Zabbix and multiple LDAP authentification sources
  • Coolgeek
    • Aug 2024
    Hello !
    I have an issue I don't understand. I hope you can shed a bit of light onto this.
    We have 2 Active Directory I need Zabbix to authenticate user (with JIT) against : "AD1" and "AD2".
    Initially, we were all in AD1, but some change at work will made us all migrate to AD2. It won't be a big bang so I need to be able to authenticate against the 2.
    I tested the login against AD1, it works.
    I tested the login against AD2, it works.
    If I put AD1 by default, I can't login against AD2 with a user not yet created by JIT. It works if I try with a user already created.
    Is there a way to make Zabbix try to login against AD2 if the user is not in AD1 AND not yet created in Zabbix ?
    Thanks.
  • Coolgeek
    • Aug 2024
    I forgot some infos and I can't edit my post, so here they are :
    Additional infos :
    - Containers Zabbix 7.0.3
    - It's a fresh install, so all users doesn't exist yet in Zabbix
