Unable to Connect Zabbix to Secure MySql over TLS
  • Eslam.Basyouni
    • Aug 2024
    Hello All,
    This My first post in Zabbix, where i have an issue and also comment that maybe consider as a bug:
    ==== My Issue ====
    I have Mysql Server which use TLS , where i created server-key.pem and CSR then send this CSR to My MS Root CA in Windows 2019 to get at the end server-cert.pem as a MySql Certificate and download my Root-CA.cer its the MS Root CA Certificate then i configured Mysql /etc/my.cnf
    require_secure_transport=ON
    tls-version=TLSv1.3
    ssl-ca=/etc/mysql-ssl/Root-CA.cer
    ssl-cert=/etc/mysql-ssl/server-cert.pem
    ssl-key=/etc/mysql-ssl/server-key.pem
    I add this info Also in Zabbix Manager :
    DBTLSConnect=verify_full
    DBTLSCAFile=/etc/mysql-ssl/Root-CA.cer
    DBTLSCertFile=/etc/mysql-ssl/server-cert.pem
    DBTLSKeyFile=/etc/mysql-ssl/server-key.pem
    But i got error : [Z3001] connection to database 'zabbix' failed: [2013] Lost connection to MySQL server at 'reading authorization packet', system error: 0
    and the same in Zabbix Frontend
    ====== My comment That maybe consider as a bug =======
    DBTLSConnect=verify_ca is not work and i gor error that its not configure in zabbix and it's missing some libarary
    but after some test i discoverd that i can use it or use verify_full without adding :
    Also FYI I test with Self Signed and its working , but i need to use My MS Root CA , i used it before in Zabbix Front url to be https and its working good.
    Can anyone help or tell me what i missing ​
  • Markku
    • Sep 2018
    • 1784
    In the Zabbix config above you are using the database server certificate and key, I don't think that's the correct way. https://www.zabbix.com/documentation...#dbtlscertfile specifically says about DBTLSCertFile: "The full pathname of a file containing the Zabbix server certificate for authenticating to database.".
    Markku
