problem migrating from 5 to 7
  • AlfredIT
    • Jan 2011
    hi,
    I am trying to upgrade from Zabbix 5.4.12 to latest.
    What i did :
    * My ubuntu 18.04 is old now so i backed up the MySQL,
    * Installed a new 24.04 server with latest zabbix/Mysql version,
    * Followed the install process, restored my mysql dump (15GB).
    * I've completed the /etc/zabbix/zabbix-server.conf with my mysql config user, password and database.
    * I have seen the upgrade process doing fine in the /val/log/zabbix/zabbix-server.log, i see only active check error ono 127.0.0.1
    The problem i have is that the setup.php il displayed when i go to http://server_ip/zabbix.
    If i try to go through it, after the database password the page does not respond (nothing seen in /val/log/apache2/error.log)
    Questions :
    1. is this the good way to upgrade? Can i do it simpler ?
    2. how to bypass the setup.php page, since everything is running
    Thanks a lot,
    Edgar
    • 4996
    1. Yes. No
    2. By adding all required credentials to config file (conf/zabbix.conf.php)
    • AlfredIT
      • Jan 2011
      It's working, thanks a lot ! Took my old
      "/usr/share/zabbix/conf/zabbix.conf.php"
      and restored it on the new server and it works (minus a thing...)
      I have these pages that cannot load. I see nothing in /var/log/apache2/error.log or zabbix_server.log. The page times out.
      * zabbix.php?action=userprofile.edit
      * gui.edit
      * user.edit
      Is there a log for the frontend ? What can i do ?
      • tim.mooney
        • Dec 2012
        • 1436
        * gui.edit
        * user.edit
        Enable logging for either the PHP-FPM worker pool you're using (assuming you are using PHP-FPM, which is the default for modern installs) or enable it system-wide in you /etc/php.ini or /etc/php.d/90-local.ini file. Once logging is enabled, restart your php-fpm worker pool and visit the problematic pages and then check the php or php-fpm logs.
        You may also want to look at the documentation for the web interface ("Frontend") requirements. Make sure you're not missing any PHP extensions that are required.
