Hello Zabbix Community,
I'm experiencing an issue while trying to create a dashboard in Zabbix for monitoring disk space usage on the C: drive of our server dbfz-clu2023-n1. The setup includes a pie chart graph named "Disk space usage C:" which uses the template Template OS Windows C Drive Only.
The graph is configured to show both the total disk space and used disk space. When I check the latest data, everything seems to be fine, and the data is available. However, the graph does not reflect the data for a particular user. Strangely, this problem does not occur for other users.
Here are the steps we've taken so far:
I'm attaching screenshots of the graph configuration and the data as seen by other users.
Has anyone encountered a similar issue? What could be causing this discrepancy for the specific user? Any insights or suggestions on how to resolve this would be greatly appreciated.
Thank you!
- Verified the graph configuration and ensured it is set up correctly.
- Checked that the data is being collected and displayed under "Latest Data."
- Granted administrator privileges to the affected user, but the data still does not display in the graph.
Thank you!
