Process killed by signal: 11
  • soundsessential
    • Aug 2024
    I just updated a Mac to macOS Sonoma and reinstalled the Zabbix agent that was running on it previously (zabbix_agent-5.4.8-macos-amd64). It's mostly working fine but I am getting this error in the logs:
    Failed to execute command "/Library/FileMaker\ Server/Database\ Server/bin/fmsadmin list clients -s -u *** -p ***": Process killed by signal: 11.
    That is being trigger by an item executing this:
    system.run["{$FMS_CLI_PATH}fmsadmin list clients -s -u {$FMS_U} -p {$FMS_P}",wait]
    The path is correct and if I run the command in Terminal it does execute fine. If I test the item from within the Zabbi
  • Answer selected by soundsessential at 22-08-2024, 14:46.
    tim.mooney
    • Dec 2012
    • 1434
    It's "fmsadmin" that's failing with the segmentation violation, correct? Not zabbix_agentd?
    Are you sure that the version of FileMaker Server you're using is supported on your version of MacOs and your processor family?
    When you say "if I run the command in Terminal", are you running it as the 'zabbix' user, or are you running it as yourself or some kind of pseudo-admin account?
    • soundsessential
      • Aug 2024
      Let me try that again... The saved text wasn't complete! :-)
      I just updated a Mac to macOS Sonoma and reinstalled the Zabbix agent that was running on it previously (zabbix_agent-5.4.8-macos-amd64). It's mostly working fine but I am getting this error in the logs (credentials suppressed here):
      The path is correct and if I run the command in Terminal it does execute fine. If I test the item from within the Zabbix template, I get the same error result.
      Any thoughts on why it's being killed? Many thanks.
      • tim.mooney
        • Dec 2012
        • 1434
        • soundsessential
          • Aug 2024
          Ah! Tim! Thank you! You've pushed me in the right direction. The zabbix user account was not part of the user group that fmsadmin runs under. I added the user to that group and no more error! This is new with Sonoma I think as under Ventura there was not an issue. But solved and I greatly appreciate you taking the time. Many thanks.
