Appliance 7.0.2 not initializing
  • hummel124
    • Aug 2024
    I am new to zabbix and want to deploy an appliance 7.0.2 for evaluation purposes.
    The setup is made on a KVM-based Virtual Machine Manager on a Synology NAS (latest DSM 7.2.1-69057 U5).
    I tried importing a qcow2 image and installation from iso in a new VM, both have the same outcome.
    The logs here are from the last try of the ISO setup.
    After deploying the image it took one hour during which the used disk space increased to 5.1GB (of 32GB I assigned because why not).
    Then the guest iniated a power off of the virtual machine.
    After rebooting the web interface just shows "Database Error - No such file or directory"
    I could connect via SSH and get some log files.
    mysqld.log
    2024-08-16T14:03:49.589383Z 0 [Warning] [MY-011070] [Server] 'binlog_format' is deprecated and will be removed in a future release.
    2024-08-16T14:03:49.713976Z 0 [Warning] [MY-010918] [Server] 'default_authentication_plugin' is deprecated and will be removed in a future release. Please use authentication_policy instead.
    2024-08-16T14:03:49.714962Z 0 [System] [MY-013169] [Server] /usr/libexec/mysqld (mysqld 8.0.36) initializing of server in progress as process 1017
    2024-08-16T14:03:53.128629Z 0 [Warning] [MY-013907] [InnoDB] Deprecated configuration parameters innodb_log_file_size and/or innodb_log_files_in_group have been used to compute innodb_redo_log_capacity=536870912. Please use innodb_redo_log_capacity instead.
    2024-08-16T14:03:53.506628Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
    2024-08-16T14:06:49.149258Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
    2024-08-16T14:13:43.030552Z 0 [Warning] [MY-011070] [Server] 'binlog_format' is deprecated and will be removed in a future release.
    2024-08-16T14:13:43.035886Z 0 [Warning] [MY-010918] [Server] 'default_authentication_plugin' is deprecated and will be removed in a future release. Please use authentication_policy instead.
    2024-08-16T14:13:43.036017Z 0 [System] [MY-010116] [Server] /usr/libexec/mysqld (mysqld 8.0.36) starting as process 1164
    2024-08-16T14:13:43.308056Z 0 [Warning] [MY-013907] [InnoDB] Deprecated configuration parameters innodb_log_file_size and/or innodb_log_files_in_group have been used to compute innodb_redo_log_capacity=536870912. Please use innodb_redo_log_capacity instead.
    2024-08-16T14:13:43.313347Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
    2024-08-16T14:13:43.868390Z 1 [ERROR] [MY-012960] [InnoDB] Cannot create redo log files because data files are corrupt or the database was not shut down cleanly after creating the data files.
    2024-08-16T14:13:43.868506Z 1 [ERROR] [MY-012930] [InnoDB] Plugin initialization aborted with error Generic error.
    2024-08-16T14:13:44.167873Z 1 [ERROR] [MY-010334] [Server] Failed to initialize DD Storage Engine
    2024-08-16T14:13:44.168215Z 0 [ERROR] [MY-010020] [Server] Data Dictionary initialization failed.
    2024-08-16T14:13:44.168268Z 0 [ERROR] [MY-010119] [Server] Aborting
    2024-08-16T14:13:44.169351Z 0 [System] [MY-010910] [Server] /usr/libexec/mysqld: Shutdown complete (mysqld 8.0.36) Source distribution.
    2024-08-16T14:13:45.181209Z 0 [Warning] [MY-011070] [Server] 'binlog_format' is deprecated and will be removed in a future release.
    2024-08-16T14:13:45.186313Z 0 [Warning] [MY-010918] [Server] 'default_authentication_plugin' is deprecated and will be removed in a future release. Please use authentication_policy instead.
    2024-08-16T14:13:45.186376Z 0 [System] [MY-010116] [Server] /usr/libexec/mysqld (mysqld 8.0.36) starting as process 1269
    2024-08-16T14:13:45.730029Z 0 [Warning] [MY-013907] [InnoDB] Deprecated configuration parameters innodb_log_file_size and/or innodb_log_files_in_group have been used to compute innodb_redo_log_capacity=536870912. Please use innodb_redo_log_capacity instead.
    2024-08-16T14:13:45.736446Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
    2024-08-16T14:13:46.064107Z 1 [ERROR] [MY-012960] [InnoDB] Cannot create redo log files because data files are corrupt or the database was not shut down cleanly after creating the data files.
    2024-08-16T14:13:46.064238Z 1 [ERROR] [MY-012930] [InnoDB] Plugin initialization aborted with error Generic error.
    2024-08-16T14:13:46.454209Z 1 [ERROR] [MY-010334] [Server] Failed to initialize DD Storage Engine
    2024-08-16T14:13:46.454692Z 0 [ERROR] [MY-010020] [Server] Data Dictionary initialization failed.
    2024-08-16T14:13:46.454774Z 0 [ERROR] [MY-010119] [Server] Aborting
    2024-08-16T14:13:46.455744Z 0 [System] [MY-010910] [Server] /usr/libexec/mysqld: Shutdown complete (mysqld 8.0.36) Source distribution.
    I could not find any related posts so I created this one
    Thanks for your advice
    Chris
  • hummel124
    • Aug 2024
    In the meanwhile I could reproduce the issue using different VM hardware (SATA + E1000 instead of VirtIO).
    Did anyone deploy the appliance successfully to a VM and give some hints?
    • hummel124
      • Aug 2024
      As I could not solve the issue I went for a manual setup on ubuntu.
