server #114 started [poller #67]
     45873:20240806:194847.366 server #117 started [poller #70]
     45874:20240806:194847.367 server #118 started [poller #71]
     45866:20240806:194847.367 server #110 started [poller #63]
     45876:20240806:194847.369 server #120 started [poller #73]
     45871:20240806:194847.370 server #115 started [poller #68]
     45888:20240806:194847.378 server #132 started [poller #85]
     45883:20240806:194847.379 server #127 started [poller #80]
    45884:20240806:194847.426 server #128 started [poller #81]
     45897:20240806:194847.435 server #140 started [poller #93]
     45906:20240806:194847.440 server #147 started [poller #100]
     45904:20240806:194847.441 server #146 started [poller #99]
     45909:20240806:194847.444 server #150 started [unreachable poller #3]
     45908:20240806:194847.445 server #149 started [unreachable poller #2]
     45907:20240806:194847.458 server #148 started [unreachable poller #1]
     45913:20240806:194847.474 server #153 started [unreachable poller #6]
     45914:20240806:194847.475 server #154 started [unreachable poller #7]
     45910:20240806:194847.484 server #151 started [unreachable poller #4]
     45923:20240806:194847.486 server #157 started [unreachable poller #10]
     45924:20240806:194847.489 server #158 started [unreachable poller #11]
     45926:20240806:194847.489 server #160 started [unreachable poller #13]
     45912:20240806:194847.491 server #152 started [unreachable poller #5]
     45925:20240806:194847.493 server #159 started [unreachable poller #12]
     45921:20240806:194847.495 server #155 started [unreachable poller #8]
     45922:20240806:194847.503 server #156 started [unreachable poller #9]
     45881:20240806:194847.510 enabling Zabbix agent checks on host "mask.digmesa.com": interface became available
     45927:20240806:194847.513 server #161 started [unreachable poller #14]
     45929:20240806:194847.518 server #163 started [unreachable poller #16]
     45928:20240806:194847.518 server #162 started [unreachable poller #15]
     45930:20240806:194847.531 server #164 started [unreachable poller #17]
     45931:20240806:194847.542 server #165 started [unreachable poller #18]
     45933:20240806:194847.569 server #167 started [unreachable poller #20]
     45932:20240806:194847.573 server #166 started [unreachable poller #19]
     45936:20240806:194847.583 server #170 started [unreachable poller #23]
     45935:20240806:194847.585 server #169 started [unreachable poller #22]
     45937:20240806:194847.590 server #171 started [unreachable poller #24]
     45934:20240806:194847.590 server #168 started [unreachable poller #21]
     45938:20240806:194847.592 server #172 started [unreachable poller #25]
     45939:20240806:194847.595 server #173 started [unreachable poller #26]
     45940:20240806:194847.599 server #174 started [unreachable poller #27]
     45941:20240806:194847.618 server #175 started [unreachable poller #28]
     45943:20240806:194847.618 server #177 started [unreachable poller #30]
     45946:20240806:194847.626 server #180 started [unreachable poller #33]
     45944:20240806:194847.628 server #178 started [unreachable poller #31]
     45945:20240806:194847.631 server #179 started [unreachable poller #32]
     45942:20240806:194847.635 server #176 started [unreachable poller #29]
     45949:20240806:194847.651 server #182 started [unreachable poller #35]
     45950:20240806:194847.657 server #183 started [unreachable poller #36]
     45948:20240806:194847.666 server #181 started [unreachable poller #34]
     45958:20240806:194847.676 server #188 started [unreachable poller #41]
     45956:20240806:194847.677 server #186 started [unreachable poller #39]
     45954:20240806:194847.681 server #185 started [unreachable poller #38]
     45957:20240806:194847.684 server #187 started [unreachable poller #40]
     45952:20240806:194847.690 server #184 started [unreachable poller #37]
     45959:20240806:194847.693 server #189 started [unreachable poller #42]
     45962:20240806:194847.699 server #192 started [unreachable poller #45]
     45961:20240806:194847.705 server #191 started [unreachable poller #44]
     45960:20240806:194847.706 server #190 started [unreachable poller #43]
     45963:20240806:194847.709 server #193 started [unreachable poller #46]
     45964:20240806:194847.709 server #194 started [unreachable poller #47]
     45966:20240806:194847.734 server #195 started [unreachable poller #48]
     45931:20240806:194847.751 enabling Zabbix agent checks on host "bbb2.ngft.com": interface became available
     45938:20240806:194847.752 resuming Zabbix agent checks on host "fw.archgmbh.local": connection restored
     45912:20240806:194847.755 enabling Zabbix agent checks on host "fw.seelandplan.ch": interface became available
     45978:20240806:194847.764 server #196 started [unreachable poller #49]
     45979:20240806:194847.765 server #197 started [unreachable poller #50]
     45980:20240806:194847.767 server #198 started [trapper #1]
     45981:20240806:194847.777 server #199 started [trapper #2]
     45982:20240806:194847.782 server #200 started [trapper #3]
     45984:20240806:194847.783 server #201 started [trapper #4]
     45997:20240806:194847.797 server #202 started [trapper #5]
     45998:20240806:194847.807 server #203 started [trapper #6]
     45949:20240806:194847.811 resuming Zabbix agent checks on host "firewall.beckkloeti.local": connection restored
     45909:20240806:194847.816 resuming Zabbix agent checks on host "support.myacdg.ch": connection restored
     45999:20240806:194847.819 server #204 started [trapper #7]
     46005:20240806:194847.823 server #207 started [trapper #10]
     46009:20240806:194847.843 server #210 started [trapper #13]
     46010:20240806:194847.847 server #211 started [trapper #14]
     46008:20240806:194847.847 server #209 started [trapper #12]
     46013:20240806:194847.850 server #214 started [trapper #17]
     46003:20240806:194847.853 server #206 started [trapper #9]
     46012:20240806:194847.857 server #213 started [trapper #16]
     46011:20240806:194847.860 server #212 started [trapper #15]
     46000:20240806:194847.863 server #205 started [trapper #8]
     46007:20240806:194847.864 server #208 started [trapper #11]
     46015:20240806:194847.884 server #215 started [trapper #18]
     46016:20240806:194847.884 server #216 started [trapper #19]
     45907:20240806:194847.887 enabling Zabbix agent checks on host "sym1-2017.oncloud7.ch": interface became available
    46018:20240806:194847.890 server #218 started [icmp pinger #1]
     46019:20240806:194847.895 server #219 started [icmp pinger #2]
     46017:20240806:194847.899 server #217 started [trapper #20]
     46023:20240806:194847.904 server #221 started [icmp pinger #4]
     46024:20240806:194847.904 server #222 started [icmp pinger #5]
     46028:20240806:194847.906 server #225 started [icmp pinger #8]
     46027:20240806:194847.906 server #224 started [icmp pinger #7]
     46029:20240806:194847.907 server #226 started [icmp pinger #9]
     46025:20240806:194847.907 server #223 started [icmp pinger #6]
     46030:20240806:194847.907 server #227 started [icmp pinger #10]
     46022:20240806:194847.908 server #220 started [icmp pinger #3]
     46032:20240806:194847.915 server #229 started [icmp pinger #12]
     46033:20240806:194847.915 server #230 started [icmp pinger #13]
     46031:20240806:194847.915 server #228 started [icmp pinger #11]
     46036:20240806:194847.931 server #232 started [icmp pinger #15]
     46037:20240806:194847.934 server #233 started [icmp pinger #16]
     46041:20240806:194847.934 server #236 started [icmp pinger #19]
     46044:20240806:194847.934 server #238 started [alert syncer #1]
     46040:20240806:194847.934 server #235 started [icmp pinger #18]
     46046:20240806:194847.935 server #239 started [history poller #1]
     46047:20240806:194847.937 server #240 started [history poller #2]
     46039:20240806:194847.938 server #234 started [icmp pinger #17]
     46048:20240806:194847.938 server #241 started [history poller #3]
     46035:20240806:194847.941 server #231 started [icmp pinger #14]
     46050:20240806:194847.941 server #243 started [history poller #5]
     46042:20240806:194847.941 server #237 started [icmp pinger #20]
     46052:20240806:194847.948 server #245 started [trigger housekeeper #1]
     46053:20240806:194847.950 server #246 started [odbc poller #1]
     46049:20240806:194847.952 server #242 started [history poller #4]
     46051:20240806:194847.963 server #244 started [availability manager #1]
     45952:20240806:194852.775 enabling Zabbix agent checks on host "sv18.aarboard.ch": interface became available
     45819:20240806:194917.263 Zabbix agent item "agent.ping" on host "sv87.aarboard.ch" failed: first network error, wait for 15 seconds
     45839:20240806:194917.305 Zabbix agent item "elasix[stat, health, status]" on host "sv89.aarboard.ch" failed: first network error, wait for 15 seconds
     45820:20240806:194917.435 Zabbix agent item "proc.num[smtpd]" on host "mx2.aarboard.ch" failed: first network error, wait for 15 seconds
     45857:20240806:194918.016 Zabbix agent item "proc.num[php-fpm8.2]" on host "sv83.aarboard.ch" failed: first network error, wait for 15 seconds
     45691:20240806:194937.075 cannot connect to availability manager service: Cannot connect to service "availability": [2] No such file or directory.
     45671:20240806:194937.079 One child process died (PID:45691,exitcode/signal:1). Exiting ...
     45671:20240806:194937.079 PROCESS EXIT: 45691
     45689:20240806:194937.080 HA manager has been paused
     45746:20240806:194937.081 cannot read alert manager service request
     45750:20240806:194937.090 cannot read preprocessing service request
    zabbix_server [45671]: Error waiting for process with PID 45691: [10] No child processes
     45689:20240806:194937.162 HA manager has been stopped
     45671:20240806:195147.339 syncing history data...
     45671:20240806:195147.801 item "mx2.aarboard.ch:ssltls.check[{HOST.CONN}:25,smtp,lifetime]" became not supported: Value of type "string" is not suitable for value type "Numeric (unsigned)". Value ""
     45671:20240806:195147.801 item "sv89.aarboard.ch:nginx.get" became not supported: Cannot perform request: Connection timed out after 3001 milliseconds
     45671:20240806:195248.054 cannot connect to service manager service: Cannot connect to service "service": [111] Connection refused.
    The child process crashing (in this log pid 45691) is always the "server #2 started [configuration syncer #1]" process
    I have increased the debuglevel to 4, but there is no more details about the crash of the child process
    Any ideas?
    André
    • 5004
    You have other errors there also
    and after that config syncer exits... Is it always something with availability manager? I think config syncer dying is result not the reason. Maybe you have something about that availability manager in debug log?
    • aschild
      aschild commented
      We don't have the HA mode activated, is it normal that it still logs this "HA manager started in active mode" message?
  • aschild
    • Sep 2014
    • 25
    Yes, seems to be the problem.
    It does not create the zabbix_server_availability.sock file in /tmp for this (or it vanishes almost instantly)
    Unfortunately the log does not show much more
    158801:20240807:191718.142 server #229 started [availability manager #1]
    158801:20240807:191718.142 zbx_setproctitle() title:'availability manager #1 [connecting to the database]'
    158801:20240807:191718.143 In DBconnect() flag:0
    and then
    158541:20240807:191809.026 cannot connect to availability manager service: Cannot connect to service "availability": [2] No such file or directory.
    158511:20240807:191809.035 One child process died (PID:158541,exitcode/signal:1). Exiting ...
    Selinux is not enabled
    • Markku
      • Sep 2018
      • 1788
      What does AppArmor's sudo aa-status say?
      Markku
      • aschild
        • Sep 2014
        • 25
         aa-status
        apparmor module is loaded.
        14 profiles are loaded.
        14 profiles are in enforce mode.
           /usr/bin/man
           /usr/lib/NetworkManager/nm-dhcp-client.action
           /usr/lib/NetworkManager/nm-dhcp-helper
           /usr/lib/connman/scripts/dhclient-script
           /usr/lib/ipsec/charon
           /usr/lib/ipsec/stroke
           /usr/sbin/ntpd
           /{,usr/}sbin/dhclient
           lsb_release
           man_filter
           man_groff
           nvidia_modprobe
           nvidia_modprobe//kmod
           tcpdump
        0 profiles are in complain mode.
        0 profiles are in kill mode.
        0 profiles are in unconfined mode.
        2 processes have profiles defined.
        2 processes are in enforce mode.
           /usr/lib/ipsec/charon (910)
           /usr/sbin/ntpd (788)
        0 processes are in complain mode.
        0 processes are unconfined but have a profile defined.
        0 processes are in mixed mode.
        0 processes are in kill mode.
        • aschild
          • Sep 2014
          • 25
          I have attached the DebugLevel=4 for the dying child process 197452
          197452:20240808:095041.844 server #2 started [configuration syncer #1]
          197452:20240808:095451.581 === memory statistics for configuration cache ===
          197452:20240808:095451.581 free chunks of size 48 bytes: 1
          197452:20240808:095451.581 free chunks of size >= 256 bytes: 9
          197452:20240808:095451.581 min chunk size: 48 bytes
          197452:20240808:095451.581 max chunk size: 2110185912 bytes
          197452:20240808:095451.581 memory of total size 2142360448 bytes fragmented into 320177 chunks
          197452:20240808:095451.581 of those, 2110211256 bytes are in 10 free chunks
          197452:20240808:095451.581 of those, 32149192 bytes are in 320167 used chunks
          197452:20240808:095451.581 of those, 5122816 bytes are used by allocation overhead
          197452:20240808:095451.581 ================================
          197452:20240808:095451.581 End of DCsync_configuration()
          197452:20240808:095451.581 In DCsync_kvs_paths()
          197452:20240808:095451.581 End of DCsync_kvs_paths()
          197452:20240808:095451.581 In DCupdate_interfaces_availability()
          197452:20240808:095451.581 In DCreset_interfaces_availability()
          197452:20240808:095451.581 End of DCreset_interfaces_availability() interfaces:195
          197452:20240808:095451.581 In zbx_ipc_socket_open()
          197452:20240808:095552.091 End of zbx_ipc_socket_open():FAIL
          197452:20240808:095552.091 cannot connect to availability manager service: Cannot connect to service "availability": [2] No such file or directory.
          197446:20240808:095552.098 One child process died (PID:197452,exitcode/signal:1). Exiting ...
          197446:20240808:095552.099 PROCESS EXIT: 197452
          zabbix_server [197446]: Error waiting for process with PID 197452: [10] No child processes
          The corresponding availability nanager is pid 197551 and only logs this and does not create the socket file in /tmp
          197551:20240808:095502.185 server #69 started [availability manager #1]
          197551:20240808:095502.185 zbx_setproctitle() title:'availability manager #1 [connecting to the database]'
          197551:20240808:095502.190 In DBconnect() flag:0
          zz0.zv08c17ta3zz
          • aschild
            • Sep 2014
            • 25
            Ok, got that problem sorted out.
            The cause was, that the MariaDB server was only accessible via ipv4 connections, but not ipv6.
            Aparrently some parts of zabbix do fallback to ipv4 when using dns name for the dbserver, and others not (or take too long to fall back)
            But now it fails very fast in the configuration syncher
            199832:20240808:104553.959 using configuration file: /etc/zabbix/zabbix_server.conf
            199832:20240808:104553.975 current database version (mandatory/optional): 06000000/06000045
            199832:20240808:104553.975 required mandatory version: 06000000
            199832:20240808:104553.977 database could be upgraded to use primary keys in history tables
            199832:20240808:104553.978 database is not upgraded to use double precision values
            199833:20240808:104553.980 starting HA manager
            199833:20240808:104553.988 HA manager started in active mode
            199832:20240808:104553.989 server #0 started [main process]
            199834:20240808:104553.990 server #1 started [service manager #1]
            199835:20240808:104553.991 server #2 started [configuration syncer #1]
            199835:20240808:104554.077 Got signal [signal:11(SIGSEGV),reason:1,refaddr:(nil)]. Crashing ...
            199835:20240808:104554.077 ====== Fatal information: ======
            199835:20240808:104554.077 Program counter: 0x7f6557d4fcb6
            199835:20240808:104554.077 === Registers: ===
            199835:20240808:104554.077 r8      =                0 =                    0 =                    0
            199835:20240808:104554.077 r9      =         7fef4b78 =           2146388856 =           2146388856
            199835:20240808:104554.077 r10     =         7fef4b10 =           2146388752 =           2146388752
            199835:20240808:104554.077 r11     =     7f6557e233c0 =      140073242866624 =      140073242866624
            199835:20240808:104554.077 r12     =     7f6492c45170 =      140069935796592 =      140069935796592
            199835:20240808:104554.077 r13     =     7f6492cd1990 =      140069936372112 =      140069936372112
            199835:20240808:104554.077 r14     =     7f6492d50488 =      140069936891016 =      140069936891016
            199835:20240808:104554.077 r15     =                1 =                    1 =                    1
            199835:20240808:104554.077 rdi     =                0 =                    0 =                    0
            199835:20240808:104554.077 rsi     =     7f6492d504b0 =      140069936891056 =      140069936891056
            199835:20240808:104554.077 rbp     =     7f6492d504b0 =      140069936891056 =      140069936891056
            199835:20240808:104554.077 rbx     =                0 =                    0 =                    0
            199835:20240808:104554.077 rdx     =                0 =                    0 =                    0
            199835:20240808:104554.077 rax     =                0 =                    0 =                    0
            199835:20240808:104554.077 rcx     =                0 =                    0 =                    0
            199835:20240808:104554.077 rsp     =     7ffcacb04948 =      140723205720392 =      140723205720392
            199835:20240808:104554.077 rip     =     7f6557d4fcb6 =      140073242000566 =      140073242000566
            199835:20240808:104554.077 efl     =            10293 =                66195 =                66195
            199835:20240808:104554.077 csgsfs  =   2b000000000033 =    12103423998558259 =    12103423998558259
            199835:20240808:104554.077 err     =                4 =                    4 =                    4
            199835:20240808:104554.077 trapno  =                e =                   14 =                   14
            199835:20240808:104554.078 oldmask =                0 =                    0 =                    0
            199835:20240808:104554.078 cr2     =                0 =                    0 =                    0
            199835:20240808:104554.078 === Backtrace: ===
            199835:20240808:104554.079 15: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_backtrace+0x3c) [0x556d3bf1b37c]
            199835:20240808:104554.079 14: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_log_fatal_info+0x28d) [0x556d3bf1b70d]
            199835:20240808:104554.079 13: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1ead36) [0x556d3bf1bd36]
            199835:20240808:104554.079 12: /lib/x86_64-linux-gnu/libc.so.6(+0x3c050) [0x7f6557ce2050]
            199835:20240808:104554.079 11: /lib/x86_64-linux-gnu/libc.so.6(+0xa9cb6) [0x7f6557d4fcb6]
            199835:20240808:104554.079 10: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCstrpool_replace+0x3d) [0x556d3bebb9dd]
            199835:20240808:104554.079 9: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x192690) [0x556d3bec3690]
            199835:20240808:104554.079 8: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCsync_configuration+0x2f69) [0x556d3bec7039]
            199835:20240808:104554.079 7: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](dbconfig_thread+0xe3) [0x556d3bdb5873]
            199835:20240808:104554.079 6: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_thread_start+0x20) [0x556d3bf1d800]
            199835:20240808:104554.079 5: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x768fb) [0x556d3bda78fb]
            199835:20240808:104554.079 4: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](MAIN_ZABBIX_ENTRY+0xaaf) [0x556d3bda8aef]
            199835:20240808:104554.079 3: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](main+0x527) [0x556d3bd9f917]
            199835:20240808:104554.079 2: /lib/x86_64-linux-gnu/libc.so.6(+0x2724a) [0x7f6557ccd24a]
            199835:20240808:104554.079 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7f6557ccd305]
            199835:20240808:104554.079 0: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](_start+0x21) [0x556d3bda6bc1]
            199835:20240808:104554.079 === Memory map: ===
            199835:20240808:104554.079 556d3bd31000-556d3bd98000 r--p 00000000 fe:01 148488                     /usr/sbin/zabbix_server
            199835:20240808:104554.079 556d3bd98000-556d3bff6000 r-xp 00067000 fe:01 148488                     /usr/sbin/zabbix_server
            199835:20240808:104554.079 556d3bff6000-556d3c0cd000 r--p 002c5000 fe:01 148488                     /usr/sbin/zabbix_server
            199835:20240808:104554.079 556d3c0cd000-556d3c0d1000 r--p 0039b000 fe:01 148488                     /usr/sbin/zabbix_server
            199835:20240808:104554.079 556d3c0d1000-556d3c1a6000 rw-p 0039f000 fe:01 148488                     /usr/sbin/zabbix_server
            199835:20240808:104554.079 556d3c1a6000-556d3c1b6000 rw-p 00000000 00:00 0
            199835:20240808:104554.079 556d3dbf5000-556d3dc37000 rw-p 00000000 00:00 0                          [heap]
            199835:20240808:104554.079 556d3dc37000-556d3dc58000 rw-p 00000000 00:00 0                          [heap]
            199835:20240808:104554.079 556d3dc58000-556d3e409000 rw-p 00000000 00:00 0                          [heap]
            199835:20240808:104554.079 7f6471adb000-7f6472845000 rw-p 00000000 00:00 0
            199835:20240808:104554.079 7f6472845000-7f6472c45000 rw-s 00000000 00:01 1212449                    /SYSV00000000 (deleted)
            199835:20240808:104554.079 7f6472c45000-7f6492c45000 rw-s 00000000 00:01 1212448                    /SYSV00000000 (deleted)
            199835:20240808:104554.080 7f6492c45000-7f6512c45000 rw-s 00000000 00:01 1212446                    /SYSV00000000 (deleted)
            • aschild
              • Sep 2014
              • 25
              200296:20240808:105530.003 query [txnlev:0] [select t.timeperiodid,t.timeperiod_type,t.every,t.month,t .dayofweek,t.day,t.start_time,t.period,t.start_dat e,m.maintenanceid from maintenances_windows m,timeperiods t where t.timeperiodid=m.timeperiodid]
              200296:20240808:105530.003 query [txnlev:0] [select maintenanceid,groupid from maintenances_groups order by maintenanceid]
              200296:20240808:105530.004 query [txnlev:0] [select maintenanceid,hostid from maintenances_hosts order by maintenanceid]
              200296:20240808:105530.004 In DCsync_hosts()
              200296:20240808:105530.005 End of DCsync_hosts()
              200296:20240808:105530.005 In DCsync_host_inventory()
              200296:20240808:105530.006 End of DCsync_host_inventory()
              200296:20240808:105530.006 In DCsync_hostgroups()
              200296:20240808:105530.006 End of DCsync_hostgroups()
              200296:20240808:105530.006 In DCsync_hostgroup_hosts()
              200296:20240808:105530.006 End of DCsync_hostgroup_hosts()
              200296:20240808:105530.006 In DCsync_maintenances()
              200296:20240808:105530.006 End of DCsync_maintenances()
              200296:20240808:105530.006 In DCsync_maintenance_tags()
              200296:20240808:105530.006 End of DCsync_maintenance_tags()
              200296:20240808:105530.006 In DCsync_maintenance_groups()
              200296:20240808:105530.006 End of DCsync_maintenance_groups()
              200296:20240808:105530.006 In DCsync_maintenance_hosts()
              200296:20240808:105530.006 End of DCsync_maintenance_hosts()
              200296:20240808:105530.006 In DCsync_maintenance_periods()
              200296:20240808:105530.006 End of DCsync_maintenance_periods()
              200296:20240808:105530.006 query [txnlev:0] [select i.interfaceid,i.hostid,i.type,i.main,i.useip,i.ip, i.dns,i.port,i.available,i.disable_until,i.error,i .errors_from,s.version,s.bulk,s.community,s.securi tyname,s.securitylevel,s.authpassphrase,s.privpass phrase,s.authprotocol,s.privprotocol,s.contextname from interface
              200296:20240808:105530.007 query [txnlev:0] [select i.itemid,i.hostid,i.status,i.type,i.value_type,i.k ey_,i.snmp_oid,i.ipmi_sensor,i.delay,i.trapper_hos ts,i.logtimefmt,i.params,ir.state,i.authtype,i.use rname,i.password,i.publickey,i.privatekey,i.flags, i.interfaceid,ir.lastlogsize,ir.mtime,i.history,i. trends,i.invent
              200296:20240808:105530.050 query [txnlev:0] [select i.itemid,i.hostid,i.templateid from items i inner join hosts h on i.hostid=h.hostid where h.status=3]
              200296:20240808:105530.051 query [txnlev:0] [select i.itemid,i.hostid,i.templateid from items i where i.flags=2]
              200296:20240808:105530.053 query [txnlev:0] [select itemid,parent_itemid from item_discovery]
              200296:20240808:105530.057 query [txnlev:0] [select pp.item_preprocid,pp.itemid,pp.type,pp.params,pp.s tep,h.hostid,pp.error_handler,pp.error_handler_par ams from item_preproc pp,items i,hosts h where pp.itemid=i.itemid and i.hostid=h.hostid and (h.proxy_hostid is null or i.type in (5,15,18)) and h.status in (0,1) and
              200296:20240808:105530.059 query [txnlev:0] [select p.item_parameterid,p.itemid,p.name,p.value,i.hosti d from item_parameter p,items i,hosts h where p.itemid=i.itemid and i.hostid=h.hostid and h.status in (0,1) and i.flags<>2 order by p.itemid]
              200296:20240808:105530.060 In DCsync_interfaces()
              200296:20240808:105530.061 Got signal [signal:11(SIGSEGV),reason:1,refaddrnil)]. Crashing ...
              200296:20240808:105530.061 ====== Fatal information: ======
              200296:20240808:105530.061 Program counter: 0x7ff93673acb6
              200296:20240808:105530.061 === Registers: ===
              200296:20240808:105530.061 r8 = 0 = 0 = 0
              200296:20240808:105530.061 r9 = 7fef4b78 = 2146388856 = 2146388856
              200296:20240808:105530.061 r10 = 7fef4b10 = 2146388752 = 2146388752
              200296:20240808:105530.061 r11 = 7ff93680e3c0 = 140708338000832 = 140708338000832
              200296:20240808:105530.061 r12 = 7ff871632170 = 140705030938992 = 140705030938992
              200296:20240808:105530.061 r13 = 7ff8716be990 = 140705031514512 = 140705031514512
              200296:20240808:105530.061 r14 = 7ff87173d488 = 140705032033416 = 140705032033416
              200296:20240808:105530.061 r15 = 1 = 1 = 1
              200296:20240808:105530.061 rdi = 0 = 0 = 0
              200296:20240808:105530.061 rsi = 7ff87173d4b0 = 140705032033456 = 140705032033456
              200296:20240808:105530.061 rbp = 7ff87173d4b0 = 140705032033456 = 140705032033456
              200296:20240808:105530.061 rbx = 0 = 0 = 0
              200296:20240808:105530.061 rdx = 0 = 0 = 0
              200296:20240808:105530.061 rax = 0 = 0 = 0
              200296:20240808:105530.061 rcx = 0 = 0 = 0
              200296:20240808:105530.061 rsp = 7fffbe2df838 = 140736384071736 = 140736384071736
              200296:20240808:105530.061 rip = 7ff93673acb6 = 140708337134774 = 140708337134774
              200296:20240808:105530.061 efl = 10293 = 66195 = 66195
              200296:20240808:105530.061 csgsfs = 2b000000000033 = 12103423998558259 = 12103423998558259
              200296:20240808:105530.061 err = 4 = 4 = 4
              200296:20240808:105530.061 trapno = e = 14 = 14
              200296:20240808:105530.061 oldmask = 0 = 0 = 0
              200296:20240808:105530.061 cr2 = 0 = 0 = 0
              200296:20240808:105530.062 === Backtrace: ===
              200296:20240808:105530.063 15: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_backtrace+0x3c) [0x557c9bc3e37c]
              200296:20240808:105530.063 14: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_log_fatal_info+0x28d) [0x557c9bc3e70d]
              200296:20240808:105530.063 13: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1ead36) [0x557c9bc3ed36]
              200296:20240808:105530.063 12: /lib/x86_64-linux-gnu/libc.so.6(+0x3c050) [0x7ff9366cd050]
              200296:20240808:105530.063 11: /lib/x86_64-linux-gnu/libc.so.6(+0xa9cb6) [0x7ff93673acb6]
              • aschild
                • Sep 2014
                • 25
                I just did a upgrade to 6.4.17 and the same crash happens there
                215524:20240808:162341.552 Got signal [signal:11(SIGSEGV),reason:1,refaddrnil)]. Crashing ...
                215524:20240808:162341.552 ====== Fatal information: ======
                215524:20240808:162341.552 Program counter: 0x7f2309e8eea6
                215524:20240808:162341.552 === Registers: ===
                215524:20240808:162341.552 r8 = 7f2244e5c634 = 139785161524788 = 139785161524788
                215524:20240808:162341.552 r9 = 0 = 0 = 0
                215524:20240808:162341.552 r10 = 7f2309e8f380 = 139788466844544 = 139788466844544
                215524:20240808:162341.552 r11 = 7f2309f643c0 = 139788467717056 = 139788467717056
                215524:20240808:162341.553 r12 = 7f2244e5c634 = 139785161524788 = 139785161524788
                215524:20240808:162341.553 r13 = 7f2244e5c638 = 139785161524792 = 139785161524792
                215524:20240808:162341.553 r14 = 7f2244e5c628 = 139785161524776 = 139785161524776
                215524:20240808:162341.553 r15 = 55db1aa5cb60 = 94399533271904 = 94399533271904
                215524:20240808:162341.553 rdi = 0 = 0 = 0
                215524:20240808:162341.553 rsi = 55db1aa5cb60 = 94399533271904 = 94399533271904
                215524:20240808:162341.553 rbp = 55db1aa72eb8 = 94399533362872 = 94399533362872
                215524:20240808:162341.553 rbx = 3 = 3 = 3
                215524:20240808:162341.553 rdx = 7f2244e5c628 = 139785161524776 = 139785161524776
                215524:20240808:162341.553 rax = 0 = 0 = 0
                215524:20240808:162341.553 rcx = 20 = 32 = 32
                215524:20240808:162341.553 rsp = 7ffd59196f58 = 140726098292568 = 140726098292568
                215524:20240808:162341.553 rip = 7f2309e8eea6 = 139788466843302 = 139788466843302
                215524:20240808:162341.553 efl = 10283 = 66179 = 66179
                215524:20240808:162341.553 csgsfs = 2b000000000033 = 12103423998558259 = 12103423998558259
                215524:20240808:162341.553 err = 4 = 4 = 4
                215524:20240808:162341.553 trapno = e = 14 = 14
                215524:20240808:162341.553 oldmask = 0 = 0 = 0
                215524:20240808:162341.553 cr2 = 0 = 0 = 0
                215524:20240808:162341.553 === Backtrace: ===
                215524:20240808:162341.554 17: /usr/sbin/zabbix_server: trapper #1 [processing data](zbx_backtrace+0x46) [0x55db1996ac26]
                215524:20240808:162341.554 16: /usr/sbin/zabbix_server: trapper #1 [processing data](zbx_log_fatal_info+0x295) [0x55db1996afa5]
                215524:20240808:162341.554 15: /usr/sbin/zabbix_server: trapper #1 [processing data](+0x2f8556) [0x55db1996b556]
                215524:20240808:162341.554 14: /lib/x86_64-linux-gnu/libc.so.6(+0x3c050) [0x7f2309e23050]
                215524:20240808:162341.554 13: /lib/x86_64-linux-gnu/libc.so.6(+0xa7ea6) [0x7f2309e8eea6]
                215524:20240808:162341.554 12: /usr/sbin/zabbix_server: trapper #1 [processing data](+0x1bbba3) [0x55db1982eba3]
                215524:20240808:162341.554 11: /usr/sbin/zabbix_server: trapper #1 [processing data](DCset_interfaces_availability+0x61) [0x55db19836151]
                215524:20240808:162341.555 10: /usr/sbin/zabbix_server: trapper #1 [processing data](zbx_process_proxy_data+0x2194) [0x55db19934984]
                215524:20240808:162341.555 9: /usr/sbin/zabbix_server: trapper #1 [processing data](zbx_recv_proxy_data+0x38b) [0x55db1973addb]
                215524:20240808:162341.555 8: /usr/sbin/zabbix_server: trapper #1 [processing data](+0xc2d64) [0x55db19735d64]
                215524:20240808:162341.555 7: /usr/sbin/zabbix_server: trapper #1 [processing data](trapper_thread+0x320) [0x55db197374e0]
                215524:20240808:162341.555 6: /usr/sbin/zabbix_server: trapper #1 [processing data](zbx_thread_start+0x20) [0x55db198b70b0]
                215524:20240808:162341.555 5: /usr/sbin/zabbix_server: trapper #1 [processing data](+0x8e862) [0x55db19701862]
                215524:20240808:162341.555 4: /usr/sbin/zabbix_server: trapper #1 [processing data](MAIN_ZABBIX_ENTRY+0xe61) [0x55db19702a91]
                215524:20240808:162341.555 3: /usr/sbin/zabbix_server: trapper #1 [processing data](main+0x242) [0x55db196f77a2]
                215524:20240808:162341.555 2: /lib/x86_64-linux-gnu/libc.so.6(+0x2724a) [0x7f2309e0e24a]
                215524:20240808:162341.555 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7f2309e0e305]
                215524:20240808:162341.555 0: /usr/sbin/zabbix_server: trapper #1 [processing data](_start+0x21) [0x55db196fe771]
                215524:20240808:162341.555 === Memory map: ===
                215524:20240808:162341.555 55db19673000-55db196f0000 r--p 00000000 fe:01 135664 /usr/sbin/zabbix_server
                215524:20240808:162341.555 55db196f0000-55db1999a000 r-xp 0007d000 fe:01 135664 /usr/sbin/zabbix_server
                215524:20240808:162341.555 55db1999a000-55db19a90000 r--p 00327000 fe:01 135664 /usr/sbin/zabbix_server
                215524:20240808:162341.555 55db19a90000-55db19a94000 r--p 0041c000 fe:01 135664 /usr/sbin/zabbix_server
                215524:20240808:162341.555 55db19a94000-55db19b63000 rw-p 00420000 fe:01 135664 /usr/sbin/zabbix_server
                215524:20240808:162341.555 55db19b63000-55db19b74000 rw-p 00000000 00:00 0
                215524:20240808:162341.555 55db1a9c0000-55db1aa02000 rw-p 00000000 00:00 0 [heap]
                215524:20240808:162341.555 55db1aa02000-55db1aa24000 rw-p 00000000 00:00 0 [heap]
                215524:20240808:162341.555 55db1aa24000-55db1b0a4000 rw-p 00000000 00:00 0 [heap]
                215524:20240808:162341.555 7f2224938000-7f2224d38000 rw-s 00000000 00:01 6783015 /SYSV00000000 (deleted)
                215524:20240808:162341.555 7f2224d38000-7f2244d38000 rw-s 00000000 00:01 6783014 /SYSV00000000 (deleted)
                215524:20240808:162341.555 7f2244d38000-7f2244d4a000 rw-s 00000000 00:01 6783013 /SYSV00000000 (deleted)
                215524:20240808:162341.555 7f2244d4a000-7f22c4d4a000 rw-s 00000000 00:01 6783012 /SYSV00000000 (deleted)
                215524:20240808:162341.555 7f22c4d4a000-7f22c514a000 rw-s 00000000 00:01 6783009 /SYSV00000000 (deleted)
                215524:20240808:162341.555 7f22c514a000-7f22c714a000 rw-s 00000000 00:01 6783008 /SYSV00000000 (deleted)
                215524:20240808:162341.555 7f22c714a000-7f230714a000 rw-s 00000000 00:01 6783007 /SYSV00000000 (deleted)
                215524:20240808:162341.555 7f230714a000-7f230714d000 r--p 00000000 fe:01 156713 /usr/lib/x86_64-linux-gnu/libcap.so.2.66
                215524:20240808:162341.555 7f230714d000-7f2307152000 r-xp 00003000 fe:01 156713 /usr/lib/x86_64-linux-gnu/libcap.so.2.66
                215524:20240808:162341.555 7f2307152000-7f2307154000 r--p 00008000 fe:01 156713 /usr/lib/x86_64-linux-gnu/libcap.so.2.66
                215524:20240808:162341.555 7f2307154000-7f2307155000 r--p 0000a000 fe:01 156713 /usr/lib/x86_64-linux-gnu/libcap.so.2.66
                215524:20240808:162341.555 7f2307155000-7f2307156000 rw-p 0000b000 fe:01 156713 /usr/lib/x86_64-linux-gnu/libcap.so.2.66
                • Tester001
                  • Feb 2023
                  • 10
                  aschild, have you found a solution? I seem to be having a similar issue
                  • aschild
                    • Sep 2014
                    • 25
                    Nope.
                    I did invest a lot of time which db schema comparision, updates/data migrations.
                    But in the end I did not get a stable environment.
                    Each time a specific proxy and/or host did delivery data to the server, the server crashed.
                    So we we are currently setting up a second, completely separated, zabbix server and the servers is running stable. (This one running with Postgres and not MarriaDB/MySQL anymore)
                    We let the old zabbix running with disabled proxy+host for the ones we know trigger the crashing and are slowly moviing over config/templates to the new server.
                    Not ideal, but since our system was started with Zabbix 2.x and then done most of the upgrades, I think there is just too much incorrect/inconsistend data in the DB.
                    • Tester001
                      • Feb 2023
                      • 10
                      Thank you for responding, @aschild.
                      I didn't collect enough evidence to submit a bug, but have found the error be caused by a combination of my dataset in DB + int lld_update_items() function.
                      3135850:20241029:142331.036 15: /usr/sbin/zabbix_server: lld worker #2 [processed 1 LLD rules, idle 47.484055 sec during 47.490763 sec](zbx_backtrace+0x46) [0x565358b2ac76]
                      3135850:20241029:142331.036 14: /usr/sbin/zabbix_server: lld worker #2 [processed 1 LLD rules, idle 47.484055 sec during 47.490763 sec](zbx_log_fatal_info+0x285) [0x565358b2afe5]
                      3135850:20241029:142331.036 13: /usr/sbin/zabbix_server: lld worker #2 [processed 1 LLD rules, idle 47.484055 sec during 47.490763 sec](+0x2fd5c6) [0x565358b2b5c6]
                      3135850:20241029:142331.036 12: /lib/x86_64-linux-gnu/libpthread.so.0(+0x13140) [0x7f3db91bd140]
                      3135850:20241029:142331.036 11: /lib/x86_64-linux-gnu/libc.so.6(+0x171b58) [0x7f3db8a5fb58]
                      3135850:20241029:142331.036 10: /lib/x86_64-linux-gnu/libc.so.6(__strdup+0xf) [0x7f3db8977c1f]
                      3135850:20241029:142331.036 9: /usr/sbin/zabbix_server: lld worker #2 [processed 1 LLD rules, idle 47.484055 sec during 47.490763 sec](zbx_strdup2+0x33) [0x565358b511f3]
                      3135850:20241029:142331.036 8: /usr/sbin/zabbix_server: lld worker #2 [processed 1 LLD rules, idle 47.484055 sec during 47.490763 sec](lld_update_items+0xe4) [0x5653589a8f74]
                      3135850:20241029:142331.036 7: /usr/sbin/zabbix_server: lld worker #2 [processed 1 LLD rules, idle 47.484055 sec during 47.490763 sec](lld_process_discovery_rule+0xe4c)
                      I knew which LLD was running at the time so disabling/deleting it has stopped the crashes. Luckily I was able to isolate the crash to this particular function!
