No Error but Upgrade from 6.2 to 7 does not happen..
  • tryllz
    • Jun 2021
    • 29
    I'm trying to upgrade zabbix server from 6.2 to 7 but nothing happens after going through all the steps.
    I upgrade PHP to 8.3, then go ahead with the rest of the upgrade, no errors but nothing happens either, after all the steps its still 6.2.
    I have gone through the requirements, and even upgraded Ubuntu from 20.04 to 22.04. As per Zabbix I ran tail on zabbix_server.log but there is nothing getting logged in it during the upgrade..
    Below is all thay I get when upgrading zabbix server
    HTML Code:
    rw-r--r-- 1 root root 8288 Jul 4 11:55 zabbix-release_latest+ubuntu20.04_all.deb
    root@zabbix:~# dpkg -i zabbix-release_latest+ubuntu20.04_all.deb
    (Reading database ... 83604 files and directories currently installed.)
    Preparing to unpack zabbix-release_latest+ubuntu20.04_all.deb ...
    Unpacking zabbix-release (1:7.0-2+ubuntu20.04) over (1:7.0-2+ubuntu20.04) ...
    Setting up zabbix-release (1:7.0-2+ubuntu20.04)
    root@zabbix:~#
  • tryllz
    • Jun 2021
    • 29
    I'm following this for the upgrade..
      • 5004
      Your log snippet shows updating of repos... and nothing more... If you follow upgrade docs, you should continue with upgrading components etc... section 5 on that page...
      • tryllz
        • Jun 2021
        • 29
        Thanks, all of it was tried end to end with no success, had to deplay a new Zabbix 7 VM..
