Getting error "Deadlock found when trying to get lock" while inserting trigger
  • kanchan
    • Dec 2013
    • 23
    Dear All,
    I am using Zabbix 2.0.9 with Mysql DB (Version - 5.6.19).
    I am trying to add new triggers in existing linux template which has too many hosts tagged and getting below error :
    Error in query [INSERT INTO functions (itemid,triggerid,function,parameter,functionid) VALUES ('200200000743538','200200008794039','avg','120',' 200200009111515')] [Deadlock found when trying to get lock; try restarting transaction]
    Cannot implode expression "{<HOSTNAME>:vfs.dev.read[,ops].avg(120)}>3000". SQL statement execution has failed "INSERT INTO functions (itemid,triggerid,function,parameter,functionid) VALUES ('200200000743538','200200008794039','avg','120',' 200200009111515')".
    Now days we are facing this problem frequently. In past when we used to try to insert this task couple of time then it was able to execute query but now it is continuously throwing deadlock error. Please suggest how to fix this issue as it will be very difficult for us to manage if it wont work.
  • batchenr
    • Sep 2016
    • 440
    Originally posted by kanchan
    Dear All,
    please post my.cnf + new trigger configuration
    • kanchan
      • Dec 2013
      • 23
      Thanks for your reply.
      Please find my mysql configuration.
      [root@zabbix ~]# cat /etc/my.cnf
      [mysqld]
      datadir=/var/lib/mysql
      socket=/var/lib/mysql/mysql.sock
      max_connections=600
      skip-name-resolve
      read_buffer_size=1M
      max_allowed_packet=32M
      join_buffer_size=1M
      myisam_sort_buffer_size=64M
      tmp_table_size=16M
      read_rnd_buffer_size=1M
      local-infile=0
      symbolic-links=0
      innodb_checksum_algorithm=INNODB
      binlog_checksum=NONE
      skip_secure_auth
      table_open_cache=6000
      innodb_open_files=1500
      table_definition_cache=6000
      slow_query_log=0
      slow_query_log_file=/var/log/mysqld.slow.log
      long_query_time=1
      #For open db and slow query
      general_log=0
      log_output=TABLE
      #### To disable the replication of mysql.general log from master #############
      replicate-ignore-table=mysql.general_log
      replicate-wild-ignore-table=mysql.log%
      #### To disable the replication of slow log from master #############
      replicate-ignore-table=mysql.slow_log
      slave-compressed-protocol=1
      # To resolve inderterministic behavior of sysdate() (makes it binlog safe)
      sysdate-is-now
      # ## # To suppress the mysql error log from warnings
      log-warnings=0
      tmpdir=/var/lib/mysql
      innodb_buffer_pool_size=72G
      innodb_buffer_pool_instances=8
      innodb_log_file_size=512M
      innodb_log_buffer_size=16M
      thread_cache=64
      innodb_file_per_table
      log_bin_trust_function_creators = 1
      performance_schema=OFF
      innodb_purge_threads=1
      innodb_thread_concurrency=64
      core-file
      # Mysql suggested Parameter On 10-Mar-10
      innodb_stats_on_metadata=0
      # The default storage engine to be used when new tables are created
      default_storage_engine=InnoDB
      server-id = 53
      # changes made to make this master
      log-bin=/usr/binlogs/mysql-bin
      binlog-format=statement
      #changes according to Mysql Support suggested
      max_heap_table_size=32M
      sort_buffer_size=1M
      key_buffer=64M
      query_cache_size=48M
      query_cache_type=1
      innodb_flush_log_at_trx_commit=2
      group_concat_max_len = 16000
      [mysql.server]
      user=mysql
      [mysql_safe]
      log-error=/var/log/mysqld.log
      pid-file=/var/lib/mysql/mysqld.pid
      Please find trigger expression which need to be added :
      {Template_Linux:vfs.dev.read[,ops].avg(120)}>3000
      {Template_Linux:vfs.dev.write[,ops].avg(120)}>3000
      Please let me know if you need any more details.
      • batchenr
        • Sep 2016
        • 440
        [mysqld]
        max_connections=600
        skip-name-resolve
        read_buffer_size=1M
        join_buffer_size=1M
        tmp_table_size=16M
        local-infile=0
        symbolic-links=0
        skip_secure_auth
        slow_query_log=0
        long_query_time=1
        general_log=0
        log_output=TABLE
        sysdate-is-now
        log-warnings=0
        thread_cache=64
        core-file
        server-id = 53
        sort_buffer_size=1M
        key_buffer=64M
        query_cache_type=1
        [mysql.server]
        user=mysql
        [mysql_safe]
        ok so,
        1.is the zabbix db is myisam or innodb?
        2.is the trigger you send is one trigger ? it can explain the issue which your asking to read and write at the same time and it gets locked.
        (again im no expert it is what i think.)
        this is my setting after workd hard to make mysql work faster
        see if you can benafit from it :
        datadir=/var/lib/mysql_orig/mysql
        socket=/var/lib/mysql_orig/mysql.sock
        user=mysql
        innodb_file_per_table=1
        key_buffer_size=1G
        innodb_flush_method=O_DIRECT
        innodb_log_file_size=1G
        innodb_buffer_pool_size=9G
        innodb_flush_log_at_trx_commit=0
        query_cache_size=32M
        query_cache_type=0
        log_slow_queries = 1
        skip-name-resolve
        open_files_limit=6740
        join_buffer_size=128K
        innodb_max_dirty_pages_pct=90
        innodb_support_xa = false
        table_cache = 80
        thread_cache_size = 4
        table_open_cache = 90
        innodb_log_buffer_size= 1M
        ***dont use innodb_file_per_table if you didnt make all the necessary changes for it*** http://dba.stackexchange.com/questio...bdata-in-mysql
        • kanchan
          • Dec 2013
          • 23
          We are using innodb and those are 2 separate triggers which I am trying to add.
          Thanks for sharing your mysql configuration. I will go through it.
