Hello Zabbix Forums,
I have been configuring some database monitors using an ODBC connection to Microsoft SQL servers, mostly this has been working well as I have been using COUNT SQL queries to tell me if there is an entry in a table. Mostly these have been very small numbers, like 1.
I am now trying to configure a query that will return a count that is much larger and use this for graphing history as well as triggering an alert. I have noticed that Zabbix is truncating my results so it is only showing the first three characters.
I have configured my item like the attached image.
I have tested the query from isql on the zabbix server, and the results are correct:
However the results showing in latest data, and the graph, are showing 486:
The same problem has occurred if I try and retrieve a time stamp from a query, although that truncates at 16 characters. However, if I retrieve a text string then it returns the full string and it is not truncated.
Thanks in advance,
Tim
SQL> select count (*) FROM [distribution].[dbo].[MSrepl_commands] +------------+ | | +------------+ | 48657 | +------------+ SQLRowCount returns 1 1 rows fetched
SQL Replication Distribution Database MSrepl_commands 2017-01-24 17:00:58 486
Thanks in advance,
Tim
