Monitor a file on windows mounted drive
  • deepaksharma
    • Jul 2016
    • 12
    Hi Friends,
    I want to monitor a file (text/log) on windows mounted drive and want to set trigger based on content match. I had used the "log[d:\test.txt,abc]" but somehow its not working. Kindly suggest if anything is wrongly configured or suggest some links which I can refer.
    Thanks in advance.
  • batchenr
    • Sep 2016
    • 440
    Originally posted by deepaksharma
    Hi Friends,
    Thanks in advance.
    did you add it as zabbix active ?
